Summicron (I) f= 9 cm 1:2
- Leica Order No. - SOOZI, SEOOM 11123 11133 LLC - 174
- Production era - 1957-1962, 490 screw lens, 4430 bayonet lens Serial Nos. -2997000
- Variants - All black, all chrome, and black and chrome versions; preset ring with f/16 or f/22 minimum aperture
- F stop range - f/2 > f/22
- Diaphragm setting /type -
- Filter type - E48
- Accessories - Hood: HMOOD
- Materials -
- Dimensions length x diameter - 110 x 66 mm / 4.33 x 2.60 in
- Weight - 660 g /1.46 lb
- Inscription - LEITZ CANADA 165XXXX SUMMICRON 1:2/90; Ernst Leitz Canada Ltd. Midland Summicron f = 9cm 1:2 Nr. 158xxxx
- Designer - Walter Mandler
Summicron (I) f= 9 cm 1:2 Serial Numbers
1119001 | 1119200 | Summicron f= 9 cm 1:2 | 1953 | 200 |
1477001 | 1477100 | Summicron f= 9 cm 1:2 | 1957 | 100 |
1580001 | 1581000 | Summicron f= 9 cm 1:2 | 1958 | 1000 |
1651001 | 1652000 | Summicron f= 9 cm 1:2 | 1959 | 1000 |
1652451 | 1653450 | Summicron f= 9 cm 1:2 | 1959 | 1000 |
1680001 | 1682000 | Summicron f= 9 cm 1:2 | 1959 | 2000 |
1740001 | 1743500 | Summicron f= 9 cm 1:2 | 1960 | 3500 |
1743501 | 1746500 | Summicron f= 9 cm 1:2 | 1960 | 3000 |
1817001 | 1819000 | Summicron f= 9 cm 1:2 | 1960 | 2000 |
1983001 | 1983900 | Summicron f= 9 cm 1:2 | 1963 | 900 |
2025001 | 2026000 | Summicron f= 9 cm 1:2 | 1964 | 1000 |
2068501 | 2069500 | Summicron f= 9 cm 1:2 | 1964 | 1000 |
2150551 | 2151550 | Summicron f= 9 cm 1:2 | 1965 | 1000 |
2203101 | 2204100 | Summicron f= 9 cm 1:2 | 1966 | 1000 |
2246051 | 2247150 | Summicron f= 9 cm 1:2 | 1967 | 1100 |
2332801 | 2333800 | Summicron f= 9 cm 1:2 | 1969 | 1000 |
2370801 | 2371800 | Summicron f= 9 cm 1:2 | 1969 | 1000 |
2413101 | 2413600 | Summicron f= 9 cm 1:2 | 1970 | 500 |
2499651 | 2500650 | Summicron f= 9 cm 1:2 | 1971 | 1000 |
2731921 | 2731921 | Summicron f= 9 cm 1:2 | 1974 | 1 |
2731922 | 2731950 | Summicron f= 9 cm 1:2 | 1975 | 29 |
2751051 | 2752050 | Summicron f= 9 cm 1:2 | 1975 | 1000 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1953-1975 | 1 |
