28mm f/2.8 Elmarit-M III
Revision as of 14:49, 4 April 2010 by Admin (talk | contribs) (→28mm f/2.8 Elmarit III Serial Numbers)
- Leica Order No. - 11 804 LLC - 145
- Production era - 1979-1993 < 17,115 lenses
- Variants - 1913-1983 anniversary edition and ELC versions
- Number of lenses /groups - 8 /6
- F stop range - f/2.8-f/22
- Smallest object field -
- Diaphragm setting /type -
- Filter type - E49
- Accessories - Hood: 12536 - Viewfinder: SLOOZ
- Materials - Black lacquered brass
- Weight - 250 g /8.82 oz
- Inscriptions - LEITZ LENS MADE IN CANADA ELMARIT 1:2.8/28
LEITZ ELMARIT 1:2.8/28 3XXXXXX - Designer - Walter Mandler
Serial numbers compiled from Puts Pocket Pod.* Lens 2978506 is type -M not -R as listed (11 804-ELC)
| 2977551 | 2978550 | 28mm f/2.8 Elmarit-R* | 1979 | 1[000] |
| 3037401 | 3038400 | 28mm f/2.8 Elmarit-M | 1980 | 1000 |
| 3041001 | 3042000 | 28mm f/2.8 Elmarit-M | 1980 | 1000 |
| 3154501 | 3155500 | 28mm f/2.8 Elmarit-M | 1981 | 1000 |
| 3168001 | 3169000 | 28mm f/2.8 Elmarit-M | 1982 | 1000 |
| 3189701 | 3190700 | 28mm f/2.8 Elmarit-M | 1982 | 1000 |
| 3205801 | 3206800 | 28mm f/2.8 Elmarit-M (13-83) | 1982 | 1000 |
| 3245101 | 3246100 | 28mm f/2.8 Elmarit-M | 1982 | 1000 |
| 3276401 | 3277400 | 28mm f/2.8 Elmarit-M | 1983 | 1000 |
| 3293401 | 3294400 | 28mm f/2.8 Elmarit-M | 1983 | 1000 |
| 3392801 | 3393300 | 28mm f/2.8 Elmarit-M | 1986 | 500 |
| 3425691 | 3426690 | 28mm f/2.8 Elmarit-M (ELC) | 1987 | 1000 |
| 3438501 | 3439500 | 28mm f/2.8 Elmarit-M | 1987 | 1000 |
| 3466571 | 3467070 | 28mm f/2.8 Elmarit-M | 1988 | 500 |
| 3487551 | 3488550 | 28mm f/2.8 Elmarit-M | 1989 | 1000 |
| 3507631 | 3507845 | 28mm f/2.8 Elmarit-M | 1990 | 215 |
| 3518796 | 3519795 | 28mm f/2.8 Elmarit-M | 1990 | 1000 |
| 3558368 | 3559367 | 28mm f/2.8 Elmarit-M | 1991 | 1000 |
| 3575634 | 3576533 | 28mm f/2.8 Elmarit-M | 1991 | 900 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1979-1991 | 17,116 |
Lens superseded by 28mm f/2.8 Elmarit-M IV
