Elmar (III) f= 5 cm 1:3.5
- Leica Code /No. – ELMAR, ELMAR-M - ELMAM 11610 LLC - 113
- Production era - 1950-1959, 1954-1961 M-bayonet
- Variants - Metric and foot scales, A36 and E39 versions
- Lens mount - Screw-thread and M-bayonet
- Number of lenses /groups – 4 /3
- Aperture range – f/3.5 > f/22
- Focusing range – 1 m / 3.28 ft < ∞
- Smallest object field -
- Diaphragm setting /type -
- Filter type - A36, E39
- Accessories – Combination hood with diaphragm adjustment: VALOO; Hood for E39 version: ITOOY
- Weight – 125 g / 4.4 oz
- Inscription - Ernst Leitz GmbH Wetzlar - Elmar f=5cm 1:3.5 Nr.1XXXXXX
Serial numbers compiled from Puts Pocket PodNote: Some of the numbers between 1950 and 1956 should be assigned to Elmar (II) f= 5 cm 1:3.5
^ Lens 1148775 is Summaron 3.5 cm 1:3.5 (M)
| 802001 | 807000 | Elmar 5 cm 1:35 | 1950 | 5000 |
| 826001 | 836000 | Elmar 5 cm 1:35 | 1950 | 10000 |
| 866001 | 872000 | Elmar 5 cm 1:35 | 1951 | 6000 |
| 893001 | 898000 | Elmar 5 cm 1:35 | 1951 | 5000 |
| 904001 | 910000 | Elmar 5 cm 1:35 | 1951 | 6000 |
| 941001 | 950000 | Elmar 5 cm 1:35 | 1951 | 9000 |
| 955001 | 956000 | Elmar 5 cm 1:35 | 1952 | 1000 |
| 957501 | 958000 | Elmar 5 cm 1:35 | 1952 | 500 |
| 987151 | 990000 | Elmar 5 cm 1:35 | 1952 | 2850 |
| 998001 | 999000 | Elmar 5 cm 1:35 | 1952 | 1000 |
| 1000001 | 1004000 | Elmar 5 cm 1:35 | 1952 | 4000 |
| 1010201 | 1015000 | Elmar 5 cm 1:35 | 1952 | 4800 |
| 1045001 | 1050000 | Elmar 5 cm 1:35 | 1952 | 5000 |
| 1063001 | 1072000 | Elmar 5 cm 1:35 | 1953 | 9000 |
| 1086001 | 1091000 | Elmar 5 cm 1:35 | 1953 | 5000 |
| 1100001 | 1103000 | Elmar 5 cm 1:35 | 1953 | 3000 |
| 1121501 | 1124000 | Elmar 5 cm 1:35 | 1953 | 2500 |
| 1140016 | 1143000 | Elmar 5 cm 1:35 (M) | 1954 | 2985 |
| 1148222^ | 1149100 | Elmar 5 cm 1:35 | 1954 | 879 |
| 1163001 | 1166000 | Elmar 5 cm 1:35 | 1954 | 3000 |
| 1183501 | 1187000 | Elmar 5 cm 1:35 (E39-M) | 1954 | 3500 |
| 1198001 | 1203000 | Elmar 5 cm 1:35 | 1954 | 5000 |
| 1242001 | 1245000 | Elmar 5 cm 1:35 | 1955 | 3000 |
| 1294001 | 1297000 | Elmar 5 cm 1:35 | 1955 | 3000 |
| 1320001 | 1325000 | Elmar 5 cm 1:35 | 1955 | 5000 |
| 1333001 | 1337000 | Elmar 5 cm 1:35 (M) | 1956 | 4000 |
| 1340001 | 1345000 | Elmar 5 cm 1:35 | 1956 | 5000 |
| 1372001 | 1375000 | Elmar 5 cm 1:35 | 1956 | 3000 |
| 1426001 | 1429000 | Elmar 5 cm 1:35 | 1956 | 3000 |
| 1455001 | 1458000 | Elmar 5 cm 1:35 | 1956 | 3000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1950-1956 | 1 |
