Elmar (II) f= 9 cm 1:4
  • Leica Order No. - ELANG LLC -
  • Production era - 1933-1948
  • Variants - Black and chrome
  • Lens mount - Leica Screw-thread
  • Number of lenses /groups - 4 /3
  • F stop range - f/4 > f/36
  • Smallest object field -
  • Diaphragm setting /type -
  • Angle of view diagonal - 27 degrees
  • Filter type - E39
  • Accessories - Viewfinder: SOOUT - Case: ETINI
  • Materials -
  • Weight - 250 g /0.55 lb
  • Inscription - Elmar f=9cm 1:4 No6xxxxx Ernst Leitz Wetzler
  • Forum discussion
Elmar (II) f= 9 cm 1:4 Serial Numbers
165001 166000 Elmar 90 mm 1:40 1933 1000
177001 178000 Elmar 90 mm 1:4 1933 1000
220101 222000 Elmar 90 mm 1:40 1934 1900
260001 261000 Elmar 90 mm 1:4 1935 1000
283551 284500 Elmar 90 mm 1:4 1935 950
295001 297000 Elmar 90 mm 1:4 1936 2000
320001 322000 Elmar 90 mm 1:40 1936 2000
355001 356000 Elmar 90 mm 1:4 1937 1000
372001 375000 Elmar 90 mm 1:40 1937 3000
411001 415000 Elmar 90 mm 1:40 1937 4000
453001 460000 Elmar 90 mm 1:40 1938 7000
516001 520000 Elmar 90 mm 1:40 1939 4000
556001 557000 Elmar 90 mm 1:40 1940 1000
565001 566000 Elmar 90 mm 1:40 1941 1000
575001 575200 Elmar 90 mm 1:40 1941 200
576201 577000 Elmar 90 mm 1:40 1941 800
583501 583682 Elmar 90 mm 1:40 1942 182
590001 590200 Elmar 90 mm 1:40 1942 200
592001 593000 Elmar 90 mm 1:40 1942 1000
596001 597000 Elmar 90 mm 1:40 1945 1000
606001 607000 Elmar 90 mm 1:40 1946 1000
615001 616000 Elmar 90 mm 1:40 1946 1000
633001 633100 Elmar 90 mm 1:40 1947 100
635001 637000 Elmar 90 mm 1:40 1947 2000
645001 647000 Elmar 90 mm 1:40 1947 2000
657001 677000 Elmar 90 mm 1:40 1948 20000
696001 699000 Elmar 90 mm 1:40 1949 3000
718001 721000 Elmar 90 mm 1:40 1949 3000
756001 760000 Elmar 90 mm 1:40 1950 4000
807001 810000 Elmar 90 mm 1:40 1950 3000
836001 840000 Elmar 90 mm 1:40 1950 4000
872001 880000 Elmar 90 mm 1:40 1951 8000
958001 959000 Elmar 90 mm 1:40 1952 1000
960001 965000 Elmar 90 mm 1:40 1952 5000
967001 972000 Elmar 90 mm 1:40 1952 5000
1010001 1010200 Elmar 90 mm 1:40 1952 200
1035001 1040000 Elmar 90 mm 1:40 1952 5000
1080001 1083000 Elmar 90 mm 1:40 1953 3000
1111001 1113385 Elmar 90 mm 1:40 1953 2385
1113438 1114000 Elmar 90 mm 1:40 1953 563
TOTAL ASSIGNED SERIAL NUMBERS 1933-1953 107,480
