180mm f/2.8 Elmarit-R I
Revision as of 22:51, 6 April 2010 by Admin (talk | contribs) (→180mm f/2.8 Elmarit-R I Serial Numbers)
- Leica Order No. - 11 919 LLC - 187
- Production era - 1968-1979 < 17,000 lenses
- Variants - 1, 2 or 3-cam, ELC & ELW versions
- F stop range - f/2.8-f/22
- Closest focusing distance - 1.8 m / 5.91 ft
- Smallest object field -
- Diaphragm setting /type -
- Angle of view diagonal - 14 degrees
- Filter type - Series 8 + 14165
- Accessories - Filter-ring: 14165
- Materials -
- Weight - 1325 g /2.92 lb
- Inscription - ELMARIT-R 1:2.8/180 LEITZ CANADA 2XXXXXX
- Designer -
- On the street - €EU
| 2161001 | 2161500 | 180mm f/2.8 Elmarit-R | 1966 | 500 |
| 2226001 | 2226500 | 180mm f/2.8 Elmarit-R | 1967 | 500 |
| 2247901 | 2249900 | 180mm f/2.8 Elmarit-R | 1967 | 2000 |
| 2280851 | 2283350 | 180mm f/2.8 Elmarit-R | 1968 | 2500 |
| 2354301 | 2356300 | 180mm f/2.8 Elmarit-R (3-cam) | 1969 | 2000 |
| 2455501 | 2457500 | 180mm f/2.8 Elmarit-R (3-cam) | 1970 | 2000 |
| 2498101 | 2499100 | 180mm f/2.8 Elmarit-R | 1971 | 1000 |
| 2511601 | 2512600 | 180mm f/2.8 Elmarit-R | 1972 | 1000 |
| 2542501 | 2543500 | 180mm f/2.8 Elmarit-R | 1972 | 1000 |
| 2673201 | 2674200 | 180mm f/2.8 Elmarit-R (2-cam) | 1974 | 1000 |
| 2698601 | 2699600 | 180mm f/2.8 Elmarit-R (2-cam) | 1974 | 1000 |
| 2753051 | 2754050 | 180mm f/2.8 Elmarit-R (3-cam) | 1975 | 1000 |
| 2838801 | 2839800 | 180mm f/2.8 Elmarit-R (ELW) | 1977 | 1000 |
| 2913101 | 2913600 | 180mm f/2.8 Elmarit-R | 1978 | 500 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1966-1978 | 17,000 |
Lens superseded by 180mm f/2.8 Elmarit-R II
