Elmar f= 3.5 cm 1:3.5
  • Leica Code /No. – EKURZ, KUP or CHROM LLC - 150
  • Production era - 1930-1950
  • Variants - Nickel Serial Nos. / Chrome Serial Nos. / Coated lens after 1946
  • Lens mount - Screw-thread
  • Number of lenses /groups – 4 /3
  • Aperture range – f/3.5 > f/18
  • Focusing range – 1 m / 3.28 ft < ∞
  • Smallest object field -
  • Diaphragm setting /type -
  • Angle of view diagonal - 64 degrees
  • Filter type - A36
  • Accessories – Hood: FLQOO
  • Materials - Nickel plated brass, chrome plated brass
  • Weight – 110 g /3.88 oz
  • Inscription - Leitz Elmar f=3,5cm 1:3,5
  • Forum discussion
Elmar f= 3.5 cm 1:3.5 Serial Numbers
-149910-252698- -439276- *Elmar 3.5cm 1:3.5 1930-1933 unknown
160001 161000 Elmar 3.5cm 1:3.5 1933 1000
171001 172000 Elmar 3.5cm 1:3.5 1933 1000
182001 183000 Elmar 3.5cm 1:3.5 1933 1000
215001 216000 Elmar 3.5cm 1:3.5 1934 1000
515001 516000 Elmar 3.5cm 1:3.5 1939 1000
566501 567000 Elmar 3.5cm 1:3.5 1941 5000
567061 567061 Elmar 3.5cm 1:3.5 1941 1
677601 679000 Elmar 3.5cm 1:3.5 1948 1400
693001 696000 Elmar 3.5cm 1:3.5 1948 3000
TOTAL ASSIGNED SERIAL NUMBERS 1933-1941 14,401
.* Early serial numbers are from known lenses Note: Puts lists a lens called "Weitwinkel" (wide-angle) 3.5cm 1:3.5 from the same production era. I don't know if these lenses should be listed here as well, or if not, with which lens?
