35mm f/2 Summicron-R I
- Leica Order No. - 11 227 LLC - 159
- Production era - 1972-1976
- Variants -
- Number of lenses /groups - 9 / 7
- F stop range - f/2-f/16
- Closest focusing distance - 30 cm / 11.81 in
- Smallest object field - 140 x 210 mm
- Diaphragm setting /type -
- Angle of view diagonal - 64 degrees
- Filter type - Series 7
- Accessories - Hood: 12509
- Materials -
- Dimensions length x diameter - 61 x 68 mm / 2.40 x 2.68 in
- Weight - 510 g /1.12 lb
- Inscription - SUMMICRON-R 1:2/35 LEITZ CANADA 2XXXXXX
- On the street - €EU 384 IN 2008
35mm f/2 Summicron-R I Serial Numbers
| 2402001 | 2404000 | 35mm f/2 Summicron-R | 1970 | 2000 |
| 2464501 | 2466500 | 35mm f/2 Summicron-R | 1970 | 2000 |
| 2545701 | 2545950 | 35mm f/2 Summicron-R | 1972 | 250 |
| 2613001 | 2613100 | 35mm f/2 Summicron-R | 1973 | 100 |
| 2615101 | 2617100 | 35mm f/2 Summicron-R | 1973 | 2000 |
| 2618101 | 2620100 | 35mm f/2 Summicron-R | 1973 | 2000 |
| 2693001 | 2694000 | 35mm f/2 Summicron-R | 1974 | 1000 |
| 2713351 | 2713850 | 35mm f/2 Summicron-R | 1974 | 500 |
| 2728921 | 2729420 | 35mm f/2 Summicron-R | 1974 | 500 |
| 2731421 | 2731920 | 35mm f/2 Summicron-R | 1974 | 500 |
| 2783151 | 2783350 | 35mm f/2 Summicron-R | 1976 | 200 |
| 2791151 | 2791650 | 35mm f/2 Summicron-R | 1976 | 500 |
| 2819351 | 2820350 | 35mm f/2 Summicron-R | 1977 | 1000 |
| 2859601 | 2860600 | 35mm f/2 Summicron-R | 1977 | 1000 |
| 2902801 | 2904800 | 35mm f/2 Summicron-R | 1978 | 2000 |
| 2935701 | 2937700 | 35mm f/2 Summicron-R | 1978 | 2000 |
| 2983101 | 2983600 | 35mm f/2 Summicron-R | 1979 | 500 |
| 2996701 | 2997000 | 35mm f/2 Summicron-R | 1979 | 3600 |
| 3002101 | 3003100 | 35mm f/2 Summicron-R | 1979 | 1000 |
| 3034401 | 3035400 | 35mm f/2 Summicron-R | 1980 | 1000 |
| 3069301 | 3070800 | 35mm f/2 Summicron-R | 1980 | 1500 |
| 3087001 | 3088000 | 35mm f/2 Summicron-R | 1981 | 1000 |
| 3124501 | 3125500 | 35mm f/2 Summicron-R | 1981 | 2000 |
| 3192701 | 3194700 | 35mm f/2 Summicron-R | 1982 | 2000 |
| 3246101 | 3248100 | 35mm f/2 Summicron-R | 1982 | 2000 |
| 3282401 | 3284400 | 35mm f/2 Summicron-R | 1983 | 2000 |
| 3363801 | 3365800 | 35mm f/2 Summicron-R | 1985 | 2000 |
| 3475151 | 3478150 | 35mm f/2 Summicron-R | 1988 | 3000 |
| 3583863 | 3583864 | 35mm f/2 Summicron-R | 1992 | 2 |
| 3617880 | 3617881 | 35mm f/2 Summicron-R | 1993 | 2 |
| 3843500 | 3843999 | 35mm f/2 Summicron-R | 1998 | 500 |
| 3864167 | 3864666 | 35mm f/2 Summicron-R | 1999 | 500 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1970-1999 | 1 |
