90mm f/2 ASPH Apo-Summicron-M
Revision as of 15:28, 9 March 2010 by Admin (talk | contribs)
  • Leica Order No. - 11 884 - 11 632 LLC - 177
  • Production era - 1998-Current 13,600+ lenses
  • Lens mount - Leica M quick-change bayonet
  • Variants - Black or titanium versions
  • Number of lenses/groups - 5 /5
  • Focusing range - 1 m / 3.3 ft < ∞
  • Aperture - f/2-f/16 - Setting/Function Preset, with click-stops, half values available, manual diaphragm
  • Smallest object field/Largest reproduction ratio - 220 mm x 330 mm / 1:9
  • Angle of view (diagonal, horizontal, vertical) - 27°, 23°, 15°
  • Position of entrance pupil - 58.6 mm (related to the first lens surface in light direction)
  • Filter mount/Lens hood - Internal thread for screw-in filters size E55 / built-in, telescopic
  • Materials - Anodized aluminum and optical glass
  • Focal length - 90.9 mm / 3.6 in
  • Length to bayonet flange - 78 mm / 3.1 in
  • Largest diameter - 64 mm / 2.5 in
  • Weight - 660 g / 1.46 lb
  • Inscription - APO SUMMICRON-M 1:2/90 ASPH.
90mm f/2 ASPH Apo-Summicron-M Serial Numbers
3815625 3817624 90mm f/2 ASPH Apo-Summicron-M 1997 2000
3856300 3856799 90mm f/2 ASPH Apo-Summicron-M 1998 500
3866167 3867166 90mm f/2 ASPH Apo-Summicron-M 1999 1000
3875167 3876166 90mm f/2 ASPH Apo-Summicron-M 1999 1000
3880947 3881946 90mm f/2 ASPH Apo-Summicron-M 1999 1000
3890507 3890956 90mm f/2 ASPH Apo-Summicron-M 2000 450
3891151 3891700 90mm f/2 ASPH Apo-Summicron-M 2000 550
3893351 3894350 90mm f/2 ASPH Apo-Summicron-M 2000 1000
3.918.271 3.918.770 90mm f/2 ASPH Apo-Summicron-M 2001 500
3.923.671 3.924.670 90mm f/2 ASPH Apo-Summicron-M 2001 1000
3.932.014 3.933.013 90mm f/2 ASPH Apo-Summicron-M 2001 1000
3.943.114 3.944.113 90mm f/2 ASPH Apo-Summicron-M 2002 1000
3.954.811 3.955.810 90mm f/2 ASPH Apo-Summicron-M 2002 1000
3.959.911 3.960.210 90mm f/2 ASPH Apo-Summicron-M 2002 300
3.961.211 3.961.510 90mm f/2 ASPH Apo-Summicron-M 2003 300
3.965.511 3.966.510 90mm f/2 ASPH Apo-Summicron-M 2003 1000
unknown unknown 90mm f/2 ASPH Apo-Summicron-M 2006-2010 unknown
TOTAL ASSIGNED SERIAL NUMBERS 1997-2005 13,600
