Magnus 1.5 - 10 x 42
Revision as of 17:05, 5 November 2014 by Tdavis (talk | contribs)
  • Production era - 2011-Current
  • Order no. per Reticle - 53 0XX - 12 variations
  • Name and Type - Magnus 1.5 - 10 x 42
  • Front lens diameter - 42 mm
  • Magnification - 1.5 - 10 x
  • Zoom factor - 6.7
  • Field of View at max. magnification - 4.4 yds /4.1 m
  • Field of View at min. magnification - 28.4 yds /26 m
  • Eye Relief - 3.5 in /90 mm
  • Exit pupil - 12.4 - 4.2 mm
  • Parallax - 109 yds /100 mm
  • Diopter Compensation - -4 / +3
  • Transmission - ~ 91 %
  • Mounting options - 30 mm tube /Zeiss internal track
  • Impact point correction - 1 click - 0.39 in/10 yds (1/3 MOA), 59 in × 55 in/150 × 140 cm
  • Weight - 21.9 oz /620 g
  • Length - 124.8 in / 317 mm
  • Waterproof to Depth - 4 m / 13.1 ft
  • Automatic switch-off - 3 min
  • Automatic switch-on - activated by position and /or movement
  • Materials - nitrogen filled aluminum
See manufacturer's technical data for complete specifications
ed. note - as of 2013 mid-May Magnus has been removed from Leica UK Sport Optic site - reason here [1] [2]
