50mm f/2 Summicron-R I
Revision as of 13:59, 7 April 2010 by Admin (talk | contribs) (→50mm f/2 Summicron-R I Serial Numbers)
- Leica Order No. - 11 228 / LLC - 121
- Production era - 1964-1976 black; 1964-1966 200 chrome < 95,647 lenses
- Variants - 1-cam and 2-cam; black and chrome versions
- Number of lenses /groups - 6 / 5
- F stop range - f/2-f/16
- Closest focusing distance - 50 cm / 1.64 ft
- Smallest object field -
- Diaphragm setting /type -
- Filter type - Series 6 + 14160
- Accessories - Hood: 12564 - Close focusing attachment: ELPRO - Filter ring: 14160
- Materials -
- Weight - 680 g /1.50 lb
- Inscription - SUMMICRON-R 1:2/50 LEITZ CANADA (or WETZLAR) 2XXXXXX
- Designer - Walter Mandler
- On the street - €EU 780 chrome, 188 black, in 2008
Serial numbers compiled from Puts Pocket Pod.* Lens 2359246 is Summicron 3.5 cm 1:2 (M-black.ELW)
| 1940501 | 1941000 | 50mm f/2 Summicron-R (1-cam.chrom) | 1962 | 500 |
| 1972001 | 1972100 | 50mm f/2 Summicron-R | 1963 | 100 |
| 1999001 | 1999998 | 50mm f/2 Summicron-R (2-cam.chrom) | 1963 | 998 |
| 2000002 | 2001000 | 50mm f/2 Summicron-R (1-cam.chrom) | 1963 | 999 |
| 2002001 | 2004000 | 50mm f/2 Summicron-R (1-cam.chrom) | 1963 | 2000 |
| 2033001 | 2034000 | 50mm f/2 Summicron-R | 1964 | 1000 |
| 2038701 | 2039700 | 50mm f/2 Summicron-R | 1964 | 1000 |
| 2078501 | 2080500 | 50mm f/2 Summicron-R | 1965 | 2000 |
| 2110801 | 2113800 | 50mm f/2 Summicron-R (1-cam.black) | 1965 | 3000 |
| 2134951 | 2136950 | 50mm f/2 Summicron-R | 1965 | 2000 |
| 2145451 | 2147450 | 50mm f/2 Summicron-R | 1965 | 2000 |
| 2157001 | 2159000 | 50mm f/2 Summicron-R | 1966 | 2000 |
| 2164501 | 2166500 | 50mm f/2 Summicron-R | 1966 | 2000 |
| 2173701 | 2175700 | 50mm f/2 Summicron-R | 1966 | 2000 |
| 2178901 | 2180900 | 50mm f/2 Summicron-R | 1966 | 2000 |
| 2190901 | 2192900 | 50mm f/2 Summicron-R (1-cam.black) | 1966 | 2000 |
| 2199101 | 2201100 | 50mm f/2 Summicron-R (2-cam.black) | 1966 | 2000 |
| 2204101 | 2206100 | 50mm f/2 Summicron-R | 1966 | 2000 |
| 2224001 | 2226000 | 50mm f/2 Summicron-R | 1967 | 2000 |
| 2229801 | 2231800 | 50mm f/2 Summicron-R (2-cam.black+chrom) | 1967 | 2000 |
| 2242051 | 2244050 | 50mm f/2 Summicron-R (2-cam.black) | 1967 | 2000 |
| 2255401 | 2257400 | 50mm f/2 Summicron-R (2-cam.black) | 1968 | 2000 |
| 2265251 | 2267250 | 50mm f/2 Summicron-R | 1968 | 2000 |
| 2270251 | 2274250 | 50mm f/2 Summicron-R (2-cam.black) | 1968 | 4000 |
| 2299951 | 2303950 | 50mm f/2 Summicron-R (2-cam.black) | 1968 | 4000 |
| 2320301 | 2324300 | 50mm f/2 Summicron-R | 1969 | 4000 |
| 2351301 | 2353300 | 50mm f/2 Summicron-R | 1969 | 2000 |
| 2358301* | 2360000 | 50mm f/2 Summicron-R | 1969 | 1700 |
| 2360001 | 2362000 | 50mm f/2 Summicron-R | 1969 | 2000 |
| 2366001 | 2368000 | 50mm f/2 Summicron-R | 1969 | 2000 |
| 2380701 | 2382700 | 50mm f/2 Summicron-R (2-cam.black) | 1969 | 2000 |
| 2388201 | 2390200 | 50mm f/2 Summicron-R (2-cam.black) | 1970 | 2000 |
| 2411101 | 2413100 | 50mm f/2 Summicron-R | 1970 | 2000 |
| 2422201 | 2424200 | 50mm f/2 Summicron-R (2-cam.black) | 1970 | 2000 |
| 2430751 | 2432750 | 50mm f/2 Summicron-R | 1970 | 2000 |
| 2435751 | 2437750 | 50mm f/2 Summicron-R | 1970 | 2000 |
| 2437751 | 2438000 | 50mm f/2 Summicron-R | 1970 | 250 |
| 2487201 | 2489200 | 50mm f/2 Summicron-R | 1971 | 2000 |
| 2501001 | 2503000 | 50mm f/2 Summicron-R | 1971 | 2000 |
| 2520401 | 2522400 | 50mm f/2 Summicron-R | 1972 | 2000 |
| 2527501 | 2529600 | 50mm f/2 Summicron-R | 1972 | 2100 |
| 2580551 | 2582550 | 50mm f/2 Summicron-R | 1973 | 2000 |
| 2588501 | 2590500 | 50mm f/2 Summicron-R | 1973 | 2000 |
| 2650601 | 2652600 | 50mm f/2 Summicron-R (2-cam.black) | 1973 | 2000 |
| 2665451 | 2667450 | 50mm f/2 Summicron-R | 1974 | 2000 |
| 2700601 | 2703600 | 50mm f/2 Summicron-R (2-cam.black) | 1974 | 3000 |
| 2715001 | 2718000 | 50mm f/2 Summicron-R (2-cam.black) | 1974 | 3000 |
| 2758151 | 2760150 | 50mm f/2 Summicron-R | 1975 | 2000 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1963-1975 | 95,647 |
Lens superseded by 50mm f/2 Summicron-R II
