Elmar (II) f= 9 cm 1:4
- Leica Order No. - ELANG LLC -
- Production era - 1933-1948
- Variants - Black and chrome
- F stop range - f/4 > f/36
- Smallest object field -
- Diaphragm setting /type -
- Filter type - E39
- Accessories - Viewfinder: SOOUT - Case: ETINI
- Materials -
- Weight - 250 g /0.55 lb
- Inscription - Elmar f=9cm 1:4 No6xxxxx Ernst Leitz Wetzler
Elmar (II) f= 9 cm 1:4 Serial Numbers
165001 | 166000 | Elmar 90 mm 1:40 | 1933 | 1000 |
177001 | 178000 | Elmar 90 mm 1:4 | 1933 | 1000 |
220101 | 222000 | Elmar 90 mm 1:40 | 1934 | 1900 |
260001 | 261000 | Elmar 90 mm 1:4 | 1935 | 1000 |
283551 | 284500 | Elmar 90 mm 1:4 | 1935 | 950 |
295001 | 297000 | Elmar 90 mm 1:4 | 1936 | 2000 |
320001 | 322000 | Elmar 90 mm 1:40 | 1936 | 2000 |
355001 | 356000 | Elmar 90 mm 1:4 | 1937 | 1000 |
372001 | 375000 | Elmar 90 mm 1:40 | 1937 | 3000 |
411001 | 415000 | Elmar 90 mm 1:40 | 1937 | 4000 |
453001 | 460000 | Elmar 90 mm 1:40 | 1938 | 7000 |
516001 | 520000 | Elmar 90 mm 1:40 | 1939 | 4000 |
556001 | 557000 | Elmar 90 mm 1:40 | 1940 | 1000 |
565001 | 566000 | Elmar 90 mm 1:40 | 1941 | 1000 |
575001 | 575200 | Elmar 90 mm 1:40 | 1941 | 200 |
576201 | 577000 | Elmar 90 mm 1:40 | 1941 | 800 |
583501 | 583682 | Elmar 90 mm 1:40 | 1942 | 182 |
590001 | 590200 | Elmar 90 mm 1:40 | 1942 | 200 |
592001 | 593000 | Elmar 90 mm 1:40 | 1942 | 1000 |
596001 | 597000 | Elmar 90 mm 1:40 | 1945 | 1000 |
606001 | 607000 | Elmar 90 mm 1:40 | 1946 | 1000 |
615001 | 616000 | Elmar 90 mm 1:40 | 1946 | 1000 |
633001 | 633100 | Elmar 90 mm 1:40 | 1947 | 100 |
635001 | 637000 | Elmar 90 mm 1:40 | 1947 | 2000 |
645001 | 647000 | Elmar 90 mm 1:40 | 1947 | 2000 |
657001 | 677000 | Elmar 90 mm 1:40 | 1948 | 20000 |
696001 | 699000 | Elmar 90 mm 1:40 | 1949 | 3000 |
718001 | 721000 | Elmar 90 mm 1:40 | 1949 | 3000 |
756001 | 760000 | Elmar 90 mm 1:40 | 1950 | 4000 |
807001 | 810000 | Elmar 90 mm 1:40 | 1950 | 3000 |
836001 | 840000 | Elmar 90 mm 1:40 | 1950 | 4000 |
872001 | 880000 | Elmar 90 mm 1:40 | 1951 | 8000 |
958001 | 959000 | Elmar 90 mm 1:40 | 1952 | 1000 |
960001 | 965000 | Elmar 90 mm 1:40 | 1952 | 5000 |
967001 | 972000 | Elmar 90 mm 1:40 | 1952 | 5000 |
1010001 | 1010200 | Elmar 90 mm 1:40 | 1952 | 200 |
1035001 | 1040000 | Elmar 90 mm 1:40 | 1952 | 5000 |
1080001 | 1083000 | Elmar 90 mm 1:40 | 1953 | 3000 |
