28mm f/2.8 Elmarit I
Revision as of 22:10, 22 March 2010 by Admin (talk | contribs) (change Elmarit I = Wetzlar, Elmarit II = Canada in two outer designs)
  • Leica Order No. - 11 801 LLC - 144
  • Production era - 1965-1969
  • Variants - Yellow /white scale; red /white scale; only made in Wetzlar, this lens has a deep intruding back and can't be used with built-in meter, on M5 the lightmeter don't swings in working-position on newer or modified lenses.
  • Number of lenses /groups - 9 /6, ( 9/6, but i'm not totally sure how much groops)
  • F stop range - f/2.8 > f/22
  • Closest focusing distance - 0.7 m /2.30 ft (M3 1 m)
  • Smallest object field - 533 x 800 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 76 degrees
  • Filter type - Series 7, E48
  • Accessories - Viewfinder: SLOOZ; Hood: 12501
  • Materials -
  • Dimensions length x diameter - 56 x 52.5 mm / 2.20 x 2.07 in
  • Weight - 225 g /7.94 oz
  • Inscription - LEITZ WETZLAR ELMARIT 1:2.8/28 2XXXXXX
  • Designer - Otto Zimmermann, Heinz Marquandt, Herman Desch and Eugen Hermanni
  • Forum discussion
  • Reviews
28mm f/2.8 Elmarit I Serial Numbers
2061501 2063500 28mm f/2.8 Elmarit 1964 2000
2196901 2198100 28mm f/2.8 Elmarit 1966 1200
2314801 2316000 28mm f/2.8 Elmarit 1969 1200
2459501 2460500 28mm f/2.8 Elmarit 1970 1000
TOTAL ASSIGNED SERIAL NUMBERS 1964-1970 5,400
Lens superseded by 28mm f/2.8 Elmarit II
