100mm f/4 Macro-Elmar-R
Revision as of 22:24, 20 March 2010 by Admin (talk | contribs) (→100mm f/4 Macro-Elmar-R Serial Numbers)
- Leica Order No. - 11 232 / LLC - 179
- Production era - 1978-1995 < 16,254 lenses including Helical and Bellows versions
- Variants - Helical with 3 cams and bellows unit with no cams
- Number of lenses /groups - 4 / 3
- F stop range - f/4-f/22
- Closest focusing distance - 1.10 m / 3.60 ft
- Smallest object field - 38 x 57 mm (bellows) - 72 x 106 mm (helical)
- Diaphragm setting /type -
- Angle of view diagonal - 25 degrees (bellows) - 27 degrees (helical)
- Filter type - E55
- Accessories -
- Materials -
- Dimensions length x diameter - 120 x 67.5 mm / 4.72 x 2.66 in (bellows) - 90 x 67.5 / 3.54 x 2.66 in (helical)
- Weight - 670 g /1.48 lb (bellows) - 540 g /1.19 lb (helical)
- Inscription - MACRO-ELMAR-R 1:4/100 LEITZ CANADA 2XXXXXX
- Designer -
- On the street - €EU 336-384 in 2008
| 2279851 | 2280850 | 100mm f/4 Makro-Elmar-R (bellows) | 1968 | 1000 |
| 2290951 | 2291950 | 100mm f/4 Macro-Elmar-R | 1968 | 1000 |
| 2390201 | 2391200 | 100mm f/4 Macro-Elmar-R | 1970 | 1000 |
| 2416101 | 2417200 | 100mm f/4 Macro-Elmar-R | 1970 | 1100 |
| 2623101 | 2623600 | 100mm f/4 Macro-Elmar-R (bellows) | 1973 | 500 |
| 2681201 | 2681700 | 100mm f/4 Macro-Elmar-R | 1974 | 500 |
| 2860601 | 2860800 | 100mm f/4 Macro-Elmar-R | 1977 | 200 |
| 2883701 | 2885700 | 100mm f/4 Macro-Elmar-R | 1978 | 2000 |
| 2926901 | 2928900 | 100mm f/4 Macro-Elmar-R | 1978 | 2000 |
| 2933351 | 2933500 | 100mm f/4 Macro-Elmar-R (bellows) | 1978 | 150 |
| 2973251 | 2974250 | 100mm f/4 Macro-Elmar-R | 1979 | 1000 |
| 2982001 | 2982100 | 100mm f/4 Macro-Elmar-R | 1979 | 100 |
| 3031801 | 3032800 | 100mm f/4 Macro-Elmar-R | 1980 | 1000 |
| 3052601 | 3053600 | 100mm f/4 Macro-Elmar-R (helical) | 1980 | 1000 |
| 3084501 | 3084950 | 100mm f/4 Macro-Elmar-R | 1980 | 450 |
| 3349801 | 3350800 | 100mm f/4 Macro-Elmar-R | 1985 | 1000 |
| 3409891 | 3411890 | 100mm f/4 Macro-Elmar-R | 1986 | 2000 |
| 3596460 | 3596709 | 100mm f/4 Macro-Elmar-R (bellows) | 1992 | 250 |
| 3655822 | 3655825 | 100mm f/4 Macro-Elmar-R | 1994 | 4 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1968-2005 | 16,254 |
