75mm–200mm f/4.5 Vario-Elmar-R
Revision as of 16:22, 15 May 2010 by Admin (talk | contribs)
  • Leica Order No. - 11 226 LLC -
  • Production era - 1978-1984 < 27,100 lenses
  • Manufacturer - Minolta
  • Variants -
  • Number of lenses /groups - 15 / 11
  • F stop range - f/4.5-f/22
  • Closest focusing distance - 1.2 m / 3.94 ft
  • Smallest object field - 270 x 405, 107 x 160 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 32 / 12.5 degrees
  • Filter type - E55
  • Accessories -
  • Dimensions length x diameter - 157 x 70 mm / 6.18 x 2.76 in
  • Weight - 725 g /1.6 lb
  • Inscription - VARIO-ELMAR-R 1:4.5/75-200 LEITZ WETZLAR 29XXXXX
  • Designer -
  • On the street - €EU 625 in 2003
  • Forum discussion
75mm–200mm f/4.5 Vario-Elmar-R Serial Numbers
2895401 2897400 75mm–200mm f/4.5 Vario-Elmar-R 1978 2000
2937701 2939700 75mm–200mm f/4.5 Vario-Elmar-R 1978 2000
2981001 2982000 75mm–200mm f/4.5 Vario-Elmar-R 1979 1000
2991201 2991700 75mm–200mm f/4.5 Vario-Elmar-R (3-cam) 1979 500
3004851 3006850 75mm–200mm f/4.5 Vario-Elmar-R 1979 2000
3035401 3037400 75mm–200mm f/4.5 Vario-Elmar-R 1980 2000
3042601 3044100 75mm–200mm f/4.5 Vario-Elmar-R 1980 1500
3053601 3054000 75mm–200mm f/4.5 Vario-Elmar-R 1980 400
3058601 3059600 75mm–200mm f/4.5 Vario-Elmar-R (3-cam) 1980 1000
3078801 3081000 75mm–200mm f/4.5 Vario-Elmar-R (3-cam) 1980 2200
3102501 3104000 75mm–200mm f/4.5 Vario-Elmar-R 1981 1500
3136801 3138800 75mm–200mm f/4.5 Vario-Elmar-R 1981 2000
3187701 3189700 75mm–200mm f/4.5 Vario-Elmar-R 1982 2000
3218001 3220000 75mm–200mm f/4.5 Vario-Elmar-R 1982 2000
3225301 3227300 75mm–200mm f/4.5 Vario-Elmar-R 1982 2000
3273401 3276400 75mm–200mm f/4.5 Vario-Elmar-R 1983 3000
TOTAL ASSIGNED SERIAL NUMBERS 1978-1983 27,100
