50mm f/1.4 Summilux-M III
- Leica Order No. 11 856 - 11 868 - 11 869 LLC - 127
- Production era - 1961-2004
- Serial nos. -
- Variants - Black, chrome and titanium versions
- Lens mount - Leica M-bayonet (Screw-mount in limited edition - see Forum discussion [1] [2] [3] below)
- F stop range - f/1.4 > f/16
- Diaphragm setting /type -
- Filter type - E46
- Hood - Built-in telescoping hood
- Accessories -
- Materials - Black anodized aluminum; silver or titanium lacquered brass
- Dimensions (length x diameter) - 54.5 x 47.7 mm / 2.15 x 1.88 in
- Weight - 275 g /9.70 oz in black; 380 g /13.4 oz in silver & titanium
- Inscription - LEICA SUMMILUX 1:1.4/50 E46 388XXXX
- Designer -
50mm f/1.4 Summilux-M III Serial Numbers
| 1844001 | 1846000 | Summilux f= 5 cm 1:1.4 | 1961 | 2000 |
| 1883001 | 1884000 | Summilux f= 5 cm 1:1.4 | 1961 | 1000 |
| 1884101 | 1885000 | Summilux f= 5 cm 1:1.4 | 1961 | 900 |
| 1897001 | 1899000 | Summilux f= 5 cm 1:1.4 | 1961 | 2000 |
| 1927001 | 1929000 | Summilux f= 5 cm 1:1.4 | 1962 | 2000 |
| 1945001 | 1947000 | Summilux f= 5 cm 1:1.4 | 1962 | 2000 |
| 1999999 | 2000001 | Summilux f= 5 cm 1:1.4 | 1963 | 3 |
| 2028001 | 2029000 | Summilux f= 5 cm 1:1.4 | 1964 | 1000 |
| 2039701 | 2040700 | Summilux f= 5 cm 1:1.4 | 1964 | 1000 |
| 2048501 | 2049500 | Summilux f= 5 cm 1:1.4 | 1964 | 1000 |
| 2071501 | 2073500 | Summilux f= 5 cm 1:1.4 | 1964 | 2000 |
| 2198101 | 2199100 | Summilux f= 5 cm 1:1.4 | 1966 | 1000 |
| 2220201 | 2221200 | Summilux f= 5 cm 1:1.4 | 1967 | 1000 |
| 2308251 | 2309750 | Summilux f= 5 cm 1:1.4 | 1968 | 1500 |
| 2345301 | 2347300 | Summilux f= 5 cm 1:1.4 | 1969 | 2000 |
| 2418201 | 2420200 | Summilux f= 5 cm 1:1.4 | 1970 | 2000 |
| 2503101 | 2505100 | Summilux f= 5 cm 1:1.4 | 1972 | 2000 |
| 2568551 | 2570550 | Summilux f= 5 cm 1:1.4 | 1973 | 2000 |
| 2624601 | 2625600 | Summilux f= 5 cm 1:1.4 | 1973 | 1000 |
| 2628051 | 2629600 | Summilux f= 5 cm 1:1.4 | 1973 | 1550 |
| 2821351 | 2822350 | Summilux f= 5 cm 1:1.4 | 1977 | 1000 |
| 2848051 | 2849050 | Summilux f= 5 cm 1:1.4 | 1977 | 1000 |
| 2980551 | 2981000 | Summilux f= 5 cm 1:1.4 | 1979 | 450 |
| 2991701 | 2992700 | Summilux-M f= 5 cm 1:1.4 | 1979 | 1000 |
| 3033901 | 3034400 | Summilux f= 5 cm 1:1.4 | 1980 | 500 |
| 3076301 | 3076800 | Summilux-M f= 5 cm 1:1.4 | 1980 | 500 |
| 3156501 | 3158500 | Summilux f= 5 cm 1:1.4 | 1981 | 2000 |
| 3251101 | 3252100 | Summilux-M f= 5 cm 1:1.4 | 1983 | 1000 |
| 3340201 | 3341200 | Summilux-M f= 5 cm 1:1.4 | 1984 | 1000 |
| 3415891 | 3416890 | Summilux-M f= 5 cm 1:1.4 | 1986 | 1000 |
| 3444901 | 3445900 | Summilux-M f= 5 cm 1:1.4 | 1987 | 1000 |
| 3481901 | 3482900 | Summilux f= 5 cm 1:1.4 | 1989 | 1000 |
| 3483501 | 3484600 | Summilux f= 5 cm 1:1.4 | 1989 | 1100 |
| 3493301 | 3495300 | Summilux f= 5 cm 1:1.4 | 1989 | 2000 |
| 3500000 | 3500000 | Summilux-M f= 5 cm 1:1.4 | 1989 | 1 |
| 3500150 | 3500150 | Summilux-M f= 5 cm 1:1.4 | 1989 | 1 |
| 3588960 | 3590459 | Summilux-M f= 5 cm 1:1.4 | 1992 | 1500 |
| 3653421 | 3653695 | Summilux-M f= 5 cm 1:1.4 | 1994 | 275 |
| 3655716 | 3655821 | Summilux-M f= 5 cm 1:1.4 | 1994 | 106 |
| 3660831 | 3661830 | Summilux-M f= 5 cm 1:1.4 | 1994 | 1000 |
| 3675531 | 3676530 | Summilux-M f= 5 cm 1:1.4 | 1994 | 1000 |
| 3689931 | 3690930 | Summilux-M f= 5 cm 1:1.4 | 1995 | 1000 |
| 3693931 | 3694930 | Summilux-M f= 5 cm 1:1.4 | 1995 | 1000 |
| 3726303 | 3726553 | Summilux-M f= 5 cm 1:1.4 | 1995 | 251 |
| 3760000 | 3760999 | Summilux-M f= 5 cm 1:1.4 | 1996 | 1000 |
| 3772930 | 3773929 | Summilux-M f= 5 cm 1:1.4 | 1997 | 1000 |
| 3868267 | 3868616 | Summilux-M f= 5 cm 1:1.4 | 1999 | 350 |
| 3870167 | 3871166 | Summilux-M f= 5 cm 1:1.4 | 1999 | 1000 |
| 3877167 | 3877466 | Summilux-M f= 5 cm 1:1.4 | 1999 | 300 |
| 3881947 | 3882246 | Summilux-M f= 5 cm 1:1.4 | 1999 | 300 |
| 3929514 | 3930513 | Summilux-M M1 f= 5 cm 1:1.4 | 2001 | 1000 |
| 3964511 | 3965510 | Summilux-M M1 f= 5 cm 1:1.4 | 2003 | 1000 |
| 3977089 | 3977588 | Summilux-M M1 f= 5 cm 1:1.4 | 2004 | 500 |
| 3979589 | 3980088 | Summilux-M M1 f= 5 cm 1:1.4 | 2004 | 500 |
| 3982051 | 3982550 | Summilux-M M1 Titan 5 cm 1:1.4 | 2004 | 500 |
| 3982551 | 3983050 | Summilux-M M1 Schw 5 cm 1:1.4 | 2004 | 500 |
| 3985034 | 3985533 | Summilux-M f= 5 cm 1:1.4 | 2004 | 500 |
| 3988719 | 3989218 | Summilux-M f= 5 cm 1:1.4 | 2005 | 500 |
| 3990069 | 3991118 | Summilux-M f= 5 cm 1:1.4 | 2005 | 1050 |
| 3991869 | 3992870 | Summilux-M f= 5 cm 1:1.4 | 2005 | 1000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1961-2006 | 1 |
