B
Leitz "Binoculars" data courtesy of Peter Abrahams
BANAN | - | ||
BALGT | Adjustment bellows, for screw mounting to various Leica Adapter Rings | ? | - |
BATCA | - | ||
BDFUU | - | ||
BAZOO | Copy stand, superseded BESAL copy stand | ? | - |
BAZOS | Copy stand BAZOO, NY designation | ? | - |
BEECH | Lamp for MONLA Microscope, DC current | ? | - |
BEEUL | Lamp for MONLA Microscope, AC current | ? | - |
BEHOO | Copy stand for Elmar or Summar 5 cm, 1:1.5; 1: 2.1: 3 | 1935-1959 | - replaced BEMAR & BESOT |
BEINS | 1:1 copy stand for Elmar 3.5 cm | 1931 | - |
BEKUR | Copy stand for Elmar 3.5 cm with 3 extension rings for 1:1.5, 1:2, 1:3 | 1931 | - |
BEKUS | Copy stand for Elmar 35 mm with 3 extension rings for 1:1.5, 1:2, 1:3 | ? | - |
BELOS | Small lamp with adjustable bracket and 25 watt bulb | pre 1934 | - |
BELUN | 1:1 copy stand w/extension tube for 50mm Elmar | 1932-1958 | Forum discussion |
BELUNHESUM | 1:1 closeup stand w/extension tube for Summitar | ? | - |
BEMAR | Copy stand for Elmar 5 cm with 3 extension rings for 1:1.5, 1:2, 1:3 | 1932 | - |
BEMTI | - | ||
BEOON | Offset copy stand for 1:1 reproductions with M-5 cm lenses Forum discussion | 1959-1970 | - also 16511 |
BEOOS | Offset copy stand for 1:1 reproductions with M-3.5 cm lenses | ? | - |
BEOOY | Copy stand for Elmar, Hektor or Summar 5cm with 3 supplementary lenses | 1935-1951 | - |
BERAT | 25 watt bulb for BELOS adjustable lamp | 1934 | - |
BERIN | Intermediate collar and clamping ring for BEMAR for reproduction at 1:1 | 1932 | - |
BESAL | Copy stand combining BEVOR, BETAB and BEMAR with 3 extension rings for 1:1 reproduction with Elmar 5 cm | 1933 | - |
BESOT | Copy stand for Summar 5cm with 3 extension rings for 1:1.5, 1:2, 1:3 | ? | - |
BESUM | 1:1 copy stand w/extension tube for Summar 5 cm | 1935 | - |
BETAB | 4 legs for BEVOR with closeup lens No. 2 | ? | - |
BETRY | 3 legs for BELUN and BESUM | ? | - |
BEUUY | Extension tube | - | |
BEUUY-IZUUS | - | ||
BEVOR | Copy stand for Elmar or Hektor 5cm with 3 supplementary lenses | 1931 | - superseded by BEOOY |
BFOOX | Desk viewer with zoom lens, 2 film coils and lighting, for Leica USA | ? | - |
BIDAL | Binoculars – 6 x 15 - 7 deg | 1925-1939 | - |
BIDOX | Binoculars – 6 x 30 – 8.5 deg | ca.1927-1939 | - |
BIDOXIT | Binoculars – 6 x 30 – 8.5 deg – CF type | ca.1927-1962 | - |
BILOM | Binoculars – 8 x 30 – 6.3 deg | 1930-ca.1935 | - |
BILOMIT | Binoculars – 8 x 30 – 8.5 deg – CF type | 1930-ca.1935 | - |
BILUSTRA | Binoculars – 3 x 13.5 – 13.7 deg | 1921-1950s | - |
BIMAX | Binoculars – 8 x 24 – 8.5 deg | ca.1930-1935 | - |
BIMAXIT | Binoculars – 8 x 24 – 8.5 deg – CF type | ca.1930-1935 | - |
BIMULIORA | Binoculars – 4 x 16 | 1921-ca.1926 | - |
BINAR | Binoculars – 3 x 13.5 – 13.7 deg | 1921-1950s | - |
BINOCLE | Binoculars – 6 x 18 | May 14, 1907 | - first commercially available Leitz binoculars |
BINOCT | Binoculars – 8 x 26 | 1914-ca.1926 | - |
BINODAL | Binoculars – 6 x 21 – 8 deg | 1919 | - |
BINOFORTE | Binoculars – 12 x 46 | 1913 | - 12 x 42 in 1914 |
BINOFORTIM | Binoculars – 12 x 46 – CF type | 1913 | - 12 x 42 in 1914 |
BINOL | Binoculars – 6 x 24 – 8.5 deg | ca.1927-1939 | - |
BINOLAS | Binoculars – 6 x 21 – 8 deg – CF type | 1919 | - |
