R
RAMET | Mask used with RASUK for 10.5 & 13.5 cm lenses | 1933-19?? | - |
RASAL | RAMET + RASUK; for 10.5 & 13.5 cm lenses; black or chrome | 1933-19?? | - |
RASUK | Folding viewfinder for 3.5, 5, 7.3 and 9 cm lenses; black or chrome | 1933-19?? | - |
RDQOO | Reprovit II diaphragm operating lever and guide for lens on ROOXU | 1951-19?? | 16775 |
REDIG-BEEUL | Resistor for 110 volt DC | 19??-19?? | - |
REDUK-BEEUL | Resistor for 220 volt DC | 19??-19?? | - |
REDYX | Regulating transformer for BEECH microscope light | 1934-19?? | - |
REEOD | Universal Copying Device consisting of VAFOO, RESOO, STUOO, GROOW, ZWOOC, UNOOB, TBKOO, LOOCG, LOOFV, LOOGI, LOOHW and LSZOO | 1936-19?? | - |
Reprovit | Copy stand with (II, IIa) or without (I) lights - Models I (ROOSE 1951), II (ROOXU 1951) & IIa (16788 1963) | 1951-1963 | - |
RESOO | Carrying arm with OORES rotating upper stage | 1936-19?? | - |
RFUOO | Regulating transformer for RIOOZ to control light | 1936-19?? | - |
RGWOO | Object stage to flatten books for copying | 1951-19?? | 16786 |
RIFLE | Rifle stock for use with Telyt lenses with long, right-angle eyepiece and double cable release; rare | 1938-1939 | - |
RIOOX | Reprovit II base and column with arm, tape measure and switches | 19??-19?? | - |
RIOOZ | Ring illuminator for Universal Copying Device | 1936-19?? | - |
RKCOO | Reprovit 4-lamp unit | 1951-19?? | 16785 |
ROOAI | Reprovit II focusing stage with bellows | 1951-19?? | 16770 |
ROOAM | Reprovit II focusing stage with bellows with bayonet-mount | 1960-19?? | - |
ROOFU | Reprovit I and Focoslide carrying arm to fit 1 5/8 inch column | 1951-19?? | -68-61-63-69-78 |
ROOKA | Large copying device with VELTU base and column, ROOMB arm, STAFO lighting, VEHIG and STAMA | 1936-19?? | - |
ROOMB | Arm for ROOKA large copying device used with VELTU base and arm | 1936-19?? | - |
ROONP | Copy arm to fit 1 1/4 inch column for Focoslide | 1951-19?? | - |
ROOSE | Reprovit I Universal Copying Device consisting of OVAFO, ROOFU, OOZAB, OUTSO, ZOOXY and VALOO | 19??-19?? | - |
ROOXU | Reprovit II Universal Copying Device consisting of RIOOX, ROOAI, RDQOO, OUTSO, DOOCO and RKCOO | 1951-19?? | 16795, 16794-3/8" bush |
ROOYH | 26 mm repro extension tube | 1951-19?? | -59-78 |
ROSOL | Folding frame, open, chrome viewfinder for 50, 90, 135 mm lenses; early version also included 85 mm lenses; some have feet and meter calibrations for parallax correction | 1951-19?? | 12040 |
ROXUM | Reprovit II for bayonet-mount Leica | 1960-19?? | 16796, 16793-3/8" bush |
RPNOO | Reprovit micro-addaptor for focusing stage with shutter, eyepiece, correction lens and double cable release | 1951-19?? | - |
RPOOT | Reprovit micro-addaptor for focusing stage without shutter, eyepiece or cable release | 1956-19?? | - |
RQPOO | Blue filter; screw-on type L for Summitar f= 5 cm 1:2 | ca.1949 | - |
RSTOO | Reprovit micro-addaptor for focusing stage with shutter, eyepiece, 1/2x correction lens and double cable release | 1951-19?? | |
RTSOO | Reprovit micro-addaptor for focusing stage with 1/2x correction lens but without shutter, eyepiece or cable release | 1956-19?? | - |
RWBOO | Deerskin pouch for RASAL | 1933-19?? | - |
