Elmar (III) f= 5 cm 1:3.5
Revision as of 16:17, 17 April 2010 by Admin (talk | contribs)
  • Leica Code /No. – ELMAR, ELMAR-M - ELMAM 11610 LLC - 113
  • Production era - 1950-1959 < 127,014 lenses, 1954-1961 M-bayonet
  • Variants - Metric and foot scales, A36 and E39 versions
  • Lens mount - Screw-thread and M-bayonet
  • Number of lenses /groups – 4 /3
  • Aperture range – f/3.5 > f/22
  • Focusing range – 1 m / 3.28 ft < ∞
  • Smallest object field -
  • Diaphragm setting /type - 10-blade
  • Filter type - A36, E39
  • Accessories – Combination hood with diaphragm adjustment: VALOO; Hood for E39 version: ITOOY
  • Weight – 125 g / 4.4 oz
  • Inscription - Ernst Leitz GmbH Wetzlar - Elmar f=5cm 1:3.5 Nr.1XXXXXX
Note: Some of the numbers between 1950 and 1956 should be assigned to Elmar (II) f= 5 cm 1:3.5
^ Lens 1148775 is Summaron 3.5 cm 1:3.5 (M)
802001 807000 Elmar 5 cm 1:35 1950 5000
826001 836000 Elmar 5 cm 1:35 1950 10000
866001 872000 Elmar 5 cm 1:35 1951 6000
893001 898000 Elmar 5 cm 1:35 1951 5000
904001 910000 Elmar 5 cm 1:35 1951 6000
941001 950000 Elmar 5 cm 1:35 1951 9000
955001 956000 Elmar 5 cm 1:35 1952 1000
957501 958000 Elmar 5 cm 1:35 1952 500
987151 990000 Elmar 5 cm 1:35 1952 2850
998001 999000 Elmar 5 cm 1:35 1952 1000
1000001 1004000 Elmar 5 cm 1:35 1952 4000
1010201 1015000 Elmar 5 cm 1:35 1952 4800
1045001 1050000 Elmar 5 cm 1:35 1952 5000
1063001 1072000 Elmar 5 cm 1:35 1953 9000
1086001 1091000 Elmar 5 cm 1:35 1953 5000
1100001 1103000 Elmar 5 cm 1:35 1953 3000
1121501 1124000 Elmar 5 cm 1:35 1953 2500
1140016 1143000 Elmar 5 cm 1:35 (M) 1954 2985
1145001 1148000 Elmar 5 cm 1:35 (M) 1954 3000
1148222^ 1149100 Elmar 5 cm 1:35 1954 879
1163001 1166000 Elmar 5 cm 1:35 1954 3000
1183501 1187000 Elmar 5 cm 1:35 (E39-M) 1954 3500
1198001 1203000 Elmar 5 cm 1:35 1954 5000
1242001 1245000 Elmar 5 cm 1:35 1955 3000
1294001 1297000 Elmar 5 cm 1:35 1955 3000
1320001 1325000 Elmar 5 cm 1:35 1955 5000
1333001 1337000 Elmar 5 cm 1:35 (M) 1956 4000
1340001 1345000 Elmar 5 cm 1:35 1956 5000
1372001 1375000 Elmar 5 cm 1:35 1956 3000
1426001 1429000 Elmar 5 cm 1:35 1956 3000
1455001 1458000 Elmar 5 cm 1:35 1956 3000
TOTAL ASSIGNED SERIAL NUMBERS 1950-1956 127,014
