50mm f/2 Summicron-M
Revision as of 16:33, 4 March 2010 by Admin (talk | contribs) (→50mm f/2 Summicron-M Serial Numbers)
- Leica Order No. - 11819, 11826, 11825, 11816, 11624 LLC - 123
- Era - 1979-Current
- Variants - Black Serial Nos. 2,974,251 to ? - Chrome Serial Nos. 2,909,101- ? 500 Titanium Serial Nos. - Coded after Serial No. - pre-1984 have focus tab
- Lens mount - Leica M quick-change bayonet (Screw-mount in 1999 limited edition - see Forum discussion [1] [2] [3] below)
- Number of lenses/groups - 6/4
- Focusing range - 0.7 m / 2.3 ft < ∞
- Aperture - 2 > 16 - with clickstops (including half values), manual diaphragm
- Smallest object field/Largest reproduction ratio - 277 mm x 416 mm / 1:11.5
- Angle of view (diagonal, horizontal, vertical) - 47°, 40°, 27°
- Position of entrance pupil - 25.1 mm (related to the first lens surface in light direction)
- Filter mount/Lens hood - Internal thread for screw-in filters size E39 / built-in, telescopic
- Accessories -
- Materials - Black anodized aluminum; silver or titanium lacquered brass
- Focal length - 52.3 mm / 2 in
- Length to bayonet flange - 43.5 mm / 1.7 in
- Largest diameter - 53 mm / 2.1 in
- Weight - approx. 240 g - 8.5 oz / 335 g - 11.8 oz (black anodized- / silver or titanium finish)
- Inscription - LEICA SUMMICRON-M 1:2/50 E39 (Serial No.)
- On the street - $US 1,795.00 in 2008
- Designer - Walter Mandler
| 2822351 | 2826350 | Summicron-M f= 5 cm 1:2 | 1977 | 4000 |
| 2909101 | 2913100 | Summicron-M f= 5 cm 1:2 | 1978 | 4000 |
| 2915801 | 2916800 | Summicron-M f= 5 cm 1:2 | 1978 | 1000 |
| 2922901 | 2926900 | Summicron-M f= 5 cm 1:2 | 1978 | 4000 |
| 2985101 | 2987100 | Summicron-M f= 5 cm 1:2 | 1979 | 2000 |
| 3019751 | 3022750 | Summicron-M f= 5 cm 1:2 | 1980 | 3000 |
| 3082001 | 3084000 | Summicron-M f= 5 cm 1:2 | 1980 | 2000 |
| 3098501 | 3101500 | Summicron-M f= 5 cm 1:2 | 1981 | 3000 |
| 3166001 | 3168000 | Summicron-M f= 5 cm 1:2 | 1982 | 2000 |
| 3198701 | 3199700 | Summicron-M f= 5 cm 1:2 | 1982 | 1000 |
| 3235301 | 3236300 | Summicron-M f= 5 cm 1:2 | 1982 | 1000 |
| 3261401 | 3263400 | Summicron-M f= 5 cm 1:2 | 1983 | 2000 |
| 3357801 | 3359800 | Summicron-M f= 5 cm 1:2 | 1985 | 2000 |
| 3359801 | 3360800 | Summicron-M f= 5 cm 1:2 | 1985 | 1000 |
| 3381701 | 3383200 | Summicron-M f= 5 cm 1:2 | 1985 | 1500 |
| 3408891 | 3409890 | Summicron-M f= 5 cm 1:2 | 1986 | 1000 |
| 3435501 | 3436500 | Summicron-M f= 5 cm 1:2 | 1987 | 1000 |
| 3445921 | 3446920 | Summicron-M f= 5 cm 1:2 | 1987 | 1000 |
| 3447921 | 3449920 | Summicron-M f= 5 cm 1:2 | 1987 | 2000 |
| 3449921 | 3451920 | Summicron-M f= 5 cm 1:2 | 1987 | 2000 |
| 3454071 | 3455070 | Summicron-M f= 5 cm 1:2 | 1987 | 1000 |
| 3470821 | 3471820 | Summicron-M f= 5 cm 1:2 | 1988 | 1000 |
