75mm f/1.4 Summilux-M
				Revision as of 19:01, 31 March 2010 by Admin (talk | contribs) (→75mm f/1.4 Summilux-M Serial Numbers)
- Leica Order No. - 11 814 - 11 815 LLC - 165
 - Production era - 1980-2007 < 14,752 lenses
 - Variants - Black or titanium, after 1982 with built-in hood version
 - F stop range - f/1.4-f/16
 - Closest focusing distance - 0.75 m /2.46 ft
 - Smallest object field - 192 mm x 288 mm /1:8
 - Diaphragm setting /type - with clickstops from serial No. 2048701 onwards including half values
 - Angle of view diagonal, horizontal, vertical - 32°, 27°, 18°
 - Filter type - E60
 - Accessories - Hood for 1st version: 12539
 - Materials -
 - Dimensions (length x diameter) - 80 x 69 mm /3.15 x 2.72 in
 - Weight - 560 g /19.75
 - Inscription - LEICA LENS MADE IN CANADA 1:1.4/75 E60 SUMMILUX-M XXXXXXX
 - Designer - Walter Mandler "his favorite lens"
| 3063301 | 3064300 | 75mm f/1.4 Summilux-M | 1980 | 1000 |
| 3150501 | 3151500 | 75mm f/1.4 Summilux-M | 1981 | 1000 |
| 11 814 | ABOVE | BUILT-IN HOOD BELOW | TYPE | 11 815 |
| 3223301 | 3225300 | 75mm f/1.4 Summilux-M | 1982 | 2000 |
| 3258101 | 3260100 | 75mm f/1.4 Summilux-M | 1983 | 2000 |
| 3439501 | 3440000 | 75mm f/1.4 Summilux-M | 1987 | 500 |
| 3457871 | 3458370 | 75mm f/1.4 Summilux-M | 1988 | 500 |
| 3484901 | 3485400 | 75mm f/1.4 Summilux-M | 1989 | 500 |
| 3508996 | 3509295 | 75mm f/1.4 Summilux-M | 1990 | 300 |
| 3525296 | 3525795 | 75mm f/1.4 Summilux-M | 1990 | 500 |
| 3574134 | 3574633 | 75mm f/1.4 Summilux-M | 1991 | 500 |
| 3607320 | 3607619 | 75mm f/1.4 Summilux-M | 1993 | 300 |
| 3614480 | 3614979 | 75mm f/1.4 Summilux-M | 1993 | 500 |
| 3617900 | 3617901 | 75mm f/1.4 Summilux-M | 1993 | 2 |
| 3641576 | 3641825 | 75mm f/1.4 Summilux-M | 1993 | 250 |
| 3685731 | 3686230 | 75mm f/1.4 Summilux-M | 1995 | 500 |
| 3719103 | 3719602 | 75mm f/1.4 Summilux-M | 1995 | 500 |
| 3797510 | 3797709 | 75mm f/1.4 Summilux-M | 1997 | 200 |
| 3820125 | 3820624 | 75mm f/1.4 Summilux-M | 1998 | 500 |
| 3837375 | 3837974 | 75mm f/1.4 Summilux-M | 1998 | 600 |
| 3865967 | 3866166 | 75mm f/1.4 Summilux-M | 1999 | 200 |
| 3869617 | 3869916 | 75mm f/1.4 Summilux-M | 1999 | 300 |
| 3884907 | 3885206 | 75mm f/1.4 Summilux-M | 2000 | 300 |
| 3904826 | 3905125 | 75mm f/1.4 Summilux-M | 2000 | 300 |
| 3915523 | 3916022 | 75mm f/1.4 Summilux-M | 2001 | 500 |
| 3953001 | 3953500 | 75mm f/1.4 Summilux-M | 2002 | 500 |
| 3977589 | 3977888 | 75mm f/1.4 Summilux-M | 2004 | 300 |
| 3988519 | 3988718 | 75mm f/1.4 Summilux-M | 2005 | 200 |
| unknown | unknown | 75mm f/1.4 Summilux-M | 2006-2007 | unknown |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1980-2005 | 14,752 |
