135mm f/2.8 Elmarit-R I
- Leica Order No. - 11 111 - 11 211 / LLC - 184
- Production era - 1964-1968 < 39,350 lenses
- Variants -
- F stop range - f/2.8-f/22
- Closest focusing distance - 1.5 m / 4.92 ft
- Diaphragm setting /type -
- Filter type - Series 7
- Accessories - ELPRO close focusing attachment
- Materials -
- Dimensions length x diameter - 91 x 65 mm / 3.58 x 2.56 in
- Weight - 655 g /1.44 lb
- Inscription - ELMARIT-R 1:2.8/135 LEITZ CANADA 2XXXXXX
- Designer - Walter Mandler
- On the street - €EU
135mm f/2.8 Elmarit-R I Serial Numbers
| 1967001 | 1967100 | 135mm f/2.8 Elmarit-R | 1962 | 100 |
| 1995501 | 1995900 | 135mm f/2.8 Elmarit-R | 1963 | 400 |
| 1995901 | 1996000 | 135mm f/2.8 Elmarit-R | 1963 | 100 |
| 2018001 | 2020000 | 135mm f/2.8 Elmarit-R | 1964 | 2000 |
| 2040701 | 2041700 | 135mm f/2.8 Elmarit-R | 1964 | 1000 |
| 2051001 | 2052000 | 135mm f/2.8 Elmarit-R | 1964 | 1000 |
| 2093501 | 2094500 | 135mm f/2.8 Elmarit-R | 1965 | 1000 |
| 2131951 | 2132950 | 135mm f/2.8 Elmarit-R | 1965 | 1000 |
| 2136951 | 2139950 | 135mm f/2.8 Elmarit-R | 1965 | 3000 |
| 2154901 | 2155550 | 135mm f/2.8 Elmarit-R | 1965 | 650 |
| 2171701 | 2173700 | 135mm f/2.8 Elmarit-R | 1966 | 2000 |
| 2192901 | 2194900 | 135mm f/2.8 Elmarit-R | 1966 | 2000 |
| 2244051 | 2246050 | 135mm f/2.8 Elmarit-R | 1967 | 2000 |
| 2296351 | 2298350 | 135mm f/2.8 Elmarit-R | 1968 | 2000 |
| 2305151 | 2307150 | 135mm f/2.8 Elmarit-R | 1968 | 2000 |
| 2362001 | 2364000 | 135mm f/2.8 Elmarit-R | 1969 | 2000 |
| 2376901 | 2378900 | 135mm f/2.8 Elmarit-R | 1969 | 2000 |
| 2398401 | 2400000 | 135mm f/2.8 Elmarit-R | 1970 | 1600 |
| 2404001 | 2406000 | 135mm f/2.8 Elmarit-R | 1970 | 2000 |
| 2466501 | 2468500 | 135mm f/2.8 Elmarit-R | 1970 | 2000 |
| 2529601 | 2531600 | 135mm f/2.8 Elmarit-R | 1972 | 2000 |
| 2610501 | 2613000 | 135mm f/2.8 Elmarit-R | 1973 | 2500 |
| 2621101 | 2622100 | 135mm f/2.8 Elmarit-R | 1973 | 1000 |
| 2663451 | 2665450 | 135mm f/2.8 Elmarit-R | 1974 | 2000 |
| 2729421 | 2731420 | 135mm f/2.8 Elmarit-R | 1974 | 2000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1962-1974 | 39,350 |
Lens superseded by 135mm f/2.8 Elmarit-R II
