Elmarit f= 9 cm 1:2.8
Revision as of 18:31, 25 March 2010 by Admin (talk | contribs) (→Elmarit f= 9 cm 1:2.8 Serial Numbers)
- Leica Order No. - ELRIT 11029, ELRIM 11039 11129 LLC - 171
- Production era - 1959-1974 2,067 screw lens, 28,527 bayonet lens < 43,290 lenses
- Variants - Black or chrome
- Lens mount - Leica Screw-thread & M-bayonet
- Number of lenses /groups - 5 /3
- F stop range - f/2.8-f/22
- Diaphragm setting /type -
- Filter type - E39
- Accessories - Hood: IUFOO 12575
- Materials - Black or clear anodized aluminum
- Dimensions length x diameter - 94 x 53 mm / 3.70 x 2.09 in
- Weight - 330 g / 11.64 oz
- Inscription - Elmarit f=9cm 1:2.8 1XXXXXX
- Designer - Walter Mandler
| 1585001 | 1585070 | Elmarit f= 9 cm 1:2.8 | 1958 | 70 |
| 1640501 | 1640600 | Elmarit f= 9 cm 1:2.8 (screw-mount) | 1958 | 100 |
| 1649001 | 1650000 | Elmarit f= 9 cm 1:2.8 (screw-mount) | 1959 | 1000 |
| 1657451 | 1659000 | Elmarit f= 9 cm 1:2.8 | 1959 | 1550 |
| 1683001 | 1686000 | Elmarit f= 9 cm 1:2.8 (screw-mount) | 1959 | 3000 |
| 1692001 | 1694000 | Elmarit f= 9 cm 1:2.8 (screw-mount) | 1959 | 2000 |
| 1709001 | 1710000 | Elmarit f= 9 cm 1:2.8 | 1959 | 1000 |
| 1735001 | 1737000 | Elmarit f= 9 cm 1:2.8 | 1960 | 2000 |
| 1752001 | 1753000 | Elmarit f= 9 cm 1:2.8 | 1960 | 1000 |
| 1756001 | 1757000 | Elmarit f= 9 cm 1:2.8 | 1960 | 1000 |
| 1760601 | 1762000 | Elmarit f= 9 cm 1:2.8 | 1960 | 1400 |
| 1805001 | 1808000 | Elmarit f= 9 cm 1:2.8 | 1960 | 3000 |
| 1878001 | 1880000 | Elmarit f= 9 cm 1:2.8 | 1961 | 2000 |
| 1917001 | 1920000 | Elmarit f= 9 cm 1:2.8 | 1962 | 3000 |
| 1983901 | 1984400 | Elmarit f= 9 cm 1:2.8 | 1963 | 500 |
| 2001001 | 2002000 | Elmarit f= 9 cm 1:2.8 | 1963 | 1000 |
| 2044001 | 2046000 | Elmarit f= 9 cm 1:2.8 | 1964 | 2000 |
| 2084801 | 2088800 | Elmarit f= 9 cm 1:2.8 | 1965 | 4000 |
| 2125651 | 2129950 | Elmarit f= 9 cm 1:2.8 | 1965 | 4300 |
| 2213001 | 2215000 | Elmarit f= 9 cm 1:2.8 | 1966 | 2000 |
| 2215001 | 2215200 | Elmarit f= 9 cm 1:2.8 | 1966 | 200 |
| 2291951 | 2292050 | Elmarit f= 9 cm 1:2.8 | 1968 | 100 |
| 2303951 | 2305150 | Elmarit f= 9 cm 1:2.8 | 1968 | 1200 |
| 2372801 | 2374800 | Elmarit f= 9 cm 1:2.8 | 1969 | 2000 |
| 2374801 | 2374900 | Elmarit f= 9 cm 1:2.8 | 1969 | 100 |
| 2426301 | 2428300 | Elmarit f= 9 cm 1:2.8 | 1970 | 2000 |
| 2428301 | 2428400 | Elmarit f= 9 cm 1:2.8 | 1970 | 100 |
| 2428401 | 2428750 | Elmarit f= 9 cm 1:2.8 | 1970 | 350 |
| 2522801 | 2523800 | Elmarit f= 9 cm 1:2.8 | 1972 | 1000 |
| 2721001 | 2721320 | Elmarit f= 9 cm 1:2.8 | 1974 | 320 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1958-1974 | 43,290 |
