50mm f/1.4 Summilux-M II
  • Leica Order No. - 11 113 black, 11 114 chrome LLC - 127
  • Production era - 1966-1995 Serial Numbers: 1844001-
  • Variants - Black and chrome versions
  • F stop range - f/1.4-f/16
  • Closest focusing distance - 1 m /3.28 ft
  • Smallest object field - 277 x 416 mm
  • Diaphragm setting /type -
  • Filter type - E43
  • Accessories - Hood: 12586
  • Materials - Black anodized aluminum or chrome plated brass
  • Dimensions (length x diameter) - 54.5 x 47.7 mm /
  • Weight - 275 g aluminum, 380 g chrome
  • Inscription - LEITZ WETZLAR SUMMILUX 1:1.4/50 E46 388XXXX
  • Designer - Walter Mandler
  • Forum discussion
  • Reviews
50mm f/1.4 Summilux-M II Serial Numbers
1844001 1846000 Summilux f= 5 cm 1:1.4 1961 2000
1883001 1884000 Summilux f= 5 cm 1:1.4 1961 1000
1884101 1885000 Summilux f= 5 cm 1:1.4 1961 900
1897001 1899000 Summilux f= 5 cm 1:1.4 1961 2000
1927001 1929000 Summilux f= 5 cm 1:1.4 1962 2000
1945001 1947000 Summilux f= 5 cm 1:1.4 1962 2000
1999999 2000001 Summilux f= 5 cm 1:1.4 1963 3
2028001 2029000 Summilux f= 5 cm 1:1.4 1964 1000
2039701 2040700 Summilux f= 5 cm 1:1.4 1964 1000
2048501 2049500 Summilux f= 5 cm 1:1.4 1964 1000
2071501 2073500 Summilux f= 5 cm 1:1.4 1964 2000
2198101 2199100 Summilux f= 5 cm 1:1.4 1966 1000
2220201 2221200 Summilux f= 5 cm 1:1.4 1967 1000
2308251 2309750 Summilux f= 5 cm 1:1.4 1968 1500
2345301 2347300 Summilux f= 5 cm 1:1.4 1969 2000
2418201 2420200 Summilux f= 5 cm 1:1.4 1970 2000
2503101 2505100 Summilux f= 5 cm 1:1.4 1972 2000
2568551 2570550 Summilux f= 5 cm 1:1.4 1973 2000
2624601 2625600 Summilux f= 5 cm 1:1.4 1973 1000
2628051 2629600 Summilux f= 5 cm 1:1.4 1973 1550
2821351 2822350 Summilux f= 5 cm 1:1.4 1977 1000
2848051 2849050 Summilux f= 5 cm 1:1.4 1977 1000
2980551 2981000 Summilux f= 5 cm 1:1.4 1979 450
2991701 2992700 Summilux-M f= 5 cm 1:1.4 1979 1000
3033901 3034400 Summilux f= 5 cm 1:1.4 1980 500
3076301 3076800 Summilux-M f= 5 cm 1:1.4 1980 500
3156501 3158500 Summilux f= 5 cm 1:1.4 1981 2000
3251101 3252100 Summilux-M f= 5 cm 1:1.4 1983 1000
3340201 3341200 Summilux-M f= 5 cm 1:1.4 1984 1000
3415891 3416890 Summilux-M f= 5 cm 1:1.4 1986 1000
3444901 3445900 Summilux-M f= 5 cm 1:1.4 1987 1000
3481901 3482900 Summilux f= 5 cm 1:1.4 1989 1000
3483501 3484600 Summilux f= 5 cm 1:1.4 1989 1100
3493301 3495300 Summilux f= 5 cm 1:1.4 1989 2000
3500000 3500000 Summilux-M f= 5 cm 1:1.4 1989 1
3500150 3500150 Summilux-M f= 5 cm 1:1.4 1989 1
3588960 3590459 Summilux-M f= 5 cm 1:1.4 1992 1500
3653421 3653695 Summilux-M f= 5 cm 1:1.4 1994 275
3655716 3655821 Summilux-M f= 5 cm 1:1.4 1994 106
3660831 3661830 Summilux-M f= 5 cm 1:1.4 1994 1000
3675531 3676530 Summilux-M f= 5 cm 1:1.4 1994 1000
3689931 3690930 Summilux-M f= 5 cm 1:1.4 1995 1000
3693931 3694930 Summilux-M f= 5 cm 1:1.4 1995 1000
3726303 3726553 Summilux-M f= 5 cm 1:1.4 1995 251
3760000 3760999 Summilux-M f= 5 cm 1:1.4 1996 1000
3772930 3773929 Summilux-M f= 5 cm 1:1.4 1997 1000
3868267 3868616 Summilux-M f= 5 cm 1:1.4 1999 350
3870167 3871166 Summilux-M f= 5 cm 1:1.4 1999 1000
3877167 3877466 Summilux-M f= 5 cm 1:1.4 1999 300
3881947 3882246 Summilux-M f= 5 cm 1:1.4 1999 300
3929514 3930513 Summilux-M M1 f= 5 cm 1:1.4 2001 1000
3964511 3965510 Summilux-M M1 f= 5 cm 1:1.4 2003 1000
3977089 3977588 Summilux-M M1 f= 5 cm 1:1.4 2004 500
3979589 3980088 Summilux-M M1 f= 5 cm 1:1.4 2004 500
3982051 3982550 Summilux-M M1 Titan 5 cm 1:1.4 2004 500
3982551 3983050 Summilux-M M1 Schw 5 cm 1:1.4 2004 500
3985034 3985533 Summilux-M f= 5 cm 1:1.4 2004 500
3988719 3989218 Summilux-M f= 5 cm 1:1.4 2005 500
3990069 3991118 Summilux-M f= 5 cm 1:1.4 2005 1050
3991869 3992870 Summilux-M f= 5 cm 1:1.4 2005 1000
TOTAL ASSIGNED SERIAL NUMBERS 1961-2006 1
