75mm f/2 ASPH Apo-Summicron-M
  • Leica Order No. - 11 637
  • Production era - 2005-Current < 1,653+ lenses
  • Manufacturer - Schneider
  • Lens mount - Leica M quick-change bayonet
  • Number of lenses/groups - 7 /5
  • F stop range - f/2-f/16
  • Entrance Pupil position - 30.1 mm (related to the first lens surface in light direction)
  • Closest focusing distance - 0.7 m / 2.3 ft
  • Smallest object field - 169 x 254 mm
  • Maximum magnification - 1:7
  • Diaphragm setting / type - Preset 9-blade, with click-stops, half values available
  • Angle of view diagonal, horizontal, vertical - 32°, 27°, 18°
  • Filter type - Internal thread for screw-on filters size E49, non-rotating
  • Lens hood - Built-in, telescopic, lockable
  • Accessories - UVa Filter E49 13328, Universal Polarizing Filter 13356, Polarizing Filter 14418, Leica M Viewfinder Magnifiers 1.25x & 1.4x 12004 - 12006
  • Materials - Anodized aluminum, brass, and optical glass
  • Dimensions Length x Diameter - 66.8 x 58 mm / 2.6 x 2.3 in
  • Weight - 430 g / 15.2 oz
  • Inscription - APO-SUMMICRON-M 1:2/75 ASPH. E49
  • From Erwin Puts Blog "I am asked quite often what three or four lenses I would select that best represent the Leica philosophy. For this moment in time I would propose the following set:
Super-Elmar-M 3.4/21mm ASPH
Summilux-M 1.4/35 mm ASPH (latest version)
Summicron-M 2/75 ASPH
Here are the arguments: . . ."
75mm f/2 ASPH Apo-Summicron-M Serial Numbers
3983051 3983073 75mm f/2 ASPH Apo-Summicron-M 2004 25
3986034 3986433 75mm f/2 ASPH Apo-Summicron-M 2004 400
3986584 3986843 75mm f/2 ASPH Apo-Summicron-M 2005 260
3988144 3988493 75mm f/2 ASPH Apo-Summicron-M 2005 350
3989219 3989365 75mm f/2 ASPH Apo-Summicron-M 2005 150
-3993946 4004757- 75mm f/2 ASPH Apo-Summicron-M 2006 unknown
-unknown 4007331- 75mm f/2 ASPH Apo-Summicron-M 2007 unknown
-4044657 4045124- 75mm f/2 ASPH Apo-Summicron-M 2008 468+
-4122527 4122572- 75mm f/2 ASPH Apo-Summicron-M 2009 unknown
TOTAL ASSIGNED SERIAL NUMBERS 2004-2005 1,653+
