Summicron (I) f= 9 cm 1:2
Revision as of 19:11, 15 June 2010 by Admin (talk | contribs) (→‎Comment)
  • Leica Order No. - SOOZI, SEOOM 11123 11133 LLC - 174
  • Production era - 1957-1962, 490 screw lens, 4430 bayonet lens < 10,300 lenses
  • Variants - All black, all chrome, and black and chrome versions; preset ring with f/16 or f/22 minimum aperture; unscalloped focusing knurl (UFK) version
  • Type - As camera lens + optical cell unscrews for use with focusing adapter 16464 on Visoflex
  • Number of lenses /groups - 6 /5
  • F stop range - f/2-f/22 or f/2-f/16
  • Smallest object field - 220 x 330 mm
  • Diaphragm setting /type -
  • Angle of view diagonal - 27 degrees
  • Filter type - E48
  • Accessories - Hood: HMOOD
  • Materials -
  • Dimensions length x diameter - 110 x 66 mm / 4.33 x 2.60 in
  • Weight - 660 g /1.46 lb
  • Inscription - LEITZ CANADA 165XXXX SUMMICRON 1:2/90
    Ernst Leitz Canada Ltd. Midland Summicron f = 9cm 1:2 Nr. 158xxxx
  • Designer - Walter Mandler
  • On the street - $US 950 (M) - 800 (S) in 2010
  • Forum discussion
Summicron (I) f= 9 cm 1:2 Serial Numbers
.* Lens 1615415 is Summicron 2 / 90 (ELC.S-chrom)
1119001 1119200 Summicron f= 9 cm 1:2 (ELW.S-black+M-chrom) 1953 200
1477001 1477100 Summicron f= 9 cm 1:2 (ELC.S-black+chrom) 1957 100
1580001 1581000 Summicron f= 9 cm 1:2 (ELC.S-black+M-chrom-UFK) 1958 1000
1615001* 1616000 *Summaron f= 3.5 cm 1:2.8 1958 1000
TOTAL ASSIGNED SERIAL NUMBERS 1953-1960 2,300
Lens superseded by Summicron (II) f= 9 cm 1:2
