Elmar (III) 1:4 / 90mm
Revision as of 13:37, 24 March 2010 by Admin (talk | contribs)
  • Leica Order No. - ELANG, ELANG-M 11 730 11 830 LLC - 168
  • Production era - 1964-1965 < 6,400 lenses with < 500 in screw-mount (per Westlicht)
  • Variants -
  • Number of lenses /groups - 3 /3
  • F stop range - f/4-f/32
  • Closest focusing distance - 1 m /3.28 ft
  • Smallest object field -
  • Diaphragm setting /type -
  • Angle of view diagonal - 27 degrees
  • Filter type -
  • Accessories - Hood: IUFOO 12575
  • Materials - Clear anodized aluminum
  • Weight - 300 g /10.58 lb
  • Inscription - Leitz Wetzlar 169XXXX Elmar f=9cm 1:4 or some with Ernst Leitz GmbH Wetzlar
  • Forum discussion
Elmar (III) f= 9 cm 1:4 Serial Numbers
Note: Some of these numbers might be 90mm f/4 Elmar
1913001 1914000 Elmar 90 mm 1:40 1962 1000
1936001 1937000 Elmar 90 mm 1:40 (screw-mount) 1962 1000
2088801 2090800 Elmar 90 mm 1:40 1965 2000
2097501 2097900 Elmar 90 mm 1:40 1965 400
2123651 2125650 Elmar 90 mm 1:40 1965 2000
TOTAL ASSIGNED SERIAL NUMBERS 1964-1965 6,400
