Summicron (II) f= 9 cm 1:2
Revision as of 14:21, 3 March 2010 by Admin (talk | contribs)
  • Leica Order No. - SEOOF 11123, SEOOM 11133 LLC - 175
  • Production era - 1959-1979; Serial Nos. -3177200
  • Variants - Black and chrome versions
  • Number of lenses /groups -
  • F stop range - f/2 > f/16 or f/22
  • Smallest object field -
  • Diaphragm setting /type -
  • Angle of view diagonal - 27 degrees
  • Filter type - E49
  • Accessories -
  • Materials - Clear and black anodized aluminum
  • Dimensions length - 64.5 mm / 2.55 in
  • Weight - 685 g /1.51 lb
  • Inscription - Ernst Leitz Canada Summicron f-9cm 1:2 Nr.158xxxx; LEITZ CANADA 168XXXX SUMMICRON 1:2 / 90
  • Designer - Walter Mandler
  • Forum discussion
Summicron (II) f= 9 cm 1:2 Serial Numbers
1580001 1581000 Summicron f= 9 cm 1:2 1958 1000
1651001 1652000 Summicron f= 9 cm 1:2 1959 1000
1652451 1653450 Summicron f= 9 cm 1:2 1959 1000
1680001 1682000 Summicron f= 9 cm 1:2 1959 2000
1740001 1743500 Summicron f= 9 cm 1:2 1960 3500
1743501 1746500 Summicron f= 9 cm 1:2 1960 3000
1817001 1819000 Summicron f= 9 cm 1:2 1960 2000
1983001 1983900 Summicron f= 9 cm 1:2 1963 900
2025001 2026000 Summicron f= 9 cm 1:2 1964 1000
2068501 2069500 Summicron f= 9 cm 1:2 1964 1000
2150551 2151550 Summicron f= 9 cm 1:2 1965 1000
2203101 2204100 Summicron f= 9 cm 1:2 1966 1000
2246051 2247150 Summicron f= 9 cm 1:2 1967 1100
2332801 2333800 Summicron f= 9 cm 1:2 1969 1000
2370801 2371800 Summicron f= 9 cm 1:2 1969 1000
2413101 2413600 Summicron f= 9 cm 1:2 1970 500
2499651 2500650 Summicron f= 9 cm 1:2 1971 1000
2731921 2731921 Summicron f= 9 cm 1:2 1974 1
2731922 2731950 Summicron f= 9 cm 1:2 1975 29
2751051 2752050 Summicron f= 9 cm 1:2 1975 1000
TOTAL ASSIGNED SERIAL NUMBERS 1953-1975 1
