O
Forum discussion| Leica Code | Description | Production Year | Remarks |
| OAGNO | Medical copy stand using PLOOT | 1938-19?? | - |
| OAPDO | Medical copy stand using PLOOT | 1939-19?? | Italian item |
| OCEGO | Leica Ig body | 1957-1963 | - |
| OCLOM | Visoflex II with 4x 90 magnifier, bayonet mount | 1962-19?? | - |
| OCMOR | Visoflex lens 1:3.5 / 65 Elmar | 1960-1970 | 11062 |
| ODULO | PROON reflex housing + PAMOO right-angle magnifier | 1940-19?? | - |
| OEFGO | Leica If body | 1952-1957 | - |
| OEGIO | Leica If with viewfinder for 50 mm lenses; Leica Ic in 1950 NY catalog | 1952-1957 | - |
| OEINO | Leica If with viewfinder for 50 mm lenses and ELMAR | 1952-1957 | - |
| OERDO | Summicron 90 short mount with preset diaphragm Forum discussion | 19??-19?? | 11126 |
| OESBO | Summicron 90 short mount with standard diaphragm ring Forum discussion | 19??-19?? | 11124 |
| OEUPO | Extension ring for Summicron (II) f= 9 cm 1:2 with !:4.5 reproduction ratio | 1959-19?? | 16474 |
| OHEBO-M | 19??-19?? | - | |
| OHIKO | Stereo unit complete with Stemar lens OISBO, prism, and viewfinder for screw-mount cameras | 1954-1957 | - |
| OHIKO-M | Stereo unit complete with Stemar lens OISBO, prism, and viewfinder for M-mount cameras | 1950's | - |
| OHTEO | OIPVO stereo viewer + OIFCO light unit | 1950's | - |
| OHUGO | No. 1 light yellow filter; paired for Stemar mount | ca.1959 | NY item |
| OHVIO | Orange filter; paired for Stemar mount | ca.1959 | NY item |
| OHWLO | UVa filter; paired for Stemar mount | ca.1959 | NY item |
| OIASO | Sremar stero lens for M-camera | 1954-1957 | - |
| OIDYO | Cylidrical chrome, half frame viewfinder used with Stemar stereo unit similar in shape to SBOOI | 1950's | - |
| OIFCO | Stereo light unit | 1950's | - |
| OIGEO | Stereo lens hood for use on Stemar when prism is not attached | 1950's | ELC |
| OIMPO | Prism for front of Stemar for subject distances beyond 10 feet; hinged front cover added in 1955 | 1950's | - |
| OIPVO | Stereo viewer with independently focusing eye pieces; brittle plastic housing | 1950's | - |
| OIRZO-M | Stereo unit complete with Stemar lens OIGEO, prism, and viewfinder for M-mount cameras | 1950's | - |
| OIRZO-S | Stereo unit complete with Stemar lens OIGEO, prism, and viewfinder for screw-mount cameras | 1950's | - |
| OISBO | Stemar stereo lens | 1950's | - |
| OIVHO | Rear cover for bayonet-mount Stemar | 1950's | - |
| OIWKO | Lens cap with bayonet for Stemar | 1950's | - |
| OIXMO | Rear cover for screw-mount Stemar | 1950's | - |
| OIZQO | Rear cover for Stemar prism | 1950's | - |
| OKARO | Orange filter to improve contrast between rangefinder images for FOKUS or Leica IIc, IIf, IIIb, IIIc and IIIf in chrome Forum discussion | 1939-1962 | 14058 |
| OKBZO | Diopter correction lens for near-sightedness for Leica IIIg | 1960-19?? | 14064 |
| OKLMO | Connecting piece to convert Focomat Ic enlarger to copy use with column VOOQF and arm OKYNO | 1956-19?? | 16744 |
| OKVCO | Diopter correction lens for astigmatism for Leica IIIg | 1960-19?? | 14066 |
| OKYNO | Arm for Focoslide Valloy II enlarger | 1956-19?? | 16748 |
| OKZPO | Copy stand 25 1/2 inch column with guide rail | 19??-19?? | 16747 |
| OLEYO | Single exposure camera with IBSOR shutter used with Elmar 3.5, 5, and 10.5 cm lenses | 1934-1935 | JCB's a little...15 |
| OLIGO | Single exposure camera with Ibsor shutter used a variety of lenses | 1934-1939 | JCB's a little...15 |
| OLLUX | Hood for 35mm f/1.4 Summilux I | 1961-19?? | - |
| OLORA | Single exposure camera without shutter | 1936-19?? | NY item |
| OMAPO | Close focus accessory with parallax for 50 mm 1:4 lens; per Lager: catalog item only, no known examples are known | 1939 | - |
| OMEXO | Complete copy stand including OOZEG, OOZAB, ZOOXY, VALOO, LVFOO, KGOON, OPKOM, ROOYH and ONLIO | 1951-19?? | - |
| OMIFO | Close focus accessory with parallax for 90mm f/4 Elmar lens | 1949-1968 | - |
| ONLIO | Canvas carrying bag portion of OMEXO for Focoslide | 1951-19?? | - |