1111001 | 1113385 | Elmar 90 mm 1:40 | 1953 | 2385 |
1113438 | 1114000 | Elmar 90 mm 1:40 | 1953 | 563 |
1137001 | 1140000 | Elmar 90 mm 1:40 | 1954 | 3000 |
1160501 | 1163000 | Elmar 90 mm 1:40 | 1954 | 2500 |
1171001 | 1171500 | Elmar 90 mm 1:40 | 1954 | 500 |
1178001 | 1178500 | Elmar 90 mm 1:40 | 1954 | 500 |
1182001 | 1183500 | Elmar 90 mm 1:40 | 1954 | 1500 |
1188001 | 1190000 | Elmar 90 mm 1:40 | 1954 | 2000 |
1212001 | 1214000 | Elmar 90 mm 1:40 | 1954 | 2000 |
1224001 | 1224200 | Elmar 90 mm 1:40 | 1954 | 200 |
1236001 | 1238000 | Elmar 90 mm 1:40 | 1955 | 2000 |
1241001 | 1242000 | Elmar 90 mm 1:40 | 1955 | 1000 |
1247001 | 1250000 | Elmar 90 mm 1:40 | 1955 | 3000 |
1260001 | 1263000 | Elmar 90 mm 1:40 | 1955 | 3000 |
1271001 | 1272000 | Elmar 90 mm 1:40 | 1955 | 1000 |
1291001 | 1293000 | Elmar 90 mm 1:40 | 1955 | 2000 |
1309001 | 1311000 | Elmar 90 mm 1:40 | 1955 | 2000 |
1337001 | 1340000 | Elmar 90 mm 1:40 | 1956 | 3000 |
1353001 | 1356000 | Elmar 90 mm 1:40 | 1956 | 3000 |
1380001 | 1383000 | Elmar 90 mm 1:40 | 1956 | 3000 |
1386001 | 1389000 | Elmar 90 mm 1:40 | 1956 | 3000 |
1409001 | 1412000 | Elmar 90 mm 1:40 | 1956 | 3000 |
1459001 | 1465000 | Elmar 90 mm 1:40 | 1957 | 6000 |
1481701 | 1483700 | Elmar 90 mm 1:40 | 1957 | 2000 |
1491001 | 1494000 | Elmar 90 mm 1:40 | 1957 | 3000 |
1497001 | 1499000 | Elmar 90 mm 1:40 | 1957 | 2000 |
1503501 | 1506000 | Elmar 90 mm 1:40 | 1957 | 2500 |
1521001 | 1524000 | Elmar 90 mm 1:40 | 1957 | 3000 |
1547001 | 1548000 | Elmar 90 mm 1:40 | 1957 | 1000 |
1558001 | 1559000 | Elmar 90 mm 1:40 | 1958 | 1000 |
1572001 | 1574000 | Elmar 90 mm 1:40 | 1958 | 2000 |
1585071 | 1585075 | Elmar 90 mm 1:40 | 1958 | 5 |
1603001 | 1604000 | Elmar 90 mm 1:40 | 1958 | 1000 |
1630001 | 1630500 | Elmar 90 mm 1:40 | 1958 | 500 |
1700001 | 1701000 | Elmar 90 mm 1:40 | 1959 | 1000 |
1712001 | 1714000 | Elmar 90 mm 1:40 | 1959 | 2000 |
1725001 | 1727000 | Elmar 90 mm 1:40 | 1960 | 2000 |
1766201 | 1768000 | Elmar 90 mm 1:40 | 1960 | 1800 |
1822001 | 1823000 | Elmar 90 mm 1:40 | 1960 | 1000 |
1827001 | 1830000 | Elmar 90 mm 1:40 | 1961 | 3000 |
1913001 | 1914000 | Elmar 90 mm 1:40 | 1962 | 1000 |
1920001 | 1921000 | Elmar 90 mm 1:40 | 1962 | 1000 |
1936001 | 1937000 | Elmar 90 mm 1:40 | 1962 | 1000 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1933-1962 | 1 |
