135mm f/2.8 Elmarit-M I
Revision as of 21:01, 4 March 2010 by Admin (talk | contribs)
  • Leica Order No. - 11 829 LLC - 184
  • Production era - 1963-1964; Serial Nos. -2788926
  • Variants -
  • Number of lenses /groups - 5 /3
  • F stop range - f/2.8 > f/32
  • Closest focusing distance - 1.5 m /4.92 ft
  • Smallest object field - 220 x 330 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 18 degrees
  • Filter type - Series 7
  • Accessories -
  • Dimensions length x diameter - 120 x 66 mm / 4.72 x 2.60 in
  • Weight - 730 g /1.61 lb
  • Inscription - ELMARIT-M 1:2.8/135 LEITZ CANADA 1XXXXXX
  • Designer - Walter Mandler
  • Forum discussion
135mm f/2.8 Elmarit-M I Serial Numbers
1957001 1958000 135mm f/2.8 Elmarit 1962 1000
2011001 2011700 135mm f/2.8 Elmarit 1963 700
2038001 2038700 135mm f/2.8 Elmarit 1964 700
2151551 2152550 135mm f/2.8 Elmarit 1965 1000
2223201 2224000 135mm f/2.8 Elmarit 1967 800
2258901 2259900 135mm f/2.8 Elmarit 1968 1000
2288951 2289950 135mm f/2.8 Elmarit 1968 1000
2324301 2326300 135mm f/2.8 Elmarit 1969 2000
2424201 2425700 135mm f/2.8 Elmarit 1970 1500
2466501 2468500 135mm f/2.8 Elmarit 1970 2000
2655901 2656900 135mm f/2.8 Elmarit-M 1973 1000
2681801 2682800 135mm f/2.8 Elmarit-M 1974 1000
2771201 2773200 135mm f/2.8 Elmarit 1976 2000
2788651 2789650 135mm f/2.8 Elmarit-M 1976 1000
2849551 2850050 135mm f/2.8 Elmarit-M 1977 500
2872601 2873100 135mm f/2.8 Elmarit 1977 500
1878001 1880000 135mm f/2.8 Elmarit 1961 2000
1917001 1920000 135mm f/2.8 Elmarit 1962 3000
1983901 1984400 135mm f/2.8 Elmarit 1963 500
2001001 2002000 135mm f/2.8 Elmarit 1963 1000
2044001 2046000 135mm f/2.8 Elmarit 1964 2000
2084801 2088800 135mm f/2.8 Elmarit 1965 4000
2125651 2129950 Elmarit f= 9 cm 1:2.8 1965 4300
2213001 2215000 Elmarit f= 9 cm 1:2.8 1966 2000
2215001 2215200 Elmarit f= 9 cm 1:2.8 1966 200
2291951 2292050 Elmarit f= 9 cm 1:2.8 1968 100
2303951 2305150 Elmarit f= 9 cm 1:2.8 1968 1200
2372801 2374800 Elmarit f= 9 cm 1:2.8 1969 2000
2374801 2374900 Elmarit f= 9 cm 1:2.8 1969 100
2426301 2428300 Elmarit f= 9 cm 1:2.8 1970 2000
2428301 2428400 Elmarit f= 9 cm 1:2.8 1970 100
2428401 2428750 Elmarit f= 9 cm 1:2.8 1970 350
2522801 2523800 Elmarit f= 9 cm 1:2.8 1972 1000
2721001 2721320 Elmarit f= 9 cm 1:2.8 1974 320
TOTAL ASSIGNED SERIAL NUMBERS 1962-1976 1
