75mm f/1.4 Summilux-M
- Leica Order No. - 11814 - 11815-built-in hood - 11810 . LLC - 165
- Production era - 1980-2007 < 14,752 lenses
- Variants - Black, titanium, ELC, ELW, 1913-1983 anniversary edition; after 1982 built-in hood version 11 815
- F stop range - f/1.4-f/16
- Closest focusing distance - 0.75 m /2.46 ft
- Smallest object field - 192 mm x 288 mm /1:8
- Diaphragm setting /type - with clickstops from serial No. 2048701 onwards including half values / 10-blade
- Angle of view diagonal, horizontal, vertical - 32°, 27°, 18°
- Filter type - E60
- Accessories - Hood for 1st version: 12539
- Materials -
- Dimensions (length x diameter) - 80 x 69 mm /3.15 x 2.72 in
- Weight - 560 g /19.75
- Inscription - LEICA LENS MADE IN CANADA 1:1.4/75 E60 SUMMILUX-M XXXXXXX
- LEITZ SUMMILUX-M 1:1.4/75 E60 325XXXX
- LEICA SUMMILUX-M 1:1.4/75 E60 395XXXX
- Designer - Walter Mandler "his favorite lens"
- Leica Tech Data
- 75mm f/1.4 Summilux-M.pdf - courtesy Summilux.net
- Erwin Puts (2002) Leica M-Lenses.pdf - pgs. 60 - 63
- On the street - $US 2,300 - 2,650 (built-in hood) in 2010 - €EU 3,680 in 2015
- Gabriele Caproni - in Italian
- Thorston Overgaard
Leica 75mm f/1.4 Summilux-M Serial Numbers
Serial numbers compiled from known lenses and Puts Pocket Pod.pdf~ stolen lens, please report if found on sale
3063301 | 3064300 | 75mm f/1.4 Summilux-M | 1980 | 1000 |
3150501 | 3151500 | 75mm f/1.4 Summilux-M | 1981 | 1000 |
11 814 | ABOVE | BUILT-IN HOOD BELOW | 11815 | 11810 |
3223301 | 3225300 | 75mm f/1.4 Summilux-M (13-83) | 1982 | 2000 |
3258101 | 3260100 | 75mm f/1.4 Summilux-M | 1983 | 2000 |
3439501 | 3440000 | 75mm f/1.4 Summilux-M | 1987 | 500 |
3457871 | 3458370 | 75mm f/1.4 Summilux-M (11815) | 1988 | 500 |
3484901 | 3485400 | 75mm f/1.4 Summilux-M | 1989 | 500 |
3508996 | 3509295 | 75mm f/1.4 Summilux-M | 1990 | 300 |
3525296 | 3525795 | 75mm f/1.4 Summilux-M | 1990 | 500 |
3574134 | 3574633 | 75mm f/1.4 Summilux-M | 1991 | 500 |
3607320 | 3607619 | 75mm f/1.4 Summilux-M | 1993 | 300 |
3614480 | 3614979 | 75mm f/1.4 Summilux-M | 1993 | 500 |
3617900 | 3617901 | 75mm f/1.4 Summilux-M | 1993 | 2 |
3641576 | 3641825 | 75mm f/1.4 Summilux-M (11815) | 1993 | 250 |
3685731 | 3686230 | 75mm f/1.4 Summilux-M | 1995 | 500 |
3719103 | 3719602 | 75mm f/1.4 Summilux-M (11810) | 1995 | 500 |
3797510 | 3797709 | 75mm f/1.4 Summilux-M (11810) | 1997 | 200 ~3797842 |
3820125 | 3820624 | 75mm f/1.4 Summilux-M | 1998 | 500 |
3837375 | 3837974 | 75mm f/1.4 Summilux-M | 1998 | 600 |
3865967 | 3866166 | 75mm f/1.4 Summilux-M | 1999 | 200 |
3869617 | 3869916 | 75mm f/1.4 Summilux-M | 1999 | 300 |
3884907 | 3885206 | 75mm f/1.4 Summilux-M | 2000 | 300 |
3904826 | 3905125 | 75mm f/1.4 Summilux-M | 2000 | 300 |
3915523 | 3916022 | 75mm f/1.4 Summilux-M (11810) | 2001 | 500 |
3953001 | 3953500 | 75mm f/1.4 Summilux-M (ELW) | 2002 | 500 |
3977589 | 3977888 | 75mm f/1.4 Summilux-M (ELW) | 2004 | 300 |
3988519 | 3988718 | 75mm f/1.4 Summilux-M | 2005 | 200 |
unknown | unknown | 75mm f/1.4 Summilux-M | 2006-2007 | unknown |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1980-2005 | 14,752 |
