50mm f/1.4 Summilux-M III
- Leica Order No. 11 856 - 11 868 - 11 869 LLC - 127
- Production era - 1992-2005, 22,383+ lenses
- Variants - Black, chrome and titanium versions
- Lens mount - Leica M-bayonet (Screw-mount in limited edition - see Forum discussion [1] [2] [3] below)
- F stop range - f/1.4-f/16
- Diaphragm setting /type -
- Filter type - E46
- Hood - Built-in telescoping hood
- Accessories -
- Materials - Black anodized aluminum; silver or titanium lacquered brass
- Dimensions (length x diameter) - 54.5 x 47.7 mm / 2.15 x 1.88 in
- Weight - 275 g /9.70 oz in black; 380 g /13.4 oz in silver & titanium
- Inscription - LEICA SUMMILUX 1:1.4/50 E46 388XXXX
- Designer -
50mm f/1.4 Summilux-M III Serial Numbers
| 3588960 | 3590459 | Summilux-M f= 5 cm 1:1.4 | 1992 | 1500 |
| 3653421 | 3653695 | Summilux-M f= 5 cm 1:1.4 | 1994 | 275 |
| 3655716 | 3655821 | Summilux-M f= 5 cm 1:1.4 | 1994 | 106 |
| 3660831 | 3661830 | Summilux-M f= 5 cm 1:1.4 | 1994 | 1000 |
| 3675531 | 3676530 | Summilux-M f= 5 cm 1:1.4 | 1994 | 1000 |
| 3689931 | 3690930 | Summilux-M f= 5 cm 1:1.4 | 1995 | 1000 |
| 3693931 | 3694930 | Summilux-M f= 5 cm 1:1.4 | 1995 | 1000 |
| 3726303 | 3726553 | Summilux-M f= 5 cm 1:1.4 | 1995 | 251 |
| 3760000 | 3760999 | Summilux-M f= 5 cm 1:1.4 | 1996 | 1000 |
| 3772930 | 3773929 | Summilux-M f= 5 cm 1:1.4 | 1997 | 1000 |
| 3868267 | 3868616 | Summilux-M f= 5 cm 1:1.4 (screw-mount) | 1999 | 350 |
| 3870167 | 3871166 | Summilux-M f= 5 cm 1:1.4 (black) | 1999 | 1000 |
| 3877167 | 3877466 | Summilux-M f= 5 cm 1:1.4 | 1999 | 300 |
| 3881947 | 3882246 | Summilux-M f= 5 cm 1:1.4 (screw-mount) | 1999 | 300 |
| 3929514 | 3930513 | Summilux-M f= 5 cm 1:1.4 | 2001 | 1000 |
| 3964511 | 3965510 | Summilux-M f= 5 cm 1:1.4 | 2003 | 1000 |
| 3977089 | 3977588 | Summilux-M f= 5 cm 1:1.4 | 2004 | 500 |
| 3979589 | 3980088 | Summilux-M f= 5 cm 1:1.4 | 2004 | 500 |
| 3982051 | 3982550 | Summilux-M Titan 5 cm 1:1.4 | 2004 | 500 |
| 3982551 | 3983050 | Summilux-M Schw 5 cm 1:1.4 | 2004 | 500 |
| 3985034 | 3985533 | Summilux-M f= 5 cm 1:1.4 | 2004 | 500 |
| 3988719 | 3989218 | Summilux-M f= 5 cm 1:1.4 | 2005 | 500 |
| 3990069 | 3991118 | Summilux-M f= 5 cm 1:1.4 | 2005 | 1050 |
| 3991869 | 3992870 | Summilux-M f= 5 cm 1:1.4 | 2005 | 1000 |
| unknown | -4011798- | Summilux-M f= 5 cm 1:1.4 | 2006 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1992-2005 | 22,383 |
Lens superseded by 50mm f/1.4 ASPH Summilux-M
