U
| UBECD | 22 mm extension tube for Focoslide and also for UDIMO enlarger using 5 cm Elmar | 1936-1940 | NY item |
| UCEGU | Pradovit I with Dimaron 2.8/100mm | 1960 | - |
| UCFKU | Pradovit I with Colorplan 2.5/90mm | 1960 | - |
| UCHRU | Protective metal hood for Pradovit I | 1960 | - |
| UCNXU | Pradovit f with Dimaron 2.8/100mm | 1960 | - |
| UCPLU | Pradovit f with Colorplan 2.5/90mm | 1960 | - |
| UCSHU | Remote control cable 4m long | 1960 | - |
| UCWQU | 1960 | - | |
| UDCBU | Pradovit f with Dimaron 2.8/150mm | 1960 | - |
| UDIMO | Enlarger | 19??-19?? | - |
| UDGKU | Plywood case for projector plus accessories and 150mm lenses | 1960 | - |
| UDKQU | Second heat protection filter, including 500-watt lamp | 1960 | - |
| UDWPU | Transparent container for 2 slide magazines | 1960 | - |
| UDXRU | Transparent containers with 2 magazines | 1960 | - |
| UDLSU | 1960 | - | |
| UEOOK | Adaptor ring for UZEOO 36 mm front lens mount | 19??-19?? | 16568 |
| UEOXU | Slide magazine for 30 slides | 1960 | - |
| UEPOO | Adaptor ring for UZEOO 42 mm front lens mount | 19??-19?? | 16566 |
| UFBXU | 5 magazine cassette | 1960 | - |
| UFTGU | 2 slide magazines for 50 slides incl. cardboard | 1960 | - |
| UGPXU | Remote control cable 10m long | 1960 | - |
| UGQZU | Remote control cable 15m long | 1960 | - |
| UGRBU | Remote control cable 20m long | 1960 | - |
| UHPWU | Multiple connector for tape device and cable | 1960 | - |
| UKGDU | Synchronous circuit with tape | 1960 | - |
| UMHDU | Pradovit f with Dimaron 2.8/100mm, at 60Hz switchable | 1960 | - |
| UMIQU | Pradovit f with Colorplan 2.5/90mm, at 60 Hz. switchable | 1960 | - |
| UMKHU | Pradovit f with Hektor 2.5/120mm, at 60 Hz. switchable | 1960 | - |
| UMLKU | Pradovit f with Dimaron 2.8/150mm, at 60 Hz. switchable | 1960 | - |
| UMNOU | Pradovit f with Hektor 2.5/150mm, at 60 Hz. switchable | 1960 | - |
| UNOOB | Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for Elmar (I) f= 5 cm 1:3.5 | 1934-19?? | - |
| UNOOB-YSMOO | Carrying arm with lens holder and variable bellows, known as the lower stage of the universal reproduction apparatus for Summar f= 5 cm 1:2 | 1937-19?? | - |
| UOOND | Adapter ring used to mount Leica M lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used to mount M lens on screw mount extension tube or copy device like Focoslide for close-up work. The screw mount version is UUOYW | 1956-19?? | 16596 |
| UOOPE | Spannungsreduzierer with voltmeter to extend the life of AKTOO projector bulb | ? | - |
| UOORE | Adapter to use the lens head of the rigid 50mm Summicron on BOOWU-M | ? | 16508 |
| UOORF | Adapter ring for the lens head of the rigid Summicron 50 with SOOKY or SOMKY | 1960 | 16508 |
| UOOST | UOOYW + UOOVH | ? | - |
| UOOVH | Lens adapter ring for the head of Hector and Elmar 135mm | ? | 16580 |
| UOOWV | Lens Adapter Ring for heads and the Elmarit 90mm Elmar | ? | 16585 |
| UOOXI | Adapter Ring Lens fü the head of the 125mm Hektor | 1958 | 16572 |
| UOOYW | Bellows connecting ring for I and II | ? | 16590 N |
| UOOZK | Adapter ring for the head of the Summicron 90 mm | 1960 | 16598 |
| UOSWU | Horizontal slider for Prado S and SM | ? | - |
| UPOOZ | Yellow very light no. 0 filter; screw-on type E58 | ca.1951 | 13235 |
| UQMOO | Yellow light no. 1 filter; screw-on type E58 | ca.1951 | 13235 |
| UQOOY | Yellow medium no. 2 filter; screw-on type E58 | ca.1951 | - |
| UROOX | Panchromatic green filter; screw-on type E58 | ca.1951 | 13245 |
| USFLA | Kodachrome flash filter; type E58 | 1949-19?? | NY item |
| USOAY | Kodachrome type A filter; type E58 | 1949-19?? | NY item |
| USOOW | Orange filter; screw-on type E58 | ca.1951 | 13250 |
| USQOO | Infra-red light no. 1 filter; screw-on type E58 | ca.1951 | 13255 |
| USSKY | Kodachrome skylight filter; type E58 | 1954-19?? | NY item |
| UTOOV | Infra-red medium no. 2 filter; screw-on type E58 | ca.1951 | - |
| UTSOO | Infra-red dark no. 3 filter; screw-on type E58 | ca.1951 | 13265 |
| UUOYW | Adapter ring used to mount screw-mount lens and Viso II or Viso III accessories to Viso I or PLOOT reflex housings. It can also be used for mounting extension tube or copy device like Focoslide for close-up work. The M-mount version is UUOND | 1956-19?? | - |
| UVOOF | UVa filter; screw-on type E58 | ca.1951 | 13270 |
| UVWOO | 4-way lamp socket with cable and plug | 1951-19?? | 16760 |
| UWOOS | Arm connector for copy stand Focoslide | 19??-19?? | 16601 |
| UWYOO | Adaptor plate for using focusing bellows on carrying arms ROONP and ROOFU | 1951-19?? | 16600 |
| UXOOR | Universal focusing bellows; early version had smaller diameter thread for the lens mount and was supplied with an adaptor ring UOOYW and tube UOOVH for Hektor f= 13.5 cm 1:4.5 ; later version has thread for universal focusing bellows II with interchangable adaptor rings | 1951-19?? | 16555 |
| UYOOQ | Fiber case with Visoflex I, bellows and accessories | ? | - |
| UZEOO | Large extending bellows lens hood with changeover mask frame for upright and horizontal shots for 36 mm front lens mount | 1951-19?? | 16565 |
| UZEOO-M | Bellows lens hood for 42 mm front lens mount | 1960-19?? | 16567 |
