NEC
Revision as of 22:01, 10 January 2014 by Tdavis (talk | contribs)
  • Panel Technology - IPS
    • Viewable Image Size - 29.8 in
    • Aspect Ratio - 16:10
    • Native Resolution - 2560 x 1600
    • Pixel Pitch - 0.25mm
    • Pixels Per Inch - 101@ native resolution
    • Backlight Type - GB-R LED
    • PWM Frequency - 49 KHz
    • Brightness (typical) - 340cd /m2
    • Contrast Ratio (typical) - 1000 : 1
    • Viewing Angle (typical) - 178° Vert., 178° Hor. (89U/89D/89L/89R) @ CR>10
    • ResponseTime (typical) - 6 ms
  • Color Gamut
    • Adobe RGB Coverage /Size - 99.3% / 108.6%
    • NTSC Coverage /Size - 94.8% / 103.7%
    • sRGB Coverage /Size - 146.4% / 100%
    • Lookup Table - 14-bit (3D)
    • Displayable Colors - 1.07 billion out of 4.3 trillion
  • Synchronization Range
    • Horizontal (Analog /Digital) - 31.5-98.7 kHz (Digital only)
    • Vertical - 50 - 85 Hz
  • Input Connectors - DisplayPort, Mini DisplayPort, HDMI, DVI-D Dual Link, USB hub (2 up/ 3 down) with DisplaySync Pro
  • Power Consumption (typical)
    • On - 87 W
    • Power Savings Mode - 1.4 W
  • Physical Specifications
    • Dimensions (WxHxD)
      • Net (with stand) - 27.1 x 18.4-24.3 x 11.9 in. / 688.3 x 466.4-616.4 x 301.6mm
      • Net (without stand) - 27.1 x 17.6 x 3.2 in. / 688.0 x 446.8 x 82.0mm
    • Weight
      • Net Weight (with stand) - 37.5 lbs. / 17.0 kg
      • Net Weight (without stand) - 23.6 lbs / 10.7 kg
    • VESA Hole Configuration Specifications - 100 x 100mm, 200 x 100mm
  • Environmental Conditions
    • Operating Temperature - 41-95°F / 5-35°C
    • Operating Humidity - 20-80%
    • Operating Altitude - 16,404 ft. / 5000m
    • Storage Temperature - 14-140°F / -10-60°C
    • Storage Humidity - 10-85%
    • Storage Altitude - 40,000 ft / 12,192 m
  • Environmental Compliance
    • RoHS - Yes
  • Limited Warranty (parts & labor, including backlight) - 4 years
  • Additional Features - ECO Mode, Carbon footprint meter, Thin frame, Tilt, Swivel, Pivot, Height-adjustable stand with locking base, Quick release stand, Carrying handle, Rapid Response, Ambix4, XtraView+, OSD user controls, MultiProfiler software, USB hub (2 up/3 down) with DisplaySync Pro, Cable management, Touch-integratable, VESA mount, HDCP, DDC/CI, 14-bit 3D LUT, Digital Uniformity Correction, Black Level adjustment, AmbiBright, Wide Color Gamut, Adobe RGB, CableComp, TileMatrix, TileComp, GammaComp MD QA software, SpectraView software-ready, Standalone hardware calibration
  • Ships With
Power cable
DisplayPort cable
Mini DisplayPort to DisplayPort cable
DVI cable
USB cable
Mounting Screws
  • Optional Accessories
    • SpectraViewII Color Calibration Kit - SVII-PRO-KIT
    • Color calibration sensor - MDSVSENSOR3
    • SpectraView software - SVIISOFT
    • Hood - HDPA30-2
  • Manufacturer's tech specs as of 10 Jan 2014
