M7
Revision as of 21:07, 29 April 2010 by Admin (talk | contribs)
Leica M7 with 50mm f/2 Summicron-M IV lens.
Wikipedia Leica M7
  • Leica order no. - Black Chrome 10 504 / Silver Chrome 10 503
  • Production era - 2002-Current
  • Type - 35 mm rangefinder camera with electronically controlled shutter and two mechanically controlled shutter speeds.
  • Variants - - Black - Silver - a la Carte
  • Special editions - Sheikh Al-Thani Titanium Special Edition (1) - 50 Anniversary Midland Leitz (50 cameras) - Titanium 50 Year M Edition (1000 cameras) - CPA (China Photograph Association) Edition (51 cameras)- Hermes Edition with 1.4/35 mm ASPH. (200)
  • Lens mount - Leica M bayonet mount.
  • Stabilization - None.
  • Viewfinder - Optical x 0.72 magnification with automatic parallax corrected framelines. Custom versions with x 0.58 & 0.85 magnification are available from the manufacturer. LED symbol for battery status. LED light balance with two triangular LEDs and a central circular LED to adjust the exposure. Triangular LEDs give the required direction to rotate the aperture dial. The LEDs flash to warn that the brightness reading is above or below the metering range.
  • Aspect ratio - 3:2
  • Flash - hot shoe synchronization speed 1/50s, slower shutter speeds can be used with manual settings.
  • Exposure compensation +/- 3EV in 1/3 EV increments or from 0 to –3 EV in 1 EV increments with computer control. Manual setting only.
  • Film transport - Manual film loading after opening base plate and rear panel. Advance Manually with quick wind lever or LEICAVIT M or motorized using LEICA MOTOR M, LEICA WINDER-M, LEICA WINDER M4-P or LEICA WINDER M4-2 (from serial no. 10350). Rewind Manually with extending rewind button or rewind crank after turning R lever on front of camera. Frame counter On top of camera. Automatic reset after removing base plate.
  • Film speed range - Choice of automatic setting from ISO 25/15° to ISO 5000/38° for DX coded films or manual setting from ISO 6/9° to ISO 6400/39°. Setting an additional exposure compensation (± 2 EV) allows speeds of ISO 1.5/3° to ISO 25000/45° to be used.
  • Shutter - In automatic mode (AUTO) continuous from 32 s to 1/1000 s. In automatic mode (AUTO) continuous from 32 s to 1/1000 s. With manual setting 4 s to 1/1000 s in whole increments. Electronically controlled with two mechanically controlled shutter speeds, 1/60 s and 1/125 s. B for very long exposures of any duration, (1/50 s) for flash synchronization. Three stage: Power up Exposure value storage (in automatic mode) – Release Standard thread for cable release integrated.
  • Exposure control - Choice of automatic control of shutter speed – with corresponding digital display – with manual aperture selection (automatic mode) or manual shutter speed and aperture setting with adjustment using LED light balance.
  • Metering - Exposure metering through the lens (TTL), selectively with working aperture. Metering principle The light reflected by a metering spot in the center of the first shutter curtain. The metering spot has a diameter of 12 mm and thus corresponds to approx. 13% of the full film format or approx. 2/3 of the short side of the applicable bright line frame in the viewfinder. Metering range (for ISO 100/21°) From 0.03 to 125000 cd/m2 at room temperature, normal humidity and f/1.0. For ISO 100/21° this corresponds to EV-2 to 20 or f/1 and 4s (B setting) to f/32 and 1/1000s. Flashing of the left-hand triangular LED in the viewfinder indicates that the brightness reflected is below the metering range. Metering cell Silicon photodiode with focusing lens to the top left behind the bayonet.
  • Power supply - 6 V from 2 lithium cells, type DL 1/3 N. Battery monitoring by flashing of LEDs in digital display or light balance or by illumination of bc display or all LEDs going out.
  • Weight (camera body without batteries) - approx. 610 g. / 21.5 oz
  • Dimensions (W x H x D without lens) - 138 x 79.5 x 38 mm - 5.4 x 3.1 x 1.5 inches.
  • Camera body - Brass top and base plate. Silver chrome finish or black chrome finish. Tripod thread A 1/4 (1/4") DIN in base plate.
  • Accessories - SF 24D Flash Unit, LEICAVIT M, LEICA MOTOR M, LEICA WINDER-M, LEICA WINDER M4-P or LEICA WINDER M4-2 (from serial no. 10350)
    • Information from manufacturer's technical data June 2006.
  • Manuals & brochures
Forum discussion
Leica M7 Serial Numbers
SN Start SN End Product Year Batch
2777001 2777001 M7 2001 1
2777002 2782000 M7 2001 4999
2782021 2787000 M7 2002 4980
2849751 2854750 M7 (black) 2002 5000
2884101 288910 M7 2002 5000
2942201 2947200 M7 2003 5000
2999998 3000000 M7 2003 3
3000001 3001000 M7 Titan 50 Jahre M (+black) 2003 1000
3009101 3010100 M7 a la carte 2004 1000
3121956 3122006 M7 CPA Edition 2006 51
Initial assigned serial numbers 2001-2006 only 27,033
Serial numbers compiled from Puts Pocket Pod - Note: List ends in 2006