| OOBAZ | Late version focusing stage known as Focoslide for Screw-thread cameras using N series helical focusing lenses and extension tubes | 1958-19?? | 16607 |
| OOEUK | 16 x 14 1/2 inch light box with 4 lamps | 1951-19?? | 16763 |
| OOEVM | 9 1/2 x 7 inch light box with 4 lamps Forum discussion | 1951-19?? | 16762 |
| OOFRC | Remote shutter release and winder operated by two chords | 1936-19?? | - |
| OOGAN | OOBAZ Focoslide + VXZOO + VTOOX for Elmar f= 5 cm 1:2.8 | 1958-19?? | 16632, 16603-3/8" bush |
| OOGIT | OOBAZ Focoslide + VXOOT + VALOO for Elmar (III) f= 5 cm 1:3.5 | 1958-19?? | 16633, 16604-3/8" bush |
| OOGUM | OOBAZ Focoslide + ZOGOO for Focotar | 1958-19?? | 16634, 16612-3/8" bush |
| OOMAP | OOTGU Focoslide + ZOGOO for Focotar | 1956-19?? | 16682, 16674-3/8" bush |
| OOMEX | OOTGU Focoslide + VXZOO + VTOOX for Elmar f= 5 cm 1:2.8 | 1958-19?? | 16633, 16604-3/8" bush |
| OOMYL | OOTGU Focoslide + VSPOO + VTROO for Summicron | 1956-19?? | 16681, 16678-3/8" bush |
| OORES | Rotating focusing mount with screen; early versions with single lens; 1937 double; slide-in and bayonet versions | 1934-1950's | JCB's a little...17 |
| OOTGU | Late version focusing stage known as Focoslide for M-cameras using N series helical focusing lenses and extension tubes | 1957-19?? | 16680 |
| OOZAB | Focusing stage known as Focoslide; early version had single bar on spring-loaded arm; later version with adjustable positioning bar; last version was H-shaped to clear flash bracket lug | 1938-1957 | - |
| OOZAB-G | Focusing stage known as Focoslide for accepting Leica IIIg camera | 1951-1957 | - |
| OOZEG | Folding horse-shoe type copy stand portion of OMEXO for Focoslide | 1951-19?? | - |
| OOZIS | Collapsible, horseshoe shaped copy stand | 1939-19?? | - |
| OOZKU | Set of 5 extension rings for OOZIS copy stand | 1939-19?? | - |
| OOZMY | Complete copy outfit including OOZAB, ZOOXY, ROOYH, VALOO, LVFOO and OPKOM release | 1952-19?? | - |
| OPDUR | Medical copy stand using OPRAL and OPFAS | 19??-19?? | - |
| OPFAS | Medical copy stand using frame with handle and chest support | 1932-19?? | - |
| OPKOM | Cable release portion of OMEXO for Focoslide; 20 inches with lock | 1951-19?? | - |
| OPRTO | Diopter correction lens for near-sightedness for Leica IIc, IIf, IIIb, IIIc and IIIf | 1951-19?? | 14060 |
| OPRYL | Medical copy stand using lower body strut with webbing sling | 19??-19?? | - |
| OPSVO | Diopter correction lens for astigmatism for Leica IIc, IIf, IIIb, IIIc and IIIf | 1951-19?? | 14065 |
| OQWCO | Lens cap Forum discussion | 19??-19?? | 14028 |
| OQZIO | Diopter correction lens for near-sightedness for Viso magnifiers LVFOO and PEGOO | 1960-19?? | 14063 |
| ORAKO | Orange filter to improve contrast between rangefinder images for FOKUS or Leica II, III and IIIa in black or chrome Forum discussion | 1936-1962 | 14057 |
| ORBMO | Diopter correction lens for near-sightedness for Leica I-IIIa and Universal viewfinder | 1941-19?? | NY item |
| ORLEO | Diopter correction lens for astigmatism for Leica M-cameras to 1977 | 1956-1977 | 14062 |
| ORESO | SPOOV copy stand + OORES rotating stage | 1936-19?? | - |
| ORMGO | Diopter correction lens for astigmatism for Leica I-IIIa and Universal viewfinder | 1941-19?? | NY item |
| OROBA | Cap used with XOOIM hood (in reverse position) on a 50 mm Summilux Forum discussion | 19??-19?? | - |
| OROLF | Lens turret for 3 lenses with handle; no more than 250 were made OROLF image | 1960 | [1] [2] |
| ORPDO | A42 slip-over, chromed plated brass with felt lining front cap for 21mm f/3.4 Super-Angulon-R | 1958-1963 | 14031 |
| ORPNO | Front cap for f = 12.5 cm 1:2.5 Hektor - with rear cap HGOOI it became a container for the lens JCB's a little...If | 19??-19?? | - |
| ORQPO | Hood for Summarex f= 8.5 cm 1:1.5; early version was black with clamping screw, later chrome for bayonet fitting | 1951-1960 | 12525 JCB's a little...IIIf |
| ORTOX | Diopter correction lens for near-sightedness for Leica M-cameras to 1977 | 1951-1977 | - |
| ORTUX | Diopter correction lens for near-sightedness for Leica I-IIIa and Universal viewfinder Forum discussion | 1933-19?? | 14061 |
