Digilux 2
Revision as of 02:19, 17 November 2008 by Admin (talk | contribs)
[Cick-to-Turn [1]]
Lens - LEICA DC VARIO-SUMMICRON 7 > 22.5 mm f/2.0 > 2.4 ASPH. zoom lens (corresponds to a 28 > 90 mm zoom lens for the 35 mm format), 13 lens elements in 10 groups.
Modes - Program (P) with program shift ; Aperture priority (A) ; Shutter priority (T) ; Manual control (m), Black-and-white.
Exposure series - 2.7 or 1.0 exposures per second; maximum : 3–137 exposures with low/normal data compression.
Focus range - Close-up limit 30 cm (ca. 12 inches).
Flash - Built-in flash with a guide number of 10 (metric) or 33 (feet) ; Range : 4.5 m or 15 feet with the wide-angle setting and 4 m or 13 feet with the telephoto setting (all at ISO 100) ; Flash functions Automatic flash activation, flash ON, flash OFF, pre-flash for red-eye reduction, SLOW (for long shutter speeds, SLOW with synchronization at the end of the exposure ; Flash exposure compensation ±2 EV in 1/3 EV steps ; flash shoe with contacts for the control of an external flash unit SCA 3202.
Metering - Multi-field, center-weighted, spot. Metering control a gentle pressure on the shutter release button stores the metered distance and exposure settings..
Exposure compensation - -2EV - +2EV with 1/3EV steps ; Bracketing 3 or 5 pictures.
Shutter - Remote shutter release with optional remote cable shutter release CR-DC1.
Exposure - Exposure control Program automatic, aperture automatic, time automatic and manual setting ; metering TTL open aperture metering 49-zone (with optical viewfinder), 256-zone (in Live View mode) ; metered value storage AFL/AEL button or shutter button pressed halfway in AFS mode.
A-V recording - Video recording (max. 6 minutes on a 64 MB-Memory Card) ; sound recording is possible for every picture (during and after the exposure) ; trick film mode.
Viewfinder - Electronic viewfinder with 235,000 pixels and diopter compensation (± 4 diopter), suitable for eyeglass wearers.
Power supply - Li-Ion 7.2 V, 1,400 mAh ; charger or external electrical mains connector/battery charger (ACA-DC3) (supplied with the camera), charging time approximately 2 hours with the ACA-DC3 battery charger.
Weight - ca. 630 / 705 gm or 22 / 25 oz (with / without battery).
Dimensions (W x H x D) - 135 x 82 x 103 mm - 5 5⁄16 x 3 1⁄4 x 4 1⁄16 inches.
Camera body - Metal & black plastic.
Operating conditions - Operating temperature 0ー C > 40ー C; air humidity 10 % > 80 %.
Out of the box - Electrical mains connector/battery charger ; Lithium-Ion battery 1400 mAh 7.2 V ; 64 MB SD-Memory Card ; lens cover ; lens hood with cover ; AV cable ; USB cable ; carrying strap ; Adobe Photoshop Elements 2.0 (Windows/Mac) ; ACDSee 6 PowerPack (Windows)/ACDSee 1.65 (Mac) ; LEICA USB Remote Control Software ; SilverFast 6 DCSE with Virtual Light Table ; Apple QuickTime 6 (Windows) ; USB driver for Windows 98SE
Accessories - Leather case, Cable Release, Li-ion Battery, UVa Filter, ND Filter 4x, Filter Holder.
--Tdavis 01:32, 17 November 2008 (CET)
Launched - December 1, 2003+.
Era - February 2004 > 2006 http://www.overgaard.dk/leica_digilux2.html
