35mm f/2 Summicron-M IV
- Leica Order No. - 11 310 - 11 311 LLC - 154
- Production era - 1969-1999 < 52,993 lenses
- Variants - Yellow /white scale; red /white scale; black and silver versions
- F stop range - f/2-f/16
- Smallest object field - 430 x 640 mm
- Diaphragm setting /type -
- Angle of view diagonal - 64 degrees
- Filter type - E39
- Accessories - Hood: 12524
- Materials - Black lacquered alloy or silver lacquered brass
- Dimensions length x diameter - 26 x 52 mm / 1.02 x 2.05 in
- Weight - 160 g /5.64 oz; 260 g /9.17 oz in lacquered brass
- Inscription - LEITZ LENS MADE IN CANADA SUMMICRON-M 1:2/35 or LEITZ SUMMICRON-M 1:2/35 E39 3XXXXXX
- Designer - Walter Mandler
35 mm f/2 Summicron-M IV Serial Numbers
| 2974251 | 2976250 | Summicron-M 3.5 cm 1:2 | 1979 | 2000 |
| 3017751 | 3019750 | Summicron-M 3.5 cm 1:2 | 1980 | 2000 |
| 3061301 | 3063300 | Summicron-M 3.5 cm 1:2 | 1980 | 2000 |
| 3115701 | 3116700 | Summicron-M 3.5 cm 1:2 | 1981 | 1000 |
| 3145501 | 3146500 | Summicron-M 3.5 cm 1:2 | 1981 | 1000 |
| 3165001 | 3166000 | Summicron-M 3.5 cm 1:2 | 1982 | 1000 |
| 3181201 | 3183200 | Summicron-M 3.5 cm 1:2 | 1982 | 2000 |
| 3240501 | 3241700 | Summicron-M 3.5 cm 1:2 | 1982 | 1200 |
| 3306201 | 3308200 | Summicron-M 3.5 cm 1:2 | 1984 | 2000 |
| 3354801 | 3356800 | Summicron-M 3.5 cm 1:2 | 1985 | 2000 |
| 3395601 | 3397600 | Summicron-M 3.5 cm 1:2 | 1986 | 2000 |
| 3416891 | 3418890 | Summicron-M 3.5 cm 1:2 | 1986 | 2000 |
| 3440001 | 3441000 | Summicron-M 3.5 cm 1:2 | 1987 | 1000 |
| 3453071 | 3454070 | Summicron-M 3.5 cm 1:2 | 1987 | 1000 |
| 3456871 | 3457370 | Summicron-M 3.5 cm 1:2 | 1988 | 500 |
| 3465071 | 3466070 | Summicron-M 3.5 cm 1:2 | 1988 | 1000 |
| 3485401 | 3486400 | Summicron-M 3.5 cm 1:2 | 1989 | 1000 |
| 3495661 | 3495900 | Summicron-M 3.5 cm 1:2 | 1989 | 240 |
| 3505151 | 3506150 | Summicron-M 3.5 cm 1:2 | 1990 | 1000 |
| 3507996 | 3508995 | Summicron-M 3.5 cm 1:2 | 1990 | 1000 |
| 3521296 | 3523295 | Summicron-M 3.5 cm 1:2 | 1990 | 2000 |
| 3553468 | 3555467 | Summicron-M 3.5 cm 1:2 | 1991 | 2000 |
| 3577534 | 3579533 | Summicron-M 3.5 cm 1:2 | 1991 | 2000 |
| 3590460 | 3592459 | Summicron-M 3.5 cm 1:2 | 1992 | 2000 |
| 3603670 | 3606169 | Summicron-M 3.5 cm 1:2 | 1992 | 2500 |
| 3610980 | 3613479 | Summicron-M 3.5 cm 1:2 | 1993 | 2500 |
| 3617895 | 3617897 | Summicron-M 3.5 cm 1:2 | 1993 | 3 |
| 3637926 | 3639725 | Summicron-M 3.5 cm 1:2 | 1993 | 1800 |
| 3639726 | 3641425 | Summicron-M 3.5 cm 1:2 | 1993 | 1700 |
| 3681531 | 3683730 | Summicron-M 3.5 cm 1:2 | 1995 | 2200 |
| 3683731 | 3684930 | Summicron-M 3.5 cm 1:2 | 1995 | 1200 |
| 3712903 | 3715402 | Summicron-M 3.5 cm 1:2 | 1995 | 2500 |
| 3715403 | 3717902 | Summicron-M 3.5 cm 1:2 | 1995 | 2500 |
| 3867717 | 3868266 | Summicron-M 3.5 cm 1:2 | 1999 | 550 |
| 3878467 | 3878866 | Summicron-M 3.5 cm 1:2 | 1999 | 400 |
| 3880747 | 3880946 | Summicron-M 3.5 cm 1:2 | 1999 | 200 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1979-1999 | 52,993 |
Lens superseded by 35mm f/2 ASPH Summicron-M
