Hektor f= 13.5 cm 1:4.5
Revision as of 15:28, 15 June 2010 by Admin (talk | contribs)
  • Leica Order No. - HEFAR, KUP or CHROM, HEFAR-M, 11 135 LLC - 182
  • Production era - 1933-1959 screw-thread, 1954-1960 M-bayonet < 108,088 lenses
  • Variants - All black, grey and chrome, clear anodized aluminum; coated lens after serial no. 590,550 (1946); OHEBO with fitting for Ploot
  • Type - As camera lens + optical cell unscrews for use with focusing adapter 16464 on Visoflex
  • Number of lenses /groups - 4 /3
  • F stop range - f/4.5-f/32
  • Closest focusing distance - 1.5 m /4.92 ft
  • Smallest object field -
  • Diaphragm setting /type -
  • Angle of view diagonal - 19 degrees
  • Filter type - A36 and E39
  • Accessories - Viewfinder: SYEOO Hood: IUFOO 12575 and 12585
  • Materials - Lacquered brass, or later, clear anodized aluminum with black sharkskin
  • Dimensions (length to flange x diameter) - 5.02 x 2.01 in
  • Weight - 440-555 g /0.97-1.22 lb
  • Inscription - Hektor f=13.5cm 1:4.5 Nr.1xxxxxx - Ernst Leitz GmbH Wetzlar
Hektor f= 13.5 cm 1:4.5 Serial Numbers
Note: Puts list begins in 1933 with serial number 156001.
.* Lens 1659348 is Bundeseigentum for Visoflex
172001 172500 Hektor 13.5 cm 1:4.5 1933 500
196001 197000 Hektor 13.5 cm 1:45 (S-black) 1934 1000
241001 242000 Hektor 13.5 cm 1:45 (S-black) 1935 1000
245001 246000 Hektor 13.5 cm 1:45 1935 1000
310001 311000 Hektor 13.5 cm 1:45 1936 1000
370001 372000 Hektor 13.5 cm 1:45 (S-black) 1937 2000
415001 416000 Hektor 13.5 cm 1:45 1937 1000
440001 442000 Hektor 13.5 cm 1:45 1938 2000
485001 487000 Hektor 13.5 cm 1:45 (S-black) 1938 2000
530501 531000 Hektor 13.5 cm 1:45 1939 500
538501 540000 Hektor 13.5 cm 1:45 (S-black) 1939 1500
558001 559000 Hektor 13.5 cm 1:45 (S-black) 1940 1000
575201 576200 Hektor 13.5 cm 1:45 (S-black.gray) 1941 1000
590201 591000 Hektor 13.5 cm 1:45 1942 800
600001 601000 Hektor 13.5 cm 1:45 (S-black) 1945 1000
608001 609000 Hektor 13.5 cm 1:45 (S-black) 1946 1000
617001 618000 Hektor 13.5 cm 1:45 1946 1000
637001 638000 Hektor 13.5 cm 1:45 1947 1000
644101 645000 Hektor 13.5 cm 1:45 1947 900
655001 657000 Hektor 13.5 cm 1:45 (S-black) 1948 2000
699001 701000 Hektor 13.5 cm 1:45 1949 2000
715001 718000 Hektor 13.5 cm 1:45 (S-chrom) 1949 3000
824101 826000 Hektor 13.5 cm 1:45 1950 1900
851001 856000 Hektor 13.5 cm 1:45 1951 5000
984101 987100 Hektor 13.5 cm 1:45 (S-chrom) 1952 3000
1073001 1076000 Hektor 13.5 cm 1:45 (S-chrom) 1953 3000
1083001 1086000 Hektor 13.5 cm 1:45 (S-chrom) 1953 3000
1113386 1113437 Hektor 13.5 cm 1:45 1953 52
1127001 1130000 Hektor 13.5 cm 1:45 (S-chrom) 1954 3000
1130001 1132000 Hektor 13.5 cm 1:45 1954 2000
1134001 1137000 Hektor 13.5 cm 1:45 1954 3000
1206001 1209000 Hektor 13.5 cm 1:45 (S-chrom) 1954 3000
1238001 1240636 Hektor 13.5 cm 1:45 1955 2636
1268001 1271000 Hektor 13.5 cm 1:45 1955 3000
1311001 1315000 Hektor 13.5 cm 1:45 (M-chrom) 1955 4000
1345001 1348000 Hektor 13.5 cm 1:45 (S-chrom) 1956 3000
1383001 1386000 Hektor 13.5 cm 1:45 1956 3000
1406001 1409000 Hektor 13.5 cm 1:45 1956 3000
1413501 1418000 Hektor 13.5 cm 1:45 (M+S-chrom) 1956 4500
1440001 1445000 Hektor 13.5 cm 1:45 1956 5000
1506001 1510000 Hektor 13.5 cm 1:45 (M-chrom+oliv) 1957 4000
1559101 1562000 Hektor 13.5 cm 1:45 (M-chrom+oliv) 1958 2900
1583101 1585000 Hektor 13.5 cm 1:45 1958 1900
1608001 1611000 Hektor 13.5 cm 1:45 (M+S-chrom) 1958 3000
1621001 1623000 Hektor 13.5 cm 1:45 1958 2000
1642001 1643000 Hektor 13.5 cm 1:45 (S-chrom) 1958 1000
1647001 1649000 Hektor 13.5 cm 1:45 1959 2000
1659001* 1660000 Hektor 13.5 cm 1:45 (M-chrom) 1959 1000
1689501 1690500 Hektor 13.5 cm 1:45 1959 1000
1717001 1720000 Hektor 13.5 cm 1:45 (M-chrom) 1960 3000
1737001 1740000 Hektor 13.5 cm 1:45 (M+S-chrom) 1960 3000
TOTAL ASSIGNED SERIAL NUMBERS 1933-1960 108,088