| ORTVO | Cap that screws into body lens opening | 19??-19?? | 14055 |
| ORUXO | Diopter correction lens for astigmatism for Leica I-IIIa and Universal viewfinder | 1938-19?? | 14069 |
| ORWYB | Diopter correction lens for near-sightedness for Leica IIIb | 1939-19?? | NY item |
| ORYCE | Diopter correction lens for astigmatism for Leica IIIb | 1939-19?? | NY item |
| ORYFO | Rear dust cap for screw lenses | 1951-19?? | 14050 |
| OSBLO | Magnifying eye-piece for 5 or 9 cm screw lens; converts lens to small telescope - see Photography Accessories for Monoscopes | 1954-19?? | Cosmonet OSBLO |
| OSERO | Diopter correction lens for astigmatism for Viso magnifiers LVFOO and PEGOO | 1960-19?? | 14069 |
| OTDYM | Visoflex II without magnifier, bayonet mount Forum discussion | 1962-19?? | 16455 |
| OTEMO | Stemar attachment for subject distance of 3 - 10 meters; only 20 of these were delivered | 1950's | - |
| OTHEO | 5 x stereo viewer | 1950's | - |
| OTPLO | Telyt 20 cm 1:4.5 for Visoflex | 19??-19?? | JCB's a little...11 |
| OTPRO | 1:1.25 magnification accessory for OTZFO focusing mount used with Visoflez II/ III | ? | 16471 |
| OTQNO | Visoflex ring addapter for Elmar 9 cm | 1959-19?? | 16468 |
| OTRPO | Visoflex extension tube for near focusing with universal focusing mount Forum discussion | 1959-19?? | 16471 |
| OTSRO | Adapter for use of 13.5 cm Hector lens with OTZFO focusing mount used with Visoflex II/ III Forum discussion | 1959-19?? | 16472 |
| OTVXO | 5x chimney eyepiece for Visoflex II Forum discussion | 1962-19?? | 16461 |
| OTXBO | 4x 90 degree eyepiece for Visoflex II Forum discussion | 1962-19?? | 16461 |
| OTYDO | Visoflex II without magnifier, screw mount Forum discussion | 1962-19?? | 16457 |
| OTZFO | Universal focusing mount for Visoflex II/ III for use with 1:3.5 / 65 Elmar, 90mm Elmarit and 135mm Elmar lenses Forum discussion | ? | 16464 Forum discussion |
| OUAGO | Visoflex addapter for using Elmar 9 cm Forum discussion | 1959-19?? | 16467 |
| OUBIO | Visoflex II/ III adapter for Hektor 125 mm; Elmar and Hektor 135 mm in short mounts; TELYT Visoflex lenses Forum discussion | 1959-19?? | 16466 Forum discussion |
| OUCLOO | Visoflex II with 4x 90 magnifier, screw mount | 1962-19?? | 16458 |
| OUEPO | Close-focus adaptor to be used with either the Summicron (II) f= 9 cm 1:2 in ZOOEP/16463 or 16462 adaptor or the 2.8/135 in 16462 adaptor. This usage will yield a 1:4.5 reproduction scale. Forum discussion | 1959-19?? | 16474 |
| OUFRO | Extension ring for 35/50mm M-bayonet lenses with 1:1 ratio | ? | 16469 |
| OUFRO | Visoflex extension ring for 5 and 3.5 cm lenses | 1959-19?? | 16469 |
| OUTSO | Projection head to fit ground glass screen of Focoslide or Reprovit | 1951-19?? | 16750 |
| OVAFO | Base and 48 x 1 5/8" diameter column for Reprovit I | 1951-19?? | - |
| OVURO | Valoy II copy stand with 32 inch column and UWOOS bracket for Focoslide | 1960-19?? | 16701 |
| OZTFO | Connector ring for the 65mm Elmar and 90 mm Elmarit to R-body Forum discussion | 19??-19?? | - |
| OZTNO | Cable release addaptor for using screw release on M-camera Forum discussion [3] | 1955-19?? | 14088 |
| OZTOM | Double cable release for M-camera Forum discussion | 19??-19?? | 16491 |
| OZUPO | Visoflex I housing - JCB's Visoflex I Collection | 1951-19?? | 16484 |
| OZWTO | Double cable release for Visoflex I with time lock screw; early chrome and later black versions JCB's a little...11 | 1951-19?? | 16492 |
| OZWTO-M | Double cable release for Visoflex M-camera with time lock screw; early chrome and later black versions Forum discussion | 1951-19?? | 16491 |
| OZXOM | Visoflex I with 5x chimney eyepiece, bayonet mount | 19??-19?? | 16482 |
| OZXVO | Cable release for Visoflex I for screw cameras only; pneumatic so called "sports release" | 1954-19?? | 16493 |
| OZYXO | Visoflex I with 5x chimney eyepiece, screw mount | 1951-1954 | 16485 |
| OZYXO-M | Visoflex with 5x chimney eyepiece, bayonet mount | 19??-19?? | 16482 |
