U
Revision as of 18:18, 27 January 2010 by Admin (talk | contribs)
UBECD 22 mm extension tube for Focoslide and also for UDIMO enlarger using 5 cm Elmar 1936-1940 NY item
UCEGU Pradovit I with Dimaron 2.8/100mm 1960 -
UCFKU Pradovit I with Colorplan 2.5/90mm 1960 -
UCHRU Protective metal hood for Pradovit I 1960 -
UCNXU Pradovit f with Dimaron 2.8/100mm 1960 -
UCPLU Pradovit f with Colorplan 2.5/90mm 1960 -
UCSHU Remote control cable 4m long 1960 -
UCWQU 1960 -
UDCBU Pradovit f with Dimaron 2.8/150mm 1960 -
UDIMO Enlarger 19??-19?? -
UDGKU Plywood case for projector plus accessories and 150mm lenses 1960 -
UDKQU Second heat protection filter, including 500-watt lamp 1960 -
UDWPU Transparent container for 2 slide magazines 1960 -
UDXRU Transparent containers with 2 magazines 1960 -
UDLSU 1960 -
UEOOK Adaptor ring for UZEOO 36 mm front lens mount 19??-19?? 16568
UEOXU Slide magazine for 30 slides 1960 -
UEPOO Adaptor ring for UZEOO 42 mm front lens mount 19??-19?? 16566
UFBXU 5 magazine cassette 1960 -
UFTGU 2 slide magazines for 50 slides incl. cardboard 1960 -
UGPXU Remote control cable 10m long 1960 -
UGQZU Remote control cable 15m long 1960 -
UGRBU Remote control cable 20m long 1960 -
UHPWU Multiple connector for tape device and cable 1960 -
UKGDU Synchronous circuit with tape 1960 -
UMHDU Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable 1960 -
UMIQU Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable 1960 -
UMKHU Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable 1960 -
UMLKU Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable 1960 -
UMNOU Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable 1960 -
UNOOB Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for Elmar (I) f= 5 cm 1:3.5 1934-19?? -
UNOOB-YSMOO Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for Summar f= 5 cm 1:2 1937-19?? -
UOOND Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW 1956-19?? 16596
UOOPE Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb ? -
UOORE Adapter to use the lens head of the rigid 50mm Summicron on BOOWU-M ? 16508
UOORF Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY 1960 16508
UOOST UOOYW + UOOVH ? -
UOOVH Lens adapter ring for the head of Hector and Elmar 135mm ? 16580
UOOWV Lens Adapter Ring for heads and the Elmarit 90mm Elmar ? 16585
UOOXI Adapter Ring Lens fü the head of the 125mm Hektor 1958 16572
UOOYW Bellows connecting ring for I and II ? 16590 N
UOOZK Adapter ring for the head of the Summicron 90 mm 1960 16598
UOSWU Horizontal slider for Prado S and SM ? -
UPOOZ Yellow very light no. 0 filter; screw-on type E58 ca.1951 13235
UQMOO Yellow light no. 1 filter; screw-on type E58 ca.1951 13235
UQOOY Yellow medium no. 2 filter; screw-on type E58 ca.1951 -
UROOX Panchromatic green filter; screw-on type E58 ca.1951 13245
USFLA Kodachrome flash filter; type E58 1949-19?? NY item
USOAY Kodachrome type A filter; type E58 1949-19?? NY item
USOOW Orange filter; screw-on type E58 ca.1951 13250
USQOO Infra-red light no. 1 filter; screw-on type E58 ca.1951 13255
USSKY Kodachrome skylight filter; type E58 1954-19?? NY item
UTOOV Infra-red medium no. 2 filter; screw-on type E58 ca.1951 -
UTSOO Infra-red dark no. 3 filter; screw-on type E58 ca.1951 13265
UUOYW Adapter ring used to mount screw-mount lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used for mounting extension tube or copy device like Focoslide for close-up work. The M-mount version is UUOND 1956-19?? -
UVOOF UVa filter; screw-on type E58 ca.1951 13270
UVWOO 4-way lamp socket with cable and plug 1951-19?? 16760
UWOOS Arm connector for copy stand Focoslide 19??-19?? 16601
UWYOO Adaptor plate for using focusing bellows on carrying arms ROONP and ROOFU 1951-19?? 16600
UXOOR Universal focusing bellows; early version had smaller diameter thread for the lens mount and was supplied with an adaptor ring UOOYW and tube UOOVH for Hektor f= 13.5 cm 1:4.5 ; later version has thread for universal focusing bellows II with interchangable adaptor rings 1951-19?? 16555
[1]
[2]
UYOOQ Fiber case with Visoflex I, bellows and accessories ? -
UZEOO Large extending bellows lens hood with changeover mask frame for upright and horizontal shots for 36 mm front lens mount 1951-19?? 16565
UZEOO-M Bellows lens hood for 42 mm front lens mount 1960-19?? 16567
