Digilux 2
[Cick-to-Turn [1]]
Type - Small digital rangefinder camera.
Lens provided - LEICA DC VARIO-SUMMICRON 7 > 22.5 mm f/2.0 > 2.4 ASPH. zoom lens (corresponds
to a 28 > 90 mm zoom lens for the 35 mm format), 13 lens elements in 10 groups.
Image Sensor - 2/3" CCD sensor with 5.24 million total pixels and 5 million effective pixels,
primary color filters.
Image sizes - 4:3 format 2,560 x 1,920 > 2048 x 1536 > 1,600 x 1,200 > 1,280 x 960 > 640
x 480 pixels (320 x 240 for video sequences) 16:9 format 1920 x 1080 pixels (HDTV).
Zoom - Corresponds to a 28 > 90 mm zoom lens for the 35 mm format. Digital focal length
extension 2x / 3x.
Modes - Program (P) with program shift ; Aperture priority (A) ; Shutter priority (T) ; Manual
control (m), Black-and-white.
Exposure series - 2.7 or 1.0 exposures per second; maximum : 3–137 exposures with low/normal
data compression.
Focus range - Close-up limit 30 cm (ca. 12 inches).
Flash - Built-in flash with a guide number of 10 (metric) or 33 (feet) ; Range : 4.5 m
or 15 feet with the wide-angle setting and 4 m or 13 feet with the telephoto setting (all at ISO
100) ; Flash functions Automatic flash activation, flash ON, flash OFF, pre-flash for red-eye
reduction, SLOW (for long shutter speeds, SLOW with synchronization at the end of the exposure ; Flash exposure compensation ±2 EV in 1/3 EV steps ; flash shoe with contacts for
the control of an external flash unit SCA 3202.
Storage - Secure Digital and MultiMedia-Card, limited to 2 GB (use Kingston 50x for 6 sec. RAW
download).
Metering - Multi-field, center-weighted, spot. Metering control a gentle pressure on the
shutter release button stores the metered distance and exposure settings..
White balance - Auto, manual, preset light conditions (daylight, overcast sky, incandescent
light, flash) with fine adjustment capability (±1500 K max.).
Shutter - Remote shutter release with optional remote cable shutter release CR-DC1.
Exposure - Exposure control Program automatic, aperture automatic, time automatic and
manual setting ; metering TTL open aperture metering 49-zone (with optical viewfinder),
256-zone (in Live View mode) ; metered value storage AFL/AEL button or shutter button pressed
halfway in AFS mode.
Continuous recording - Frame rate 3 or 2 i/s Exposure series 6 images (RAW),
unlimited (other formats, depending on memory card, picture resolution, image compression, battery
performance).
A-V recording - Video recording (max. 6 minutes on a 64 MB-Memory Card) ; sound recording is
possible for every picture (during and after the exposure) ; trick film mode.
Viewfinder - Electronic viewfinder with 235,000 pixels and diopter compensation (± 4 diopter),
suitable for eyeglass wearers
Ports - Digital USB 2.0 Hi-Speed, Video out Analog (video/TV) NTSC/PAL Composite
(switchable)..
Reproduction modes - EPSON Print Image System V2.5 (PIM), V1.1 (digital print order format)
DPOF, USB-Direct Print,
File formats - RRAW, JPEG (very low, low and normal compression / SUPER FINE, FINE,
STANDARD), Motion-JPEG.
Power supply - Li-Ion 7.2 V, 1,400 mAh ; charger or external electrical mains
connector/battery charger (ACA-DC3) (supplied with the camera), charging time approximately 2 hours
with the ACA-DC3 battery charger.
Weight - approx. 630 / 705 gm or 22 / 25 oz (with / without battery).
Dimensions (W x H x D) - 135 x 82 x 103 mm - 5 5⁄16 x 3 1⁄4 x 4 1⁄16 inches.
Camera body - Metal & black plastic.
Operating conditions - Operating temperature 0ー C > 40ー C; air humidity 10 % > 80 %.
Out of the box - Electrical mains connector/battery charger ; Lithium-Ion battery 1400 mAh 7.2
V ; 64 MB SD-Memory Card ; lens cover ; lens hood with cover ; AV cable ; USB cable ; carrying strap
- Adobe Photoshop Elements 2.0 (Windows/Mac) ; ACDSee 6 PowerPack (Windows)/ACDSee 1.65 (Mac) ;
LEICA USB Remote Control Software ; SilverFast 6 DCSE with Virtual Light Table ; Apple QuickTime 6
(Windows) ; USB driver for Windows 98SE
Accessories - Leather case, Cable Release, Li-ion Battery, UVa Filter, ND Filter 4x, Filter
Holder.
--Tdavis 01:32, 17 November 2008 (CET)
Launched - December 1, 2003+.
Era - February 2004 > 2006 http://www.overgaard.dk/leica_digilux2.html
