M9
- Order-No. - 10705 (steel-gray paint finish); 10704 (black paint finish)
- Camera type - Compact digital rangefinder system camera.
- Lens mount - Leica M bayonet with additional sensor for 6-bit coding.
- Lens system - Leica M lenses from 16 to135 mm.
- Image format / image sensor - 5270 × 3516 pixels (18.5 megapixels) CCD chip, active area approx. 23.9 × 35.8 mm / 5212 x 3472 pixels (18 megapixels) (corresponds to the effective image format of Leica M film cameras).
- Optional resolution - DNG™ - 5212 × 3472 (18 MP), JPEG: 5212 × 3472 (18 MP), 3840 × 2592 (10 MP), 2592 ×1728 (4.5 MP), 1728 ×1152 (2 MP), 1280 x 846 pixels (1 MP).
- Image file formats - DNG™ (RAW data), optionally uncompressed or slightly compressed (by non-linear reduction of color depth), 2 JPEG compression levels.
- Color spaces - Adobe® RGB, sRGB.
- White balance - Automatic, manual, 7 presets, direct color temperature selection.
- Storage media - SD cards up to 2 GB / SDHC cards up to 32 GB.
- Menu languages - German, English, French, Spanish, Italian, Japanese, traditional Chinese, simplified Chinese, Russian.
- Compatibility - Windows® XP/Vista®; Mac® OS X (10.5)
- Exposure metering - Through-the-lens (TTL) metering, center-weighted at working aperture. Center-weighted TTL metering for flash exposure with dedicated SCA-3000/2 standard flash units.
- Metering principle - The light reflected from the bright leaves of the first shutter curtain is metered.
- Metering range (at ISO 160/23°) - At room temperature and normal humidity, equivalent to EV 0 to 20 or f 1.0 and 1.2s to f 32 and 1/1000 s. Flashing left triangular LED in the viewfinder indicates light levels below metering capability.
- Metering cell - for available light (ambient light metering) Silicon photodiode with condenser lens, bottom center of camera base.
- Exposure modes - Optional automatic determination of shutter speeds with preselected apertures – aperture priority automatic mode A – with corresponding digital display, or manual selection of shutter speed and aperture and balance by means of an LED light balance with correct exposure display, or over exposure / camera shake trend prevention (snapshot mode only).
- Synchronization - Optional, on first or second curtain.
- Flash synchronization speed - 1/180 s; longer shutter speeds may be used.
- Flash metering - (With SCA-3501/3502 adapter or SCA-3000-standard flash unit, e.g. LEICA SF 24D / LEICA SF-58 Flash exposure control with center-weighted TTL pre-flash metering.
- Flash metering cell - 2 silicon photodiodes with condenser lens in camera base.
- Flash exposure correction - ±3 1/3 EV in 1/3 EV increments, adjustable on SCA-3501/3502 adapter.
- Viewfinder principle - Large size, bright, combined bright-line viewfinder / rangefinder with automatic parallax compensation.
- Eyepiece Adjusted to -0.5 diopters Correction lenses for –3 to +3 diopter available.
- Parallax compensation - The horizontal and vertical differences between the viewfinder and the lens are automatically compensated in accordance with the focusing distance set, i.e. the bright-line frame of the viewfinder automatically moves to cover the image field covered by the respective lens.
- Correspondence between the viewfinder and the actual image - At a focusing distance of 1 meter, the bright-line frame size corresponds precisely to that of a sensor of 23.9 × 35.8 mm. Focused at infinity, and depending on the focal length, approx. 7.3% (28 mm) to 18 % (135 mm) more of the sensor is covered than the bright-line frame actually shows, the opposite is the case for focusing distances less than 1 meter, i.e. somewhat less.
- Long-base rangefinder - Bright rectangular spot (RF spot) with coincident and superimposed rangefinder in the center of the viewfinder. Effective rangefinder base 47.1 mm (actual base length 69.25 mm × viewfinder magnification 0.68×).