| 3480601 | 3481600 | Summicron-M f= 5 cm 1:2 | 1988 | 1000 |
| 3488651 | 3488790 | Summicron-M f= 5 cm 1:2 | 1989 | 140 |
| 3501701 | 3502700 | Summicron-M f= 5 cm 1:2 | 1989 | 1000 |
| 3502701 | 3503150 | Summicron-M f= 5 cm 1:2 | 1989 | 450 |
| 3506151 | 3507150 | Summicron-M f= 5 cm 1:2 | 1990 | 1000 |
| 3514796 | 3516295 | Summicron-M f= 5 cm 1:2 | 1990 | 1500 |
| 3540468 | 3542467 | Summicron-M f= 5 cm 1:2 | 1991 | 2000 |
| 3571133 | 3573132 | Summicron-M f= 5 cm 1:2 | 1991 | 2000 |
| 3587960 | 3588959 | Summicron-M f= 5 cm 1:2 | 1992 | 1000 |
| 3592460 | 3593959 | Summicron-M f= 5 cm 1:2 | 1992 | 1500 |
| 3597020 | 3598519 | Summicron-M f= 5 cm 1:2 | 1992 | 1500 |
| 3598520 | 3598819 | Summicron-M f= 5 cm 1:2 | 1992 | 300 |
| 3606170 | 3606719 | Summicron-M f= 5 cm 1:2 | 1992 | 550 |
| 3613480 | 3614479 | Summicron-M f= 5 cm 1:2 | 1993 | 1000 |
| 3617903 | 3618902 | Summicron-M f= 5 cm 1:2 | 1993 | 1000 |
| 3620133 | 3621632 | Summicron-M f= 5 cm 1:2 | 1993 | 1500 |
| 3623601 | 3623800 | Summicron-M f= 5 cm 1:2 | 1993 | 200 |
| 3630001 | 3631900 | Summicron-M f= 5 cm 1:2 | 1993 | 1900 |
| 3649976 | 3651975 | Summicron-M f= 5 cm 1:2 | 1994 | 2000 |
| 3654716 | 3655715 | Summicron-M f= 5 cm 1:2 | 1994 | 1000 |
| 3663831 | 3664830 | Summicron-M f= 5 cm 1:2 | 1994 | 1000 |
| 3669031 | 3670030 | Summicron-M f= 5 cm 1:2 | 1994 | 1000 |
| 3679031 | 3680030 | Summicron-M f= 5 cm 1:2 | 1995 | 1000 |
| 3695000 | 3695700 | Summicron-M f= 5 cm 1:2 | 1995 | 701 |
| 3700001 | 3700301 | Summicron-M f= 5 cm 1:2 | 1995 | 301 |
| 3705803 | 3707802 | Summicron-M f= 5 cm 1:2 | 1995 | 2000 |
| 3729001 | 3729150 | Summicron-M f= 5 cm 1:2 | 1995 | 150 |
| 3731301 | 3732300 | Summicron-M f= 5 cm 1:2 | 1996 | 1000 |
| 3741212 | 3741212 | Summicron-M f= 5 cm 1:2 | 1996 | 1 |
| 3746589 | 3747588 | Summicron-M f= 5 cm 1:2 | 1996 | 1000 |
| 3756036 | 3757035 | Summicron-M f= 5 cm 1:2 | 1996 | 1000 |
| 3766100 | 3767099 | Summicron-M f= 5 cm 1:2 | 1996 | 1000 |
| 3791010 | 3792009 | Summicron-M f= 5 cm 1:2 | 1997 | 1000 |
| 3802410 | 3803409 | Summicron-M f= 5 cm 1:2 | 1997 | 1000 |
| 3817625 | 3818624 | Summicron-M f= 5 cm 1:2 | 1997 | 1000 |
| 3828825 | 3829824 | Summicron-M f= 5 cm 1:2 | 1998 | 1000 |
| 3842500 | 3843499 | Summicron-M f= 5 cm 1:2 | 1998 | 1000 |
| 3852100 | 3853099 | Summicron-M f= 5 cm 1:2 | 1998 | 1000 |
| 3862417 | 3863416 | Summicron-M f= 5 cm 1:2 | 1999 | 1000 |
| 3867167 | 3867716 | Summicron-M f= 5 cm 1:2 | 1999 | 550 |
| 3877467 | 3878466 | Summicron-M f= 5 cm 1:2 | 1999 | 1000 |
| 3880377 | 3880746 | Summicron-M f= 5 cm 1:2 | 1999 | 370 |
| 3883747 | 3884746 | Summicron-M f= 5 cm 1:2 | 2000 | 1000 |
| 3884747 | 3884906 | Summicron-M f= 5 cm 1:2 | 2000 | 160 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1977-2006 | 85,273 |
