Digilux 2
3D image Click-to-turn view
Digilux 2 Wikipedia
Focus range - Close-up limit 30 cm (ca. 12 inches).
Accessories - Leather case, Cable Release, Li-ion Battery, UVa Filter, 4x ND Filter, Filter Holder, SF 24D Flash Unit, and the ELPRO-D E69 to extend focusing limits in the close-focus range.
- Specifications adapted from manufacturer's technical data of June 2006. Leica Digilux 2 Data
Reviews
Digilux 2 Serial Numbers
Serial numbers compiled from Put's Pocket PodSN Start | SN End | Product | Year | Total |
2984401 | 2999400 | Digilux 2 | 2003 | 15,000 |
3004001 | 3005000 | Digilux 2 | 2004 | 1,000 |
3011101 | 3026100 | Digilux 2 | 2004 | 15,000 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 2003-2004 | 31,000 |
