35mm f/2 Summicron-M IV
Revision as of 14:51, 4 March 2010 by Admin (talk | contribs)
  • Leica Order No. - 11 310 - 11 311 LLC - 154
  • Production era - 1969-1997 < 51,843 lenses
  • Variants - Yellow /white scale; red /white scale; black and silver versions
  • F stop range - f/2-f/16
  • Closest focusing distance - 0.7 m /2.30 ft
  • Smallest object field - 430 x 640 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 64 degrees
  • Filter type - E39
  • Accessories - Hood: 12524
  • Materials - Black lacquered alloy or silver lacquered brass
  • Dimensions length x diameter - 26 x 52 mm / 1.02 x 2.05 in
  • Weight - 160 g /5.64 oz; 260 g /9.17 oz in lacquered brass
  • Inscription - LEITZ LENS MADE IN CANADA SUMMICRON-M 1:2/35 or LEITZ SUMMICRON-M 1:2/35 E39 3XXXXXX
  • Designer - Walter Mandler
  • Forum discussion
35 mm f/2 Summicron-M IV Serial Numbers
2974251 2976250 Summicron-M 3.5 cm 1:2 1979 2000
3017751 3019750 Summicron-M 3.5 cm 1:2 1980 2000
3061301 3063300 Summicron-M 3.5 cm 1:2 1980 2000
3115701 3116700 Summicron-M 3.5 cm 1:2 1981 1000
3145501 3146500 Summicron-M 3.5 cm 1:2 1981 1000
3165001 3166000 Summicron-M 3.5 cm 1:2 1982 1000
3181201 3183200 Summicron-M 3.5 cm 1:2 1982 2000
3240501 3241700 Summicron-M 3.5 cm 1:2 1982 1200
3306201 3308200 Summicron-M 3.5 cm 1:2 1984 2000
3354801 3356800 Summicron-M 3.5 cm 1:2 1985 2000
3395601 3397600 Summicron-M 3.5 cm 1:2 1986 2000
3416891 3418890 Summicron-M 3.5 cm 1:2 1986 2000
3440001 3441000 Summicron-M 3.5 cm 1:2 1987 1000
3453071 3454070 Summicron-M 3.5 cm 1:2 1987 1000
3456871 3457370 Summicron-M 3.5 cm 1:2 1988 500
3465071 3466070 Summicron-M 3.5 cm 1:2 1988 1000
3485401 3486400 Summicron-M 3.5 cm 1:2 1989 1000
3495661 3495900 Summicron-M 3.5 cm 1:2 1989 240
3505151 3506150 Summicron-M 3.5 cm 1:2 1990 1000
3507996 3508995 Summicron-M 3.5 cm 1:2 1990 1000
3521296 3523295 Summicron-M 3.5 cm 1:2 1990 2000
3553468 3555467 Summicron-M 3.5 cm 1:2 1991 2000
3577534 3579533 Summicron-M 3.5 cm 1:2 1991 2000
3590460 3592459 Summicron-M 3.5 cm 1:2 1992 2000
3603670 3606169 Summicron-M 3.5 cm 1:2 1992 2500
3610980 3613479 Summicron-M 3.5 cm 1:2 1993 2500
3617895 3617897 Summicron-M 3.5 cm 1:2 1993 3
3637926 3639725 Summicron-M 3.5 cm 1:2 1993 1800
3639726 3641425 Summicron-M 3.5 cm 1:2 1993 1700
3681531 3683730 Summicron-M 3.5 cm 1:2 1995 2200
3683731 3684930 Summicron-M 3.5 cm 1:2 1995 1200
3712903 3715402 Summicron-M 3.5 cm 1:2 1995 2500
3715403 3717902 Summicron-M 3.5 cm 1:2 1995 2500
TOTAL ASSIGNED SERIAL NUMBERS 1979-1995 51,843