- Viewfinder displays - (Lower edge) LED symbol for flash status. Four-digit, seven-segment digital LED display with dots above and below, display brightness adjusted for ambient light, for exposure correction warnings, display of automatically determined shutter speed in aperture priority automatic mode, exposure value lock indicator, out of metering range warning in aperture priority automatic mode and countdown display for shutter speeds longer than 2 s. LED light balance with two triangular and one round, central LED in manual exposure mode. The triangular LEDs show the required directions for turning the aperture ring or the shutter speed dial to correct the exposure setting. They also warn of light levels that are above or below the metering range.
- Displays on the back - 2.5" monitor (color TFT-LCD) with 230,000 pixels
- Shutter speeds - In aperture priority automatic mode (A) continuous from 32 s to 1/4000 s. in manual mode, 8 s to 1/4000 s in half increments, B for arbitrary long exposure times (in conjunction with delayed release T function, i.e. 1st release = shutter opens, 2nd release = shutter closes, (1/180 s) fastest shutter speed for flash synchronization. Shutter cocking With integrated motor, with low-noise footprint, optionally only after release of shutter release button.
- Continuous shooting - Approx. 2 frames/s, ≥ 8 frames in sequence.
- Delayed release - Countdown 2 s (in aperture priority automatic mode and manual exposure mode) or 12 s, menu setting option, countdown is indicated by a flashing LED on the front of the camera and a corresponding display on the monitor screen.
- Camera power on / power off - Main switch located on the top deck, optional sleep mode for camera electronics after 2 / 5 / 10 minutes, reactivation by slight pressure to shutter release button.
- Power supply - 1 rechargeable lithium-ion battery, nominal voltage 3.7 V, capacity 1900 mAh. Charge level displayed on monitor screen, when shutter locked in open position (for sensor cleaning), additional acoustic warning signal for insufficient charge.
- Battery charger - Inputs: 100–240 V AC , 50/60 Hz, automatic adaptation, or 12/24 V DC - Output: 4.2 V DC, 800 mA.
- Camera body - Full-metal body in diecast magnesium alloy with cataphoretic paint finish and artificial leather trim. Brass top deck and base plate, black or steel-gray finish.
- Frame selection lever - Enables the manual display of different bright-line frame pairs at any time (e.g. for framing comparisons).
- Interface - 5-pin Mini-USB 2.0 high-speed socket for fast data transfer.
- Dimensions (length × depth × height) - Approx. 139 × 37 × 80 mm; 5.47 x 1.46 x 3.15 in
- Weight - 585 g (including battery) / 1.30 lb
- Package includes - Battery charger 100–240 V with two power cords (Euro, USA, may differ for other export markets) and one car charging cable, lithium-ion battery, USB cable, carrying strap.
- Test shots
- Manuals & brochures
- M9 Instructions courtesy of Thorsten Overgaard
M9 Lenses
M9 Accessories
M9 Firmware History
- 1.002 - September 9, 2009
- Initial Version
- 1.116 - March 15, 2010
- Camera Performance
- Faster zooming into the last picture taken
- Speed of SD-card formatting enhanced
- Image quality of “thumbnail” pictures improved
- SD- Card compatibility improved
- Magenta colour shift correction for the following wide angle lenses improved
- New ISO setting-related vignetting correction
- Bug fixes
- Transfer of large data amounts to a Mac in USB-Mass storage mode
- Sensor cleaning mode with battery capacity <50%
- Function “Deleting all images” while zoomed picture is shown on screen
- Function “Deleting all images” from a SD card with non-M9 pictures on it
- Interrupting a long exposure by switching off the camera
- Zooming into pictures with “Vintage B+W” setting
- “Max aperture value” in EXIF data corrected for the following lenses
- SDHC card compatibility
- 1.138 - August 6, 2010
- Improved compatibility of SDHC cards. Nevertheless, we recommend our customers cards such as the “Extreme III” from the leading brand “SanDisk”.
- Improved Auto White Balance in conditions with power saving lamps and tungsten light.
- Saving user profiles has been improved (changing from one profile to another did sometimes cause problems)
- Time display in “American” format corrected.
- Auto power off bug fixed (camera did turn off automatically while using the Play Mode or scrolling through the menu).
