35mm f/2 Summicron-R I
Revision as of 22:42, 6 April 2010 by Admin (talk | contribs) (→35mm f/2 Summicron-R I Serial Numbers)
- Leica Order No. - 11 227 LLC - 159
- Production era - 1972-1976 < 11,316 lenses
- Variants - 2-cam & 3-cam versions
- Number of lenses /groups - 9 / 7
- F stop range - f/2-f/16
- Closest focusing distance - 30 cm / 11.81 in
- Smallest object field - 140 x 210 mm
- Diaphragm setting /type -
- Angle of view diagonal - 64 degrees
- Filter type - Series 7
- Accessories - Hood: 12509
- Materials -
- Dimensions length x diameter - 61 x 68 mm / 2.40 x 2.68 in
- Weight - 510 g /1.12 lb
- Inscription - SUMMICRON-R 1:2/35 LEITZ CANADA 2XXXXXX
- On the street - €EU 384 IN 2008
Serial numbers compiled from Puts Pocket Pod| SN Start | SN End | Product | Year | |
| 2402001 | 2404000 | 35mm f/2 Summicron-R (2-cam) | 1970 | 2000 |
| 2464501 | 2466500 | 35mm f/2 Summicron-R (3-cam) | 1970 | 2000 |
| 2545701 | 2545950 | 35mm f/2 Summicron-R | 1972 | 250 |
| 2613001 | 2613100 | 35mm f/2 Summicron-R | 1973 | 100 |
| 2615101 | 2617100 | 35mm f/2 Summicron-R | 1973 | 2000 |
| 2618101 | 2620100 | 35mm f/2 Summicron-R | 1973 | 2000 |
| 2693001 | 2694000 | 35mm f/2 Summicron-R (3-cam) | 1974 | 1000 |
| 2713351 | 2713850 | 35mm f/2 Summicron-R | 1974 | 500 |
| 2728921 | 2729420 | 35mm f/2 Summicron-R | 1974 | 500 |
| 2731421 | 2731920 | 35mm f/2 Summicron-R | 1974 | 500 |
| 2783151 | 2783350 | 35mm f/2 Summicron-R | 1976 | 200 |
| 2791151 | 2791416 | 35mm f/2 Summicron-R | 1976 | 266 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1970-1999 | 11,316 |
Lens superseded by 35mm f/2 Summicron-R II