BINOLI | Binoculars – 6 x 24 | 1914-ca.1926 | - |
BINOLIT | Binoculars – 6 x 24 – 8.5 deg – CF type | ca.1927-1939 | - |
BINOM | Binoculars – 8 x 24 – 6.5 deg | 1913 | - 8 x 26 1914-ca.1926 |
BINOMA | Binoculars – 8 x 24 – 6.5 deg | 1913 | - heavy version of BINOM |
BINOMAT | Binoculars – 8 x 24 – 6.5 deg – CF type | 1914 | - |
BINDOMAT | - | ||
BINOMIA | Binoculars – 8 x 24 – 6.5 deg – CF type | 1913 | - |
BINOMINIA | Binoculars – 4 x 16 – 11 deg – CF type | 1914 | - |
BINOMINIOS | Binoculars – 4 x 16 – CF type | 1912-1914 | - theater glasses |
BINOMINOS | Binoculars – 4 x 16 – CF type | 1914 | - heavier theater glasses |
BINOPLASTICO | Binoculars – 30 x 90 – 1.5 deg | 1920 | - |
BINOSPO | Binoculars – 6 x 24 – CF type | 1914-ca.1926 | - |
BINOT | Binoculars – 6 x 30 | 1912-ca.1926 | - |
BINOTOUR | Binoculars – 6 x 16 – CF type | 1914 | - |
BINOTRIX | 3 oculars x 90 | 1920s | - on turret at 90 deg |
BINOVISTA | Binoculars – 15 x 60 – 3.5 deg | 1920 | - |
BINOXYD | Binoculars – 6 x 30 – CF type | 1912-ca.1926 | - |
BINOZE | Binoculars – 10 x 42 | 1912 | - |
BINOZITO | Binoculars – 10 x 46 – CF type | 1913 | - |
BINUX | Binoculars – 8 x 30 – 8.5 deg | 1927-1962 | - |
BINUXIT | Binoculars – 8 x 30 – 8.5 deg – CF type | 1927-1962 | - |
BIOCT | Binoculars – 8 x 24 – 6.3 deg | ca.1927-1939 | - |
BIOCTIT | Binoculars – 8 x 24 – 6.3 deg – CF type | ca.1927-1939 | - |
BISEXIT | Binoculars – 6 x 21 – 8.5 deg – CF type | 1925-1931 | - |
BITUR | Binoculars – 4 x 20 – 10.3 deg | ca.1925-1959 | - |
BIZWE | Binoculars – 12 x 42 | 1912 | - |
BKUUT | - | ||
BLIAU | Trigger for flash | ? | - |
BLISE | - | ||
BLITZ | Flash as a replacement for BUNOO, New York | ? | - |
BOOWU | Copy stand for screw lenses of focal length 5 cm, recording format, A4, A5, A6 | 1952-1962 | - also 16525 |
BOOWU-M | Copy stand for M lenses of focal length 5 cm, recording format, A4, A5, A6 . | 1956-1976 | - also 16526 and later BOWUM |
BOOXZ | 7mm extension tube for V: 1:2.5 for use with with ZWTOO | ? | - |
BPCUU | - | ||
BQCOO | A36 Blue filter | 1955 | - |
BRACK | Holder for SYNCO / FLASH in the vertical position | ? | - |
BRUUM | Small projector VIIIa interchangeable condenser lens for 5 cm focus | pre 1937 | - |
BSIUU | - | ||
BSUUA | - | ||
BTLOO | Flash unit for 2 flash bulbs for Leica I, II and IIIa | ? | - |
BTSOO | Flash unit for 2 flash bulbs for Leica IIIb/c | ? | - |
BTOOK | Flash unit for 2 flash bulbs for Leica Standard | ? | - |
BTLOL | Flash unit for 2 flash bulbs for Leica IIId? | ? | - |
BUNOO | Flash unit with internal synchronization for Leica IIIb or earlier; base-plate with 3/8" tripod socket, electrical contact pin and adjustment screw | ? | - |
BUUGR | Leitz briefcase projector, with lens | 1934 | - |
BUOOP | - | ||
BUUDC | - | ||
BUUQI | - | ||
BUURW | - | ||
BUUWM | - | ||
BUUYN | - | ||
BWOOG | Large battery container for flash unit | ? | - |
BWOOH | Large battery container for flash unit | ? | - |
BWOOL | Large battery container for flash unit | ? | - |
BWOOK | Large battery container for flash unit | ? | - |
BWOON | Large battery container for professional flash unit | ? | - |
BWOOP | Large battery container for flash unit with maximum performance | ? | - |
