90mm f/2.8 Elmarit-R I
- Leica Order No. - 11 239 / 11 229 LLC - 172
- Production era - 1964-1983 < 29,000 lenses
- Variants - 1-cam, 2-cam and 3-cam versions
- F stop range - f/2.8-f/22
- Closest focusing distance - 70 cm / 2.30 ft
- Smallest object field - 140 x 210 mm
- Diaphragm setting /type -
- Filter type - E55 Series 7 + 14161
- Accessories - ELPRO close focusing attachment
- Materials -
- Dimensions length x diameter - 72 x 65 mm / 2.83 x 2.56 in
- Weight - 500 g /1.1 lb
- Inscription - ELMARIT-R 1:2.8/90 LEITZ CANADA 2XXXXXX
- Designer - Walter Mandler
- On the street - €EU 240 in 2008
90mm f/2.8 Elmarit-R I Serial Numbers
1965001 | 1966000 | 90mm f/2.8 Elmarit-R | 1962 | 1000 |
2011701 | 2013700 | 90mm f/2.8 Elmarit-R | 1963 | 2000 |
2077501 | 2078500 | 90mm f/2.8 Elmarit-R | 1965 | 1000 |
2094501 | 2095500 | 90mm f/2.8 Elmarit-R | 1965 | 1000 |
2108801 | 2110800 | 90mm f/2.8 Elmarit-R | 1965 | 2000 |
2129951 | 2131950 | 90mm f/2.8 Elmarit-R | 1965 | 2000 |
2148551 | 2150550 | 90mm f/2.8 Elmarit-R | 1965 | 2000 |
2170701 | 2171700 | 90mm f/2.8 Elmarit-R | 1966 | 1000 |
2208101 | 2210100 | 90mm f/2.8 Elmarit-R | 1966 | 2000 |
2267251 | 2269250 | 90mm f/2.8 Elmarit-R | 1968 | 2000 |
2333801 | 2335800 | 90mm f/2.8 Elmarit-R | 1969 | 2000 |
2374901 | 2376900 | 90mm f/2.8 Elmarit-R | 1969 | 2000 |
2414101 | 2416100 | 90mm f/2.8 Elmarit-R | 1970 | 2000 |
2442001 | 2444000 | 90mm f/2.8 Elmarit-R | 1970 | 2000 |
2536251 | 2538250 | 90mm f/2.8 Elmarit-R | 1972 | 2000 |
2734951 | 2735950 | 90mm f/2.8 Elmarit-R | 1975 | 1000 |
2807401 | 2809400 | 90mm f/2.8 Elmarit-R | 1976 | 2000 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1962-1976 | 29,000 |
