90mm f/4 Elmar
  • Leica Order No. - ILNOO 11 631 - 11 830 /LLC - 168
  • Production era - 1954-1968 25,188 lenses
  • Variants - Collapsible and rigid versions with or without "eyes"; Scalloped focusing knurl (SFK); 1st rigid version has aperture scale on ring (not on barrel as shown)
  • Lens mount - Leica M-bayonet and screw-mount
  • Number of lenses /groups - 4 /3
  • F stop range - f/4-f/32
  • Closest focusing distance - 1 m /3.28 ft
  • Smallest object field -
  • Diaphragm setting /type -
  • Angle of view diagonal - 27 degrees
  • Filter type - E39
  • Accessories - Hood for collapsible lens: IUFOO, Close focusing device OMIFO for rigid lens (shown)
  • Materials - Clear anodized aluminum
  • Weight -
  • Inscription - Ernst Leitz GmbH Wetzlar Elmar f=9cm 1:4 Nr.1XXXXXX
90mm f/4 Elmar Serial Numbers
Note: Some numbers for 1965 might be Elmar (III) 1:4 / 90mm
1137001 1140000 Elmar 90 mm 1:40 (M-collapsible) 1954 3000
1160501 1163000 Elmar 90 mm 1:40 (M-rigid-1) 1954 2500
1171001 1171500 Elmar 90 mm 1:40 1954 500
1178001 1178500 Elmar 90 mm 1:40 1954 500
1182001 1183500 Elmar 90 mm 1:40 (S-rigid) 1954 1500
1188001 1190000 Elmar 90 mm 1:40 (S-collapsible) 1954 2000
1212001 1214000 Elmar 90 mm 1:40 1954 2000
1224001 1224200 Elmar 90 mm 1:40 1954 200
1236001 1238000 Elmar 90 mm 1:40 (M-collapsible) 1955 2000
1241001 1242000 Elmar 90 mm 1:40 1955 1000
1247001 1250000 Elmar 90 mm 1:40 1955 3000
1260001 1263000 Elmar 90 mm 1:40 1955 3000
1271001 1272000 Elmar 90 mm 1:40 1955 1000
1291001 1293000 Elmar 90 mm 1:40 1955 2000
1309001 1311000 Elmar 90 mm 1:40 1955 2000
1337001 1340000 Elmar 90 mm 1:40 1956 3000
1353001 1356000 Elmar 90 mm 1:40 1956 3000
1380001 1383000 Elmar 90 mm 1:40 (S-rigid) 1956 3000
1386001 1389000 Elmar 90 mm 1:40 1956 3000
1409001 1412000 Elmar 90 mm 1:40 1956 3000
1459001 1465000 Elmar 90 mm 1:40 (M-collapsible+S-rigid) 1957 6000
1481701 1483700 Elmar 90 mm 1:40 1957 2000
1491001 1494000 Elmar 90 mm 1:40 1957 3000
1497001 1499000 Elmar 90 mm 1:40 (S-rigid) 1957 2000
1503501 1506000 Elmar 90 mm 1:40 1957 2500
1521001 1524000 Elmar 90 mm 1:40 (M-collapsible) 1957 3000
1547001 1548000 Elmar 90 mm 1:40 (M-rigid) 1957 1000
1558001 1559000 Elmar 90 mm 1:40 1958 1000
1572001 1574000 Elmar 90 mm 1:40 1958 2000
1585071 1585075 Elmar 90 mm 1:40 1958 5
1603001 1604000 Elmar 90 mm 1:40 1958 1000
1630001 1630500 Elmar 90 mm 1:40 1958 500
1700001 1701000 Elmar 90 mm 1:40 (S-rigid) 1959 1000
1712001 1714000 Elmar 90 mm 1:40 (M-rigid) 1959 2000
1725001 1727000 Elmar 90 mm 1:40 1960 2000
1766201 1768000 Elmar 90 mm 1:40 (S-rigid) 1960 1800
1822001 1823000 Elmar 90 mm 1:40 1960 1000
1827001 1830000 Elmar 90 mm 1:40 1961 3000
1920001 1921000 Elmar 90 mm 1:40 (S-rigid.SFK) 1962 1000
2088801 2090800 Elmar 90 mm 1:40 (M-rigid-11 830) 1965 2000
2097501 2097900 Elmar 90 mm 1:40 (M-collapsible) 1965 400
2123651 2125650 Elmar 90 mm 1:40 (S-rigid.SFK) 1965 2000
TOTAL ASSIGNED SERIAL NUMBERS 1954-1965 81,405
