28mm f/2.8 Elmarit I
- Leica Order No. - 11 801 LLC - 144
- Production era - 1965-1969 < 3,200 lenses
- Variants - Yellow /white scale; red /white scale (RS); ELC /Wetzlar, this lens has a deep intruding back and can't be used with built-in meter, on M5 the lightmeter won't swing in working-position on newer or modified lenses.
- Compatibility - Can be used on M9 cameras (without exposure metering).
- Number of lenses /groups - 9 /6
- F stop range - f/2.8-f/22
- Closest focusing distance - 0.7 m /2.30 ft (M3 1 m)
- Smallest object field - 533 x 800 mm
- Filter type - Series 7, E48
- Accessories - Viewfinder: SLOOZ; Hood: 12501
- Materials -
- Dimensions length x diameter - 56 x 52.5 mm / 2.20 x 2.07 in
- Weight - 243 g /8.57 oz
- Inscriptions - LEITZ WETZLAR ELMARIT 1:2.8/28 2XXXXXX
LEITZ CANADA 2XXXXXX ELMARIT 1:2.8/28 - Designer - Otto Zimmermann, Heinz Marquandt, Herman Desch and Eugen Hermanni
28mm f/2.8 Elmarit I Serial Numbers
| 2061501 | 2063500 | 28mm f/2.8 Elmarit (ELC+ELW-RS) | 1964 | 2000 |
| 2196901 | 2198100 | 28mm f/2.8 Elmarit (ELC-RS+YS) | 1966 | 1200 |
| TOTAL | ASSIGNED | SERIAL NUMBERS | 1964-1966 | 3,200 |
Lens superseded by 28mm f/2.8 Elmarit II
