90mm f/2 Summicron-M III
Revision as of 14:50, 28 March 2010 by Admin (talk | contribs)
  • Leica Order No. - 11 136 - 11 137 LLC -
  • Production era - 1982-1998 < 30,151 lenses
  • Variants - Black and silver versions; 1st version with telescoping shade that covers f-stop ring when not deployed
  • Number of lenses /groups - 5 /4
  • F stop range - f/2.8-f/22
  • Smallest object field - 220 x 330 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 27 degrees
  • Filter type - E49 (1st) - E55 (2nd)
  • Accessories -
  • Materials - Black anodized aluminum or silver lacquered brass
  • Dimensions length x diameter - 77 x 63.5 mm / 3.03 x 2.50 in
  • Weight - 475 g /1.05 lb in black; 690 g / 1.52 lb in silver
  • Inscription - LEITZ SUMMICRON-M 1:2/90 3XXXXXX
  • Designer - Walter Mandler
  • On the street - €EU 456 in 2008
  • Forum discussion
90mm f/2 Summicron-M III Serial Numbers
.* Lens nos. 2814052 & 2814349 are 90mm not 35mm as listed
2813401 *2814900 Summicron-M f= *3.5 cm 1:2 (black.1) 1977 [1500]
2947201 2950200 Summicron-M f= 9 cm 1:2 1978 3000
3163001 3164000 Summicron-M f= 9 cm 1:2 (black.1) 1982 1000
3177201 3178200 Summicron-M f= 9 cm 1:2 1982 1000
3209801 3211800 Summicron-M f= 9 cm 1:2 1982 2000
3222301 3223300 Summicron-M f= 9 cm 1:2 1982 1000
3263401 3265400 Summicron-M f= 9 cm 1:2 1983 2000
3298201 3299200 Summicron-M f= 9 cm 1:2 1984 1000
3365801 3366800 Summicron-M f= 9 cm 1:2 1985 1000
3391001 3391800 Summicron-M f= 9 cm 1:2 1986 800
3436501 3437500 Summicron-M f= 9 cm 1:2 1987 1000
3455071 3455870 Summicron-M f= 9 cm 1:2 1987 800
3458371 3459070 Summicron-M f= 9 cm 1:2 1988 700
3473901 3474700 Summicron-M f= 9 cm 1:2 1988 800
3482901 3483500 Summicron-M f= 9 cm 1:2 1989 600
3523296 3523795 Summicron-M f= 9 cm 1:2 1990 500
3532468 3533467 Summicron-M f= 9 cm 1:2 1990 1000
3574634 3575633 Summicron-M f= 9 cm 1:2 1991 1000
3594960 3595959 Summicron-M f= 9 cm 1:2 1992 1000
3608120 3608369 Summicron-M f= 9 cm 1:2 1992 250
3615580 3616579 Summicron-M f= 9 cm 1:2 1993 1000
3617902 3617902 Summicron-M f= 9 cm 1:2 1993 1
3642376 3643275 Summicron-M f= 9 cm 1:2 1993 900
3643276 3644475 Summicron-M f= 9 cm 1:2 1993 1200
3665831 3666030 Summicron-M f= 9 cm 1:2 1994 200
3687031 3688230 Summicron-M f= 9 cm 1:2 1995 1200
3688231 3689030 Summicron-M f= 9 cm 1:2 1995 800
3702703 3703802 Summicron-M f= 9 cm 1:2 1995 1100
3703803 3704802 Summicron-M f= 9 cm 1:2 1995 1000
3720503 3721802 Summicron-M f= 9 cm 1:2 1995 1300
3721803 3722802 Summicron-M f= 9 cm 1:2 1995 1000
TOTAL ASSIGNED SERIAL NUMBERS 1977-1995 30,151
