Digilux 2
Revision as of 19:43, 25 January 2010 by Admin (talk | contribs)
3D image Click-to-turn view
Digilux 2 Wikipedia
Modes - Program (P) with program shift ; Aperture priority (A) ; Shutter priority (T) ; Manual control (M), Black-and-white.
Exposure series - 2.7 or 1.0 exposures per second; maximum : 3–137 exposures with low/normal data compression.
Focus range - Close-up limit 30 cm (ca. 12 inches).
Flash - Pop-up flash with a guide number of 10 (metric) or 33 (feet) ; Range : 4.5 m or 15 feet with the wide-angle setting and 4 m or 13 feet with the telephoto setting (all at ISO 100) ; Flash functions Automatic flash activation, flash ON, flash OFF, pre-flash for red-eye reduction, SLOW (for long shutter speeds, SLOW with synchronization at the end of the exposure ; Flash exposure compensation ±2 EV in 1/3 EV steps ; Flash shoe with contacts for the control of an external flash unit SCA 3202.
Exposure compensation - -2EV - +2EV with 1/3EV steps ; Bracketing 3 or 5 pictures.
Shutter - Release button ; gentle pressure on the shutter release button stores the metered distance and exposure settings ; optional remote cable shutter release CR-DC1.
Exposure control - Program automatic, Aperture automatic, Time automatic and Manual setting ; metering TTL open aperture metering 49-zone (with optical viewfinder), 256-zone (in Live View mode) ; metered value storage AFL/AEL button or shutter button pressed halfway in AFS mode.
A-V recording - Video recording (max. 6 minutes on a 64 MB-Memory Card) ; sound recording is possible for every picture (during and after the exposure) ; trick film mode.
Power supply - Li-Ion 7.2 V, 1,400 mAh ; charger or external electrical mains connector/battery charger (ACA-DC3) supplied with the camera, (charging time approximately 2 hours with the ACA-DC3 battery charger).
Work conditions - Operating temperature 0 C > 40 C; air humidity 10 % > 80 %.
Out of the box - Electrical mains connector/battery charger ; Lithium-Ion battery 1400 mAh 7.2 V ; 64 MB SD-Memory Card ; lens cover ; lens hood with cover ; AV cable ; USB cable ; carrying strap ; Adobe Photoshop Elements 2.0 (Windows/Mac) ; ACDSee 6 PowerPack (Windows)/ACDSee 1.65 (Mac) ; LEICA USB Remote Control Software ; SilverFast 6 DCSE with Virtual Light Table ; Apple QuickTime 6 (Windows) ; USB driver for Windows 98SE
Accessories - Leather case, Cable Release, Li-ion Battery, UVa Filter, 4x ND Filter, Filter Holder, SF 24D Flash Unit, and the ELPRO-D E69 to extend focusing limits in the close-focus range.
Reviews
