Summarit f= 5 cm 1:1.5
Revision as of 14:40, 31 March 2010 by Admin (talk | contribs) (→Summarit f= 5 cm 1:1.5 Serial Numbers)
- Leica Order No. - SOOIA, SOOIA-M LLC - 124
- Production era - 1949-1960 < 74,643 lenses
- Variants - Wetzlar, ELC and Taylor-Hobson versions (see Forum Discussion [7] #18 permalink below)
- F stop range - f/1.5-f/16
- Closest focusing distance -
- Smallest object field -
- Type - One of the very few lenses that can be used for UV photography - see Forum Discussion [1] #11 permalink (and following) below
- Filter type - A43 or E41
- Accessories - Hood: XOONS 12150; Viewfinders: VIOOH and SBOOI 12015
- Materials -
- Weight - 320 g /11.29 oz
- Inscription - Summarit f=5cm 1:1.5 Nr82XXXX
Serial numbers compiled from Puts Pocket Pod.* Lens 1290589 Summarit f= 5 cm 1:1.5 (ELC.S)
491898 | 492000 | Summarit f= 5 cm 1:1.5 | 1939 | 103 |
740001 | 741000 | Summarit f= 5 cm 1:1.5 | 1949 | 1000 |
801001 | 802000 | Summarit f= 5 cm 1:1.5 | 1950 | 1000 |
820001 | 823000 | Summarit f= 5 cm 1:1.5 (ELW.S) | 1950 | 3000 |
1890001 | 893000 | Summarit f= 5 cm 1:1.5 | 1951 | 3000 |
950001 | 955000 | Summarit f= 5 cm 1:1.5 | 1952 | 5000 |
956001 | 956500 | Summarit f= 5 cm 1:1.5 | 1952 | 500 |
987101 | 987150 | Summarit f= 5 cm 1:1.5 | 1952 | 50 |
999001 | 1000000 | Summarit f= 5 cm 1:1.5 (ELW.S) | 1952 | 1000 |
1025001 | 1029500 | Summarit f= 5 cm 1:1.5 (ELW.S) | 1952 | 4500 |
1052001 | 1054000 | Summarit f= 5 cm 1:1.5 | 1953 | 2000 |
1054201 | 1058000 | Summarit f= 5 cm 1:1.5 | 1953 | 3800 |
1078001 | 1080000 | Summarit f= 5 cm 1:1.5 (ELW.S) | 1953 | 2000 |
1098001 | 1100000 | Summarit f= 5 cm 1:1.5 | 1953 | 2000 |
1119201 | 1121000 | Summarit f= 5 cm 1:1.5 | 1953 | 1800 |
1171501 | 1172500 | Summarit f= 5 cm 1:1.5 | 1954 | 1000 |
1187001 | 1188000 | Summarit f= 5 cm 1:1.5 | 1954 | 1000 |
1209001 | 1212000 | Summarit f= 5 cm 1:1.5 | 1954 | 3000 |
1246001 | 1247000 | Summarit f= 5 cm 1:1.5 (ELC.S) | 1955 | 1000 |
1275001 | 1277000 | Summarit f= 5 cm 1:1.5 | 1955 | 2000 |
1288001 | *1291000 | *Summaron f= 3.5 cm 1:3.5 | 1955 | [3000] |
1297001 | 1300000 | Summarit f= 5 cm 1:1.5 | 1955 | 3000 |
1330001 | 1333000 | Summarit f= 5 cm 1:1.5 | 1955 | 3000 |
1357001 | 1360000 | Summarit f= 5 cm 1:1.5 (ELW.S) | 1956 | 3000 |
1367501 | 1368500 | Summarit f= 5 cm 1:1.5 | 1956 | 1000 |
1389001 | 1393000 | Summarit f= 5 cm 1:1.5 | 1956 | 4000 |
1418001 | 1421000 | Summarit f= 5 cm 1:1.5 (ELC.M) | 1956 | 3000 |
1430001 | 1435000 | Summarit f= 5 cm 1:1.5 (ELW.S) | 1956 | 5000 |
1470001 | 1473000 | Summarit f= 5 cm 1:1.5 (ELW.S) | 1957 | 3000 |
1499001 | 1501000 | Summarit f= 5 cm 1:1.5 | 1957 | 2000 |
1515001 | 1518000 | Summarit f= 5 cm 1:1.5 | 1957 | 3000 |
1526001 | 1526900 | Summarit f= 5 cm 1:1.5 | 1957 | 900 |
1527161 | 1530000 | Summarit f= 5 cm 1:1.5 | 1957 | 2840 |
1535001 | 1537000 | Summarit f= 5 cm 1:1.5 | 1957 | 2000 |
1546001 | 1546150 | Summarit f= 5 cm 1:1.5 | 1957 | 150 |
TOTAL | ASSIGNED | SERIAL NUMBERS | 1939-1957 | 74,643 |
