I
IASUU | Stereo polarizing spectacles in a plastic frame | 19??-19?? | - |
IBSOR | Single exposure shutter used with OLEYO and OLIGO housings Forum discussion | 1939-19?? | NY item |
IDCOO | M3 leather ready case | 1954-1968 | - |
IFLEX | Scientific version of Visoflex I with rotating clear or diffused focusing screen in screw and bayonet versions Fontenelle archive | 1953-19?? | - |
IFSTA | Adjustable filter stand copy accessory | 1939-19?? | - |
IGEMO | M3 body only | 1954-1968 | 10150 |
ILNOO | Elmar (II) f= 9 cm 1:4 collapsible | 19??-19?? | - |
ILNOO-M | 90mm f/4 Elmar collapsible M-mount | 1954-1968 | - |
ILLUM | Copy stand 2 pair lamp attachment for 2" diameter column | 19??-19?? | NY item |
ILNUU | Stereo projection attachment for twin 85 mm Hektor lenses used with PRADO projectors | 19??-19?? | - |
IMARO | M3 (IGEMO) with F = 5 cm 1:3.5 Elmar | 1954-1968 | - |
IMFIN | Universal viewfinder knon as "Imarect" | ca.1942-19xx | NY item |
IMOOP | MP and MP2 body | 1956-1959 | - |
IMPUU | Stereo projection attachment for twin 50 mm Elmar lenses used with PRADO projectors | ca.1956 | see Westlicht 22/249 |
IMPUU -IZOUU |
Stereo projection attachment for twin 50 mm Elmar lenses used with PRADO 250 and 500 projectors | 19??-19?? | - |
INVOO | Forum discussion | 19??-19?? | 00001 |
IROOA | Hood for 35 & 50 mm lenses with E39 mount; black with wide chrome band; earliest engraved "Summicron-" without code word; later versions had "IROOA"; last with catalog number JCB's a little...IIIg - JCB's a little...M3 | 1959-19?? | 12571 |
IROOW | Cap for 28mm f/2.8 Elmarit I and 21mm f3.4 Super-Angulon [1] | 1964-1976 | 14042 |
IRZOO | M-mount adapter for using 35 & 50 mm Leica screw-thread on M-cameras Forum discussion [2] | 1956-19?? | 14097 see |
IRZUU | Stereo projection attachment for twin 100 mm Hektor lenses used with PRADO projectors | 19??-19?? | - |
ISAIO | M3 with F = 5 cm 1:1.5 Summarit | 1954-1968 | - |
ISBOO | M-mount adapter for using 90 mm Leica screw-thread on M-cameras Forum discussion [3] | 1956-19?? | 14098 see |
ISBUU | Stereo projection attachment for twin 120 mm Hektor lenses used with PRADO projectors | 19??-19?? | - |
ISOOZ | M-mount adapter for using 135 mm Leica screw-thread on M-cameras Forum discussion | 1956-19?? | 14099 see |
ISUMO | M3 with F = 5 cm 1:2 Summicron II | 1954-1968 | - |
ISUMO-N | M3 with F = 5 cm 1:2 Summicron II-DR near focusing range | 1954-1968 | - |
ISUMO-S | M3 with F = 5 cm 1:2 Summicron II-Rigid | 1954-1968 | - |
ITDOO | Hood for 3.5 cm Summaron and 5 cm Summicron with narrow chrome band and velvet lining for reverse positioning | 1956-1960 | Forum discussion |
ITOOY | Hood for 3 cm Elmar with E39 front flange; early version engraved "Elmar-"; late version with wide chrome band JCB's a little...Ig | 1956-19?? | 12580 |
IUFOO | Hood for 9 cm Elmar and 135 Hektor; black with narrow chrome band at lens; wider chrome band; all black last version | 1956-19?? | 12575 |
IVZOO | Cap that screws into M-mount body | 19??-19?? | 14056 |
IWKOO | Hood for Super-Angulon f= 2.1 cm 1:4 with double trigger fastening Forum discussion | 1960-19?? | 12502 |
IXMOO | Reloadable metal cassette with chrome tab; new version | 1966-19?? | 14006 |
IZQOO | Rear dust cover for M-thread lens | 19??-19?? | 14051 |
